Can I use this?
Goto page Previous  1, 2
Strasnuts
PostPosted: Fri Jan 08, 2010 8:45 am    Post subject: Can I use this? Reply with quote
My system was deburr, scotch bright, prep-all, prime with HVLP using
variprime.
On Jan 8, 2010, at 8:48, "JHearnsberger" <jakehearnsberger(at)gmail.com>
wrote:
Ok, I give up. I will do it right. I was looking for the easy way
out. Wink
Tell me what all to order. Alumiprep, Alodine, paint sprayer, etc....
Just not the most expensive products. I don't want to break the bank.
http://forums.matronics.com/viewtopic.php?p 80676#280676
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
pitts_pilot(at)bellsouth.
PostPosted: Fri Jan 08, 2010 11:25 am    Post subject: Can I use this? Reply with quote
Also called 'aluminum bright' in hardware stores ..... and
it can be brushed on besides dipping.
Linn
Jack Phillips wrote:
Alumiprep is a phosphoric acid etch. It works best if the parts are cleaned
with a good dishwashing soap and water first, rinsed, then dipped in
Alumiprep for about 3 minutes, then rinsed with cold water. The etched
surface should be primed or alodined within 8 hours.
Jack Phillips
#40610 - Wings
Raleigh, NC
Kelly McMullen
PostPosted: Fri Jan 08, 2010 12:30 pm    Post subject: Can I use this? Reply with quote
You first need to consider your need. Are you near salt water? Other
corrosive atmosphere? If so, maybe alumiprep etch, alodine, 2 part
epoxy primer is appropriate. Especially if you are aiming at 50 year
or more life to your project. If you are like some of us...in
Aridzona, over 60, no heirs gonna get their paws on it, a 20 year life
is plenty and with out corrosive air, the Nappa/Sherwin Williams
self-etching primer in rattle cans, over a clean, lightly scuffed
alclad on metal to metal joints is more than enough priming.
Some certified planes were built with no primer at all on the interior
and only had polished aluminum exterior with a few trim stripes, over
60 years ago and are still flying. So it just depends.
On Fri, Jan 8, 2010 at 8:48 AM, JHearnsberger
<jakehearnsberger(at)gmail.com> wrote:
Ok, I give up. I will do it right. I was looking for the easy way out. Wink
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
indigoonlatigo(at)msn.com
PostPosted: Fri Jan 08, 2010 12:34 pm    Post subject: Can I use this? Reply with quote
Flip your shop upside down and put it on the other side of the world where it is now summer. You wouldn't be able to even go outside for more than a few minutes in their winter.
If you work faster you will generate friction with the air around you C generating heat and you will also finish your project faster than the rest of us.
Subject: RE: Can I use this?
Date: Thu C 7 Jan 2010 14:33:28 -0800
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal C .ExternalClass li.ecxMsoNormal C .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri' C'sans-serif';} .ExternalClass a:link C .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p.ecxMsoPlainText C .ExternalClass li.ecxMsoPlainText C .ExternalClass div.ecxMsoPlainText {margin-bottom:.0001pt;font-size:10.5pt;font-family:Consolas;} .ExternalClass p.ecxMsoAcetate C .ExternalClass li.ecxMsoAcetate C .ExternalClass div.ecxMsoAcetate {margin-bottom:.0001pt;font-size:8.0pt;font-family:'Tahoma' C'sans-serif';} .ExternalClass span.ecxPlainTextChar {font-family:Consolas;} .ExternalClass span.ecxEmailStyle19 {font-family:'Calibri' C'sans-serif';color:windowtext;} .ExternalClass span.ecxBalloonTextChar {font-family:'Tahoma' C'sans-serif';} .ExternalClass .ecxMsoChpDefault {;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
Cold in Maine??
Check out tomorrow’s Houston forecast compared to Base Orcadas C Antarctica.  J
      I don't yet have heat in my shop C but I'm almost finished with
installing a propane heating system.  It is mounted C vented C and wired C
and now I just need to get the propane company out to install the
propane lines and tank C and then check everything.  Hopefully soon!  It
gets slightly chilly here in Maine this time of year...  Wink
-Dj
 Filesize:  15.96 KB
 Viewed:  4172 Time(s)
 Filesize:  17.7 KB
deej(at)deej.net
PostPosted: Fri Jan 08, 2010 12:43 pm    Post subject: Can I use this? Reply with quote
Hi Kelly,
Curious, where did you find these lifetime figures for the different
priming methods? Can you point me at a web page or something? I'd like
to do a little more research into this.
Thanks!
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
pietflyr(at)bellsouth.net
PostPosted: Fri Jan 08, 2010 12:53 pm    Post subject: Can I use this? Reply with quote
I had one of those certified airplanes - a 1947 Cessna 140 which I owned
from 1998 to 2002. No priming of any kind and no corrosion after 55 years
of service, including many years tied down on the North Carolina coast.
Convinced me that primers just add weight and little else. I'm building my
-10 with alodining but no priming. Jonathon Bryant is building his nearby
with every surface primed. As soon as I get my wings built up through the
leading edges riveted to the spars (which is where he is) we will weigh my
wings and his with the same scales to see if the weight savings is
noticeable, and we'll post the results here on the forum.
(We needed a good primer war - haven't had one in a long time) Let the
flames begin!
Jack Phillips #40610
Raleigh, NC
Phil.Perry(at)netapp.com
PostPosted: Fri Jan 08, 2010 1:33 pm    Post subject: Can I use this? Reply with quote
Last night decided that Houston is the best “coat city” in the country. People don’t spend money on coats here, so there’s not a whole lot of fashion when it gets cold.
You see coats coming out of the closet that haven’t seen daylight since 1973. Butterfly collars, sheep skins on the outside and wool on the inside. You name it. One guy reached into his pocket the other day and found a receipt from 1981. (Okay not really, but you get the idea.) J
There are other folks who are wearing coats that fit perfectly when they were 18 years old in Nebraska, but not so well at 42 in south Texas. It’s funnier around here than you can ever imagine.
Just this afternoon, I shut off water to two houses on our street who busted water pipes. I’m sure their owners will be upset when they get home, but hopefully I saved them a little cleanup work and a smaller water bill too.
I might make another drive down the street to see if I can pick up a few more broken pipes.
Phil
From: John Gonzalez [mailto:indigoonlatigo(at)msn.com]
Sent: Friday, January 08, 2010 2:24 PM
To: RV 10 group
If you work faster you will generate friction with the air around you, generating heat and you will also finish your project faster than the rest of us.
Date: Thu, 7 Jan 2010 14:33:28 -0800
Cold in Maine??
Check out tomorrow’s Houston forecast compared to Base Orcadas, Antarctica. J
  I don't yet have heat in my shop, but I'm almost finished with
installing a propane heating system. It is mounted, vented, and wired,
propane lines and tank, and then check everything. Hopefully soon! It
-Dj
 Filesize:  15.96 KB
 Viewed:  4165 Time(s)
 Filesize:  17.7 KB
PostPosted: Fri Jan 08, 2010 1:34 pm    Post subject: Can I use this? Reply with quote
Corrosion-X and ACF-50 are pretty pricey for me. I'm going
to buy a gallon of Boeshield, cut it with a suitable solvent
... which I haven't figured out exactly what that is ....
and spray it in place of the high priced stuff.
Linn
johngoodman wrote:
<johngoodman(at)earthlink.net>
I'm leaving most of the aluminum in shiny Alclad, because
I plan on using Corrosion-X once it's painted & flying.
However, there are always worked over pieces that need
some primer. I use a rattle can of Napa 7220, which is
one of many brands of self-etching primer out there. It
contains MEK, so I wear long sleeve shirts, nitrile
gloves, and a real respirator with ventless goggles. John
-------- #40572 QB. Engine on, wing attach coming soon.
Panel delivery soon. N711JG reserved
http://forums.matronics.com/viewtopic.php?p 80679#280679
Kelly McMullen
PostPosted: Fri Jan 08, 2010 7:13 pm    Post subject: Can I use this? Reply with quote
Based on inspections and maintenance work I've done on aircraft dating
back to the post WWII boom through the mid-70s. Nothing scientific,
just observations. Cessna especially, did almost no interior priming.
Only those aircraft based on the coasts are likely to show corrosion
to any extent. I owned a '53 C170B that lived its early life in Long
Beach where it got some light corrosion. After that nothing changed
over the years I owned it(23) and it currently is registered in OR.
That doesn't mean all aircraft will escape corrosion in that time
frame. I'm just saying that if you are aiming for multiple decades
corrosion free, you want to do full treatment. If on the other hand
you aren't near a coast and only want the plane to last as long as you
have a medical, then no point in wasting time and money on it. It may
last 50 years with no primer...but it may not, especially if it sits
out on the ramp in the weather.
Hi Kelly,
Thanks!
-Dj
Dj Merrill - N1JOV
Kelly McMullen
KCHD
AV8ORJWC
PostPosted: Sat Jan 09, 2010 10:49 am    Post subject: Can I use this? Reply with quote
Having served in Antarctica, I can say you are comparing Apples and Oranges. Houston is in the middle of their Winter and Orcadas is in the middle of a Summer Heat wave. Just wait a month and watch the change.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Friday, January 08, 2010 12:24 PM
To: RV 10 group
Cold in Maine??
-Dj
 Filesize:  15.96 KB
 Viewed:  4153 Time(s)
 Filesize:  17.7 KB
Page 2 of 2
