Dana
Posted: Tue Dec 22, 2009 5:44 pm Post subject: Seat tanks |
Has anybody used (or seen) a seat tank in an UltraStar?
Currently I have three tanks: the two original 1.75 gallon tanks in front
of the seat, and a 1.5 gallon tank behind the seat. I want to replace all
of these with a single tank, and use the space currently occupied by the
original tanks for storage of small items.
I originally looked at a single tank above the engine and gravity feed
(with the added benefit of eliminating the fuel pump), but there's really
not enough room there. I next looked at the space behind the seat, but
that's pretty limited as well for any off the shelf tanks (I have a plastic
tank a friend gave me, and it's 1/2" too wide to fit... grrrrr). The only
options remaining are a custom tank (too much cost or work) or a molded
seat tank like these:
http://www.calumetair.com/tanks.php
-Dana
CanYouFixTheSpaceBarOnMyKeyboard?
Posted: Tue Dec 22, 2009 6:58 pm Post subject: Seat tanks |
Dana- A seat tank showed up on E-Bay a few months ago. I seem to remember that the ad said it was from Aircraft Spruce, and it gave a part number. I just tried to look it up in both the book and on line, and no luck. You might try calling them in the morning- maybe it is not a catalogued item. Good luck.
Bill Sullivan
Windsor Locks, Ct
Dana
Posted: Wed Dec 23, 2009 3:52 am Post subject: Seat tanks |
At 09:29 PM 12/22/2009, william sullivan wrote:
| Quote: | | Dana- A seat tank showed up on E-Bay a few months ago. I seem to remember that the ad said it was from Aircraft Spruce, and it gave a part number. I just tried to look it up in both the book and on line, and no luck. You might try calling them in the morning- maybe it is not a catalogued item. |
I know, I should have grabbed it then, but I was still looking at other options. I'm pretty sure it was the same as the one I posted the link to.
-Dana
Newton's Seventeenth Law of American Life:
For every action, there is an unequal and moronic overreaction. [quote][b]
Posted: Wed Dec 23, 2009 6:36 am Post subject: Seat tanks |
Dana- I typed into web search "ultralight aircraft seat tanks", and came up with this:
www.quicksilverultralight.com/other/fuel_tanks.htm#6gallon
P.N. AC#397
price- $450 (!!!!!!!)
See if this is what we were looking at. Maybe you can find it at a (much) better price.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Posted: Wed Dec 23, 2009 6:43 am Post subject: Seat tanks |
Dana- Also Calumetair.com
7.4 gallons, $259
Bill Sullivan
Dana
Posted: Wed Dec 23, 2009 11:45 am Post subject: Seat tanks |
At 09:34 AM 12/23/2009, william sullivan wrote:
| Quote: | Dana- Also Calumetair.com
7.4 gallons, $259 |
Bill, the Calumet is the one I'm looking at, and which I posted in the first message. The Quicksilver tank is way too expensive.
-Dana
Sometimes you're the windshield, sometimes you're the bug. [quote][b]
russkinne(at)mac.com Guest
Posted: Wed Dec 23, 2009 4:21 pm Post subject: Seat tanks |
DanaI think Ken Brock developed the seat tank many years ago, for Gyrocopters. Only complaint I ever heard was that they were COLD! -- after all, it is a huge heat-sink. In CA this didn't matter too much.
Good luck
Russ K
On Dec 23, 2009, at 2:38 PM, Dana Hague wrote:
7.4 gallons, $259 |
-Dana
Sometimes you're the windshield, sometimes you're the bug. |
rlaird
Posted: Wed Dec 23, 2009 6:11 pm Post subject: Seat tanks |
Most gyro owners have padded and/or foam seats and backs to their seat tanks, so the cold-complaint isn't really valid. However, there are two issues to consider:
1. Thin walls. Because the walls of the seat tank are relatively thin, there is lots of change in the shape as you add fuel. The change isn't significant at all in terms of comfort, safety or functionality, but, what it does do is, makes it more difficult to fill the seat tank up to the max level. Even just sitting in it will push the gas up higher. Then, as you hit bumps -- ground or air -- the gas will get redistributed around. So, most gyro pilots don't fill them up near the top, so that gas won't come out the vent.
2. Gas level. The majority of gyros with seat tanks will use a clear tube that is ported into the top of the seat and into the bottom of the seat, and there will be a tiny plastic red cylinder that floats on top of the gas in the tube. That is your gauge. It takes a while to get used to that, and requires you be able to swivel your head (and often your body) around to view it.
-- Robert (Kolb & Gyrobee owner)
On Wed, Dec 23, 2009 at 6:15 PM, russ kinne <russkinne(at)mac.com (russkinne(at)mac.com)> wrote:
[quote] DanaI think Ken Brock developed the seat tank many years ago, for Gyrocopters. Only complaint I ever heard was that they were COLD! -- after all, it is a huge heat-sink. In CA this didn't matter too much.
Good luck
Russ K
7.4 gallons, $259 |
-Dana
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
