		apilot(at)surewest.net Guest
				 Posted: Wed Dec 30, 2009 10:54 am    Post subject: FWD Battery Location....reply |
				I agree that the Kolb Mark III will fly better with an aft CG.  I have flown it at 33% and 28%.  It gets busy at 33% in rough weather.  Does anyone know the CG limits?  I assume that it is around 25% to 31%.
		Steve Simmons
				 Posted: Wed Dec 30, 2009 1:55 pm    Post subject: FWD Battery Location....reply |
				16.5 FWD  23.1 AFT for Mark IIIC
				 Posted: Wed Dec 30, 2009 2:39 pm    Post subject: FWD Battery Location....reply |
				tumultuous air will reveal weaknesses in balance better than any method.  A properly balanced airplane will
 endure a sudden blast upwards with a nice straightforward  (level) attitude.  I have flown planes like that.
 My MkIII is not so well blessed.   I'm speaking, obviously, of a column that uniformly boosts yer butt upward,
 not a little dinky thing like ones that lift one wing independently.
 Aside from any other problem with this is the necessity of messing with throttle settings too much.  I'm a lazy pilot
 who prefers to just amble along and look out the winders.
 What is the consensus?  do you end up with your nose down or up?
 BB
		rickofudall
				 Posted: Wed Dec 30, 2009 2:42 pm    Post subject: FWD Battery Location....reply |
				Here's a bit more detailed spread sheet built up from one offered by another lister (sorry, I don't remember who or I'd credit you)Happy New Year and lots of good flying in the coming year. Even you, JP :-}
 Rick
 On Wed, Dec 30, 2009 at 3:36 PM, Steve Simmons <stevesimmons(at)charter.net (stevesimmons(at)charter.net)> wrote:
  [quote]--> Kolb-List message posted by: "Steve Simmons" <stevesimmons(at)charter.net (stevesimmons(at)charter.net)>
		|  Description: |
		  Download |
		|  Filename: |
		 KolbMk3ClassicWAndB.xls |
		|  Filesize: |
		 23 KB |
		|  Downloaded: |
		 247 Time(s) |
				 Posted: Thu Dec 31, 2009 4:41 am    Post subject: FWD Battery Location....reply |
 not a little dinky thing like ones that lift one wing independently.>>
 Hi Robert,
 How do you find those nice big, fat  smooth thermals that lift the whole
 plane on the level?.  I have found those condition in the middle of a
 thermal (sometimes) but I have usually had to go through the `one wing
 lifting` bit to get there.
 Cheers
 Pat
		racerjerry
  Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
				 Posted: Thu Dec 31, 2009 5:48 am    Post subject: Re: FWD Battery Location....reply |
				 	  | apilot(at)surewest.net wrote: | 	 		  | I agree that the Kolb Mark III will fly better with an aft CG.  I have flown it at 33% and 28%.  It gets busy at 33% in rough weather.  Does anyone know the CG limits?  I assume that it is around 25% to 31%. |
 My Firestar II builders manual states that CG limits are between 20 and 35 % of wing chord.
 _________________ Jerry King |
				 Posted: Thu Dec 31, 2009 6:28 am    Post subject: FWD Battery Location....reply |
				Pat, if you fly low through the big hills south of here in the summertime you will definitely get more than one or two
 big lifts.  You will be busy opening and closing the throttle to avoid overspeed, followed immediately by near stall
 and cranking the stick like a butter churn.  Yes, I know, fly higher, but you have to start low to get there.
 I experienced my first aileron flutter in those conditions three years ago.  Airspeed can leap to 90 in an instant.
 BB
 On 31, Dec 2009, at 7:40 AM, pj.ladd wrote:
  Hi Robert,
  How do you find those nice big, fat  smooth thermals that lift the whole plane on the level?.  I have found those condition in the middle of a thermal (sometimes) but I have usually had to go through the `one wing lifting` bit to get there.
  Cheers
  Pat
				 Posted: Tue Jan 05, 2010 8:55 am    Post subject: FWD Battery Location....reply |
				Yes, I know, fly higher, but you have to start low to get there.>>
 Hi Robert,
 I do the opposite.  On the theory that thermals start at ground level and
 dont start to build until they get a bit of height and are strongest at
 cloud base, I tend to go low.
 I think we have different thermals here in the UK. Average say 3/4knots, a
 real stonker would be say 8/9knots wheras I have flown in Texas and the
 bastards seem to start at 10 knots and then build..
 I have never throttled back in a thermal here unless I am trying to maintain
 a fixed height. If I hit a thermal I just pull back and stick a wing down if
 I feel lucky.
 Amazing how we fly in a different style to `real` pilots. I took a `Red
 Arrows` (RAF airobatic team) for a ride in my Challenger. As usual my speed
 varied by a bout 10 knots and the height wandered up and down 50 ft. I
 offered mt passenger the stick and the speed and the height indicators just
 stopped moving as it they  had suddenly become stuck. I did feel amateur.
 Cheers
 Pat
				 Posted: Tue Jan 05, 2010 4:25 pm    Post subject: FWD Battery Location....reply |
				Pat, you have a good point there.  If I maintain 30 ft above the ground the thermals should be mild.
 Unfortunately where I was flying that absurdly boisterous day, the terrain was too vertical to allow.
 I'm more a fair weather flyer now although I know one needs some bumpier air to keep your reactions up to par.
 BB
 nippy here in the northeast US.
 On 5, Jan 2010, at 11:54 AM, pj.ladd wrote:
  Hi Robert,
  I do the opposite.  On the theory that thermals start at ground level and dont start to build until they get a bit of height and are strongest at cloud base, I tend to go low.
  I think we have different thermals here in the UK. Average say 3/4knots, a real stonker would be say 8/9knots wheras I have flown in Texas and the bastards seem to start at 10 knots and then build..
  I have never throttled back in a thermal here unless I am trying to maintain a fixed height. If I hit a thermal I just pull back and stick a wing down if I feel lucky.
  Amazing how we fly in a different style to `real` pilots. I took a `Red Arrows` (RAF airobatic team) for a ride in my Challenger. As usual my speed varied by a bout 10 knots and the height wandered up and down 50 ft. I offered mt passenger the stick and the speed and the height indicators just stopped moving as it they  had suddenly become stuck. I did feel amateur.
  Cheers
  Pat
				 Posted: Tue Jan 05, 2010 4:45 pm    Post subject: FWD Battery Location....reply |
				sorry guys, thought that was direct.
 On 5, Jan 2010, at 7:20 PM, robert bean wrote:
  BB
 > Hi Robert,
 > Cheers
 > Pat
