ADF Radio Compass
Goto page Previous  1, 2
BitterlichMG(at)cherrypoi
PostPosted: Tue Apr 11, 2006 5:06 pm    Post subject: ADF Radio Compass Reply with quote
Tim Gagnon said:
"Sometimes you have to handle all three alone!"
Brilliant.
Please don't talk about dropping the soap.
mgb
brian
PostPosted: Tue Apr 11, 2006 10:48 pm    Post subject: ADF Radio Compass Reply with quote
Bitterlich GS11 Mark G wrote:
Speaking of Loran A .... er, ah .. now Loran C. I heard that the
FAA was thinking of putting more emphasis on Loran C and were planning
on sinking "serious" money into the system upgrading it. The idea being
that us airplane folks would then soon be offered an actual Loran-C //
GPS Nav Aid... both in one box. Kind of like an Embedded GPS Inertial
NAV system, this thing would use a KALMAN filter to blend GPS L1 signals
with Loran-C thus creating a system with accuracy approaching or even
exceeding GPS WAAIS, or at least... that's what is being claimed.
Anyone else heard this rumor?
Yes. It is the new system that the Europeans are fielding. They are
transmitting the WAAS differential data on the LORAN chains instead of
sending it from the satellites. The advantage of this system is that,
while it is very easy to jam GPS, it is almost impossible to jam LORAN.
Also, the kind of interference that affects LORAN has no affect on GPS
and vice-versa. If the GPS part fails for whatever reason, the LORAN
part will still provide usable area navigation and accuracy suitable for
nonprecision approaches.
Why didn't we think of that.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
cgalley(at)qcbc.org
PostPosted: Wed Apr 12, 2006 4:48 am    Post subject: ADF Radio Compass Reply with quote
For one... Loran doesn't work well in rain (IFR) approaches!
brian
PostPosted: Wed Apr 12, 2006 8:49 am    Post subject: ADF Radio Compass Reply with quote
I have flown many a VOR or NDB approach using LORAN as my "backup", in
both rain and snow. It worked almost all the time. The only time I
remember completely losing my LORAN to p-static was over the mid
Atlantic in a dry snowstorm. The p-static was so fierce it took out
every radio in the airplane including the comms. (This was pre GPS so I
don't know if I would have lost the GPS too.)
That is why the GPS/LORAN combination is so powerful. They complement
each other.
LORAN can be prone to failure due to precipitation static (p-static).
GPS isn't. GPS is very susceptible to jamming. LORAN isn't.
BTW, if you use an H-field antenna (usually some kind of loop) instead
of an E-field antenna (usually a whip) you eliminate most of LORAN-C's
sensitivity to p-static. If we start using LORAN to backup GPS as the
Europeans are doing, expect to see more H-field antennas.
Brian Lloyd
PostPosted: Wed Apr 12, 2006 1:49 pm    Post subject: ADF Radio Compass Reply with quote
That is why the system incorporates a KALMAN filter.
Mark Bitterlich
N50YK
P.S.  Basically a KALMAN filter is a piece of software that takes all inputs and develops a smoothed output.  It considers everything about the conditions of the aircraft and the flight and then "decides" how to best BLEND all the inputs for the best possible output.  If one input happens to go away for a certain period of time, it follows the last and best blended solution to still give better short term accuracy than just relying on a stand alone single input.  So if you were to lose EITHER GPS or LORAN input, it would still offer better accuracy than either in a stand alone basis.
Loran-C works at about 90-110 Khz.  It will exhibit all the normal propagation characteristics of a 100 Khz signal.  GPS L1 is at 1565 Mhz and is about -169 dbw down using a spread spectrum technique.  L2 is at 1265 Mhz and is about -166 dbw down.  These are extremely weak signals.   Loran on the other hand is pretty darn strong, their transmitters usually having an output power between 100 KW and 4000 KW, that's 4,000,000,000 watts.. and that is a WHOLE BUNCH.  Either signal can be lost under certain conditions, but typically those conditions are NOT synonymous.
P.P.S.  Brian, I think you were talking about Eurofix.  I think I was talking about LORAN LDC, and hey... we DID think of that!
brian
PostPosted: Wed Apr 12, 2006 5:31 pm    Post subject: ADF Radio Compass Reply with quote
But they are doing it and we aren't. Instead the FAA wants to put all
our eggs in one GPS basket with no effective backup. And I have held the
little Russian GPS jammer in my hand. Nice little box. You used to be
able to buy them for $4000.
Wait for about 10 years for them to kill VOR and LORAN navigation then
park yourself up on Mount Wilson with it and eliminate GPS service in
the greater LA basin. Wait until rush hour during a winter storm and
have yourself a ball. When it happens remember to give me credit for
predicting it.
And there is no way anyone could even hope to build a LORAN jammer. It
would have to be the size of a skyscraper.
Brian Lloyd
HawkerPilot2015
PostPosted: Wed Apr 12, 2006 5:45 pm    Post subject: Re: ADF Radio Compass Reply with quote
predicting it.
There is always dead reckoning and pilotage...but who knows how to do that anymore?
brian
PostPosted: Wed Apr 12, 2006 5:56 pm    Post subject: ADF Radio Compass Reply with quote
I doubt that most pilots would be prepared to transition to DR while on
the gauges when all their other nav went out.
Brian Lloyd
Page 2 of 2
