william(at)gbta.net Guest
Posted: Thu Jan 07, 2010 12:26 pm Post subject: OOPS!! What have I done??? |
Yes, did it right after I posted it on here. Decided I couldn't wait.
Basically, Scott said it wasn't a big deal. The flange on the main wing
spar doesn't provide much structural support--mainly an attach point for the
skins. He recommended I use a scotch-brite wheel and remove the "nip" . As
long as I retain the minimum edge clearance on the hole it's not a big deal.
That being said, I immediately went out and fixed it. Now all I need to do
is put a little primer over where I removed the alodine finish. There's a
spot along the rear edge of the spar flange now about 1/4" long and maybe
1/8" max depth where I ground it out and smoothed/cleaned it.
Another one of those WHEW!!! moments. What was I thinking??? Oh well, it's
fixed.
Bill
Bill
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Jan 07, 2010 12:54 pm Post subject: OOPS!! What have I done??? |
Glad to hear it. I didn't know.
On Jan 7, 2010, at 13:19, "Bill and Tami Britton" <william(at)gbta.net>
wing spar doesn't provide much structural support--mainly an attach
point for the skins. He recommended I use a scotch-brite wheel and
remove the "nip" . As long as I retain the minimum edge clearance
need to do is put a little primer over where I removed the alodine
finish. There's a spot along the rear edge of the spar flange now
about 1/4" long and maybe 1/8" max depth where I ground it out and
well, it's fixed.
Bill
Bill
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Thu Jan 07, 2010 3:04 pm Post subject: Re: OOPS!! What have I done??? |
Looking at the pics it didn't look too deep. Glad Vans didn't see an issue with it. One suggestion would be to stop drill the gouge if it isn't all buffed out. You don't want a crack to develop which wraps around to the front of the spar.
Eric Kallio
