		lbcopas
				 Posted: Sun Jan 10, 2010 3:39 pm    Post subject: Milk more power from the 532? |
				What's the BIGGEST carb for the 532?   I read about tuned exhaust but such a narrow power band - (usually, where you don't need it) OR, melting pistons or disturbing the neighbors...  How about larger carbs?  .. Which,  Where?  How much?       Tnx,  Larry
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dave
				 Posted: Mon Jan 11, 2010 4:33 am    Post subject: Re: Milk more power from the 532? |
				532 --   don't  bother a larger carb as gains will be minimal if anything.
 your muffler is limiting your power more so than the carb.
 532 work ok stock.
 You want more power get a 912
 or if you want to experiment and get gobs of power but won't be the best cruise machine.......
 do a rotax 670  --  you will get 110 to 130 HP  and climb well over 2000  fpm. you might see close to 3000 fpm if your plane is light enough   WWOOOOOOOOOOOOOOOOW   !!
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Float Flyr
				 Posted: Mon Jan 11, 2010 12:15 pm    Post subject: Milk more power from the 532? |
				I don’t think larger carbs would do the trick… maybe nitrous or supercharging but I wouldn’t want to do either on a two stroke engine.
 Noel
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of larry copas
  Sent: January 10, 2010 7:53 PM
  Subject: Milk more power from the 532?
     	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Kitfox-List  | 	  0123456789
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Pat Reilly
				 Posted: Mon Jan 11, 2010 12:56 pm    Post subject: Milk more power from the 532? |
				Dave, Are there any of those 630 Rotaxes available? I have never seen one for sale. You state "It won't be the best cruise machine". Why? Is it strictly gas burn rate or something else? What does a 630 weigh in comparison to a 582?
  Pat Reilly
  Mod 3 582 Rebuild
  Rockford,IL
  On Mon, Jan 11, 2010 at 6:33 AM, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
  [quote]--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
 532 work ok stock.
 Rotax Dealer, Ontario Canada
 http://www.cfisher.com/
  Awesome *New Forum *
 http://rotaxaircraft.com/forum/
 http://www.youtube.com/profile_videos?user=kitfoxflyer
 http://forums.matronics.com/viewtopic.php?p=280996#280996
  www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
  ronics.com/" target="_blank">http://forums.matronics.com
  Matt Dralle, List Admin.
		dave
				 Posted: Mon Jan 11, 2010 1:40 pm    Post subject: Re: Milk more power from the 532? |
				Pat,  First off it is a 670 Rotax not a 630.
 Weight about the same give or take 5 lbs.
 670 have RAVE vavles which open up the exh. port but not till over 6000 rpm .........  you max HP will start to happen 6500 to  8500  rpm. with a decent pipe.  You have to mod the crankcase and cut the PTO of crank a bit shorters and make a smaller morse taper in to to fit the Rotax gear box.
 Fuel burn at wide open throttle  will go from 7 gal a hour to 11 to 15 gal hour. HP come s at a price  .
 quote="Pat Reilly"]Dave, Are there any of those 630 Rotaxes available? I have never seen one for sale.�You state "It won't be the best cruise machine". Why? Is it strictly gas burn rate or something else? What does a 630 weigh in comparison to a 582?
  Pat Reilly
  Mod 3 582 Rebuild
  Rockford,IL
  On Mon, Jan 11, 2010 at 6:33 AM, dave <dave> wrote:
   	  | Quote: | 	 		  --> Kitfox-List message posted by: "dave" <dave>
 532 -- � don't �bother a larger carb as gains will be minimal if anything.
 532 work ok stock.
  do a rotax 670 �-- �you will get 110 to 130 HP �and climb well over 2000 �fpm. you might see close to 3000 fpm if your plane is light enough � WWOOOOOOOOOOOOOOOOW � !!
 Realtime Kitfox movies to separate �the internet �chatter from the truth
 [b] |
		Pat Reilly
				 Posted: Mon Jan 11, 2010 2:07 pm    Post subject: Milk more power from the 532? |
				Dave, Thanks for quick reply. I realized after I sent the message it was a 670. Sounds like there are other issues with, retro fitting the crankcase, PTO, HP and torque not available until higher RPM, narrow power band, that make the engine less than desireable for our application.
  Pat Reilly
  On Mon, Jan 11, 2010 at 3:40 PM, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
  Pat Reilly
  Mod 3 582 Rebuild
  Rockford,IL
  	  | Quote: | 	 		   your muffler is limiting your power more so than the carb.
  532 work ok stock.
  	  | Quote: | 	 		    Matt Dralle, List Admin.
 http://forums.matronics.com/viewtopic.php?p=281087#281087
  bscription,
  ://www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
   href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
                     -Matt Dralle, List Admin.
		Float Flyr
				 Posted: Mon Jan 11, 2010 3:03 pm    Post subject: Milk more power from the 532? |
				Will a C or E box handle that kind of power?
 Noel
Kitfox III-A
		larry huntley
				 Posted: Mon Jan 11, 2010 4:25 pm    Post subject: Milk more power from the 532? |
				How about a Swiss muffler?   Larry
  _________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
		Float Flyr
				 Posted: Mon Jan 11, 2010 6:04 pm    Post subject: Milk more power from the 532? |
				Will a Rotax box take that kind of horsepower?
 Noel
Kitfox III-A
		dave
				 Posted: Tue Jan 12, 2010 2:51 am    Post subject: Re: Milk more power from the 532? |
				 	  | Float Flyr wrote: | 	 		  Will a Rotax box take that kind of horsepower?
 Noel
 sure , but use a c or E box
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
		Pat Reilly
				 Posted: Tue Jan 12, 2010 2:54 pm    Post subject: Milk more power from the 532? |
				Tom, Thanks for the Rotax 670 add. I don't need one at the moment, but am noting the shop offering it. It appears they specialize in Rotax.
  Pat Reilly
  Mod 3 582 Rebuild
  Rockford, IL
  On Tue, Jan 12, 2010 at 7:49 AM, Tom Jones <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)> wrote:
  [quote]--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
 670 Rotax
 http://www.barnstormers.com/classified_394349_KING+KONG+670+ROTAX+DUAL+IGN..html
  Tom Jones
 Classic IV
 Ellensburg, WA
 http://forums.matronics.com/viewtopic.php?p=281156#281156
  ist Un/Subscription,
		lbcopas
				 Posted: Wed Jan 13, 2010 12:00 pm    Post subject: Re: Milk more power from the 532? |
				OK Guys,  I'm beginning to see a pattern, here.  I'll just leave her the way she is. I guess I spoiled myself with a mod3 w/912.  The older mod2 with the 532 seemed a bit puny and I was hoping for a cheap, easy way to boost  it's performance.  But,  you're right, she flys just fine the way she is.  I do think that I'll look into VGs for both of 'em, though.  Thanks a lot, guys.  I've learned a lot in the past few days.  Adios for now,  larry
