DCS317(at)aol.com Guest
Posted: Fri Jan 01, 2010 2:56 pm Post subject: Adding an antenna to improve on the ground reception? |
Problem: On the ground at KAWO (non-towered airport) I can't get Seattle Center (and my IFR clearance) because of my RV-8 belly-mounted comm antenna. (In a high wing trainer, this is not a problem.) I have a bubble canopy--can I add an antenna within my canopy to the existing belly antenna with a combiner/splitter to my comm receiver and achieve better reception on the ground without degrading my in the air reception/transmission? Ground plane problem with this setup? I can't easily place another antenna on the top fuselage. Suggestions?
Don Schmiesing
edleg
Posted: Fri Jan 01, 2010 10:00 pm Post subject: Re: Adding an antenna to improve on the ground reception? |
You could use an antenna switch (vhf) to choose/select top or bottom antenna. Check with your local ham radio store, or do a "google" search for same. It would add maybe a pound or two to your comm installation with the switch, extra cabling and antenna.
-Ed-
KD6UBY
jim-bean(at)att.net Guest
Posted: Sat Jan 02, 2010 11:12 am Post subject: Adding an antenna to improve on the ground reception? |
Posted: Sun Jan 03, 2010 1:43 pm Post subject: Adding an antenna to improve on the ground reception? |
a
Don Schmiesing
I have an antenna on my RV-8 slider which works pretty well. It is on the number 2 comm.
I riveted an aluminum sheet to the aft end of the slider for a ground plane. The cable
goes to the front of the slider. The front of the slider is about as far in front of the
shoulder harness bracket when closed as it is in back of it when open, so a loop from the
slider to the bracket works well. The whip goes through the canopy with a rubber grommet.
I have some pictures but they won't get through the list.
Jim Bean
al38kit
Posted: Sun Jan 03, 2010 4:40 pm Post subject: Re: Adding an antenna to improve on the ground reception? |
Put one radio on the new antenna that points up.
Forget about the switch.
al38kit
Posted: Sat Jan 09, 2010 5:57 am Post subject: Re: Adding an antenna to improve on the ground reception? |
IFR DEPARTURE
Expedite Your IFR Clearance. Use the new FS21 dedicated IFR
Clearance Delivery Telephone Number (888-766-8267) when
departing IFR from a non-towered airport that does not have a
remote communication frequency.
