rose9065f
Posted: Mon Dec 21, 2009 4:22 pm Post subject: LG bungee cord |
CPS sent me 5/16 bungee cord instead of 3/8, and they are replacing it. But just out of curiosity, would there be a problem if I made up LG bungees of 5/16, using 8 or 9 loops instead of the 6 loops for 3/8. Seems like it might be easier to install.
Second question, is there any difference between the bungee cord I get from CPS or ACS and what I might buy from Ace hardware?
Jim
KF2/582
Pahrump NV
_________________ KF2 582 |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Dec 21, 2009 9:42 pm Post subject: LG bungee cord |
Jim,
At one time, the earl Kitfox factory had difficulty getting the 3/8" bungee
cord and did supply the 5/16". I don't recall how many loops in the
thinner setup. Regarding ACE hardware. I am almost certain that the
bungees you will get from any of the aircraft suppliers will be a mil spec
version. This typically has two layers of cotton woven to provide the outer
shieths. I guess you could try it.
Lowell
Lynn Matteson
Posted: Tue Dec 22, 2009 3:24 am Post subject: LG bungee cord |
You might want to order both the 5/16" and the 3/8", based on my
experience with what I received from Spruce.....the 5/16" was
stronger than the 3/8". (I wasn't sure what size I wanted a couple of
years ago, for my ski rigging, so I ordered three sizes.)
Lynn Matteson
Jabiru 2200, #2062, 824.8 hrs
Countdown to 1000 hrs~178 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Dec 22, 2009, at 12:32 AM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
Jim,
3/8" bungee cord and did supply the 5/16". I don't recall how many
loops in the thinner setup. Regarding ACE hardware. I am almost
certain that the bungees you will get from any of the aircraft
suppliers will be a mil spec version. This typically has two
layers of cotton woven to provide the outer shieths. I guess you
could try it.
Lowell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Dec 22, 2009 5:34 am Post subject: Re: LG bungee cord |
| Quote: | CPS sent me 5/16 bungee cord instead of 3/8, and they are replacing it. But just out of curiosity, would there be a problem if I made up LG bungees of 5/16, using 8 or 9 loops instead of the 6 loops for 3/8. Seems like it might be easier to install.
Jim
KF2/582
Pahrump NV
Jim, here's the information in a letter I received with my Classic 4 kit.
"The 3/8" diameter cord is 66" long and requires six wraps.
The 5/16" diameter cord is 90" long and requires thirteen wraps."
The bungee cord I bought at ace hardware...to make a snow bungee, not to use on my kitfox...has a very stiff and abrasive cover. I think it would act like a saw on aircraft tubing.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
dwight purdy
Posted: Tue Dec 22, 2009 5:55 am Post subject: LG bungee cord |
Tom
I guess Ace stores do not all stock the same cord as mine was very slick
polyester. They are four years old now and need replaced.
Dwight Purdy
model II
_________________ dwight
model II |
dave
Posted: Tue Dec 22, 2009 6:52 am Post subject: Re: LG bungee cord |
I just got in 100 feet from ASC of 3/8" cord.
I think it might mike just over 3/8 though.
Will take a pic later.
MIL spec Cord is much more firmer than the cheap hardware store stuff.
Make a loop and pull it or hang from it . Big difference.
Need a video? LOL
BTW more Kitfox vids up this week ......
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dave
Posted: Wed Dec 23, 2009 4:05 am Post subject: Re: LG bungee cord |
Bungee cord pic here from ACS MIL SPEC cord
http://rotaxaircraft.com/forum/viewtopic.php?f=8&t=157
Register a name there in case they start blocking pics so that you have to log in like other forums I have seen.
Tom Jones
Posted: Wed Dec 23, 2009 7:39 am Post subject: Re: LG bungee cord |
Yellow, yellow, yellow = First quarter 2009.
Yellow, yellow, blue = Last quarter of 2009.
Do I have the code correct?
Classic IV
Ellensburg, WA |
vetdrem
Posted: Wed Dec 23, 2009 8:27 am Post subject: Re: LG bungee cord |
I don't think so.
43.13 reads:
TABLE 9-1. Bungee cord color codes.
YEARS ENDING
WITH
COLOR
0 or 5 Black
1 or 6 Green
2 or 7 Red
3 or 8 Blue
4 or 9 Yellow
QUARTER COLOR
1st Red
2nd Blue
3rd Green
4th Yellow
c. The color coding is composed of
threads interwoven in the cotton sheath that
holds the strands of rubber cord together. Two
spiral threads are used for the year coding and
one thread is used for the quarter of the year
sheath, e.g. yellow and blue would indicate
that the cord was manufactured in 1994 during
April, May, or June.
therefore, yellow, yellow, yellow would be 4th qtr of 2009 and yellow, yellow, blue would be 2nd qtr of 2009. (assuming that I am reading correctly)
Tom Jones
Posted: Wed Dec 23, 2009 11:32 am Post subject: Re: LG bungee cord |
| Quote: | therefore, yellow, yellow, yellow would be 4th qtr of 2009 and yellow, yellow, blue would be 2nd qtr of 2009. (assuming that I am reading correctly)
You probably are correct. I blue it. Your chart is less confusing. I always seem to get it wrong using the FAA version.
Chapter 9, page 2
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument
Classic IV
Ellensburg, WA |
