Bob Wichita
Posted: Sun Jan 03, 2010 7:39 am Post subject: Adhesive |
Has anyone found and vinyl or foam rubber adhesive that works in cold
weather. Need to reglue some of my upholstery but it's not holding at 10
degrees.
Bob
_________________ Bob, Wichita |
Posted: Sun Jan 03, 2010 9:46 am Post subject: Adhesive |
Bob,
You're going to have to warm the materials to above 65-degrees F and
then apply. 3M Formula 77 is a good spray adhesive that holds well once
cured.
It won't cure well below 65 degrees F, but will hold tenaciously to -40
degrees F after the cure. Take the materials indoors to a good ambient
temp and allow
the materials to thaw. Clean the surfaces of old adhesive and/or paint
and then start over, spray, let set a couple of minutes, press contact
surfaces together
and allow it all to cure for a day.
Larry McFarland
Bob Gibfried wrote:
10 degrees.
Bob
john.marzulli(at)gmail.co Guest
Posted: Sun Jan 03, 2010 11:10 am Post subject: Adhesive |
I'll second using 3M #77.
I have added some sound deadening material to the inspection/controls bay. I have snagged it a few times while working back there and the glue has held VERY firmly.
DO NOT ARCHIVE
John Marzulli
http://www.GenevieveMarzulli.org/
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Sun, Jan 3, 2010 at 9:46 AM, LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)> wrote:
[quote] --> Zenith701801-List message posted by: LarryMcFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
Bob,
You're going to have to warm the materials to above 65-degrees F and then apply. 3M Formula 77 is a good spray adhesive that holds well once cured.
It won't cure well below 65 degrees F, but will hold tenaciously to -40 degrees F after the cure. Take the materials indoors to a good ambient temp and allow
the materials to thaw. Clean the surfaces of old adhesive and/or paint and then start over, spray, let set a couple of minutes, press contact surfaces together
Larry McFarland
Bob Gibfried wrote:
| Quote: | --> Zenith701801-List message posted by: "Bob Gibfried" <rfg842(at)cox.net (rfg842(at)cox.net)>
Has anyone found and vinyl or foam rubber adhesive that works in cold weather. Need to reglue some of my upholstery but it's not holding at 10 degrees.
Bob
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
http://forums.matronics.com
le, List Admin.
raymondj(at)frontiernet.n Guest
Posted: Sun Jan 03, 2010 2:28 pm Post subject: Adhesive |
I've been using 3M weatherstripping adhesive in a tube on a variety of
projects. Seems similar to the 77 spray except in a tube. I haven't
tried it in a cold environment.
Raymond Julian
Kettle River, MN.
Bob Gibfried wrote:
10 degrees.
Bob
