		Deems Davis
				 Posted: Wed Jan 13, 2010 5:22 pm    Post subject: Uneven tire wear and brake pad separation |
				I've been watching the tire wear, and after 110 hrs, the left( pilot)
 side tire is showing extreme wear on the outside of the tire, the Right
 is also showing wear on the outside, but not as extreme.
 What have others experienced?
 So today, I pulled the wheels off and reversed the tires and tubes to
 try and get some more wear out of the tires. When pulling the left tire
 off the axel, the brake lining for the inboard brake pad dropped to the
 floor! It appears that the shoulder that is supposed to hold the rivet
 liner to the pad let go, and the rivet heads were "floating" inside of
 the countersunk area. Fortunately there is minimal brake wear, and
 therefore little movement in the brake when activated. But, if the brake
 wear had been greater, there's a possibility that the pad/liner would
 have moved and jammed it self against the brake disc. If this had
 happened on landing and braking, I wouldn't have wanted to be along for
 that ride. Checking with the locals this is a problem that one person
 has seen when the rivets holding the liners are set too tight. since
 these were the parts that came with the kit from Cleveland, I would
 expect  that they should have some quality control in their mfg to
 eliminate/minimize this. Upon inspection and comparison  with the
 inboard rivets to the outboard .liner rivets, it appears that  they are
 'deeper' into the countersunk area , and possibly the  shoulder of the
 brake material that holds them  was thinner and possibly weaker. Anyway
 replacement pads on on there way. Something to keep in mind when you do
 your conditionals or change tires.
 Deems Davis
 N519PJ
 www.deemsrv10.com
		partner14
				 Posted: Wed Jan 13, 2010 5:52 pm    Post subject: Uneven tire wear and brake pad separation |
				Deems, You did better than I did.... I switched mine at 90 hours... and the pilot side was worse than the other side.  At the same time I installed air stop tubes.  Guess It's getting time to get an order together for tires.  Brakes looked good.
  Which pads did you order?
  Any word on the Alaska trip you hinted about?
  Weather here in the SAC area has been terrible... at least for flying.  Just enough overcast/fog to keep you on the ground.  Going up tomorrow though.
  Don McDonald
 --- On Wed, 1/13/10, Deems Davis <deemsdavis(at)cox.net> wrote:
 Subject: Uneven tire wear and brake pad separation
 Date: Wednesday, January 13, 2010, 5:14 PM
  --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
 I've been watching the tire wear, and after 110 hrs, the left( pilot) side tire is showing extreme wear on the outside of the tire, the Right is also showing wear on the outside, but not as extreme.
 So today, I pulled the wheels off and reversed the tires and tubes to try and get some more wear out of the tires. When pulling the left tire off the axel, the brake lining for the inboard brake pad dropped to the floor! It appears that the shoulder that is supposed to hold the rivet liner to the pad let go, and the rivet heads were "floating" inside of the countersunk area. Fortunately there is minimal brake wear, and therefore little movement in the brake when activated. But, if the brake wear had  been greater, there's a possibility that the pad/liner would have moved and jammed it self against the brake disc. If this had happened on landing and braking, I wouldn't have wanted to be along for that ride. Checking with the locals this is a problem that one person has seen when the rivets holding the liners are set too tight. since these were the parts that came with the kit from Cleveland, I would expect  that they should have some quality control in their mfg to eliminate/minimize this. Upon inspection and comparison  with the inboard rivets to the outboard .liner rivets, it appears that  they are 'deeper' into the countersunk area , and possibly the  shoulder of the brake material that holds them  was thinner and possibly weaker. Anyway replacement pads on on there way. Something to keep in mind when you do your conditionals or change tires.
 Deems atronics.com/Navigator?RV10-List" target=_blank>http://www.matronics.com/=               - MATRONICS cs.com/" ;               -Matt Dralle, List Admin==========
40636 |
		ricksked(at)cox.net Guest
		jcumins(at)jcis.net Guest
				 Posted: Wed Jan 13, 2010 6:19 pm    Post subject: Uneven tire wear and brake pad separation |
				John G. Cumins
 President
 JC'S Interactive Systems
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576 Fax
 Your Total Technology Solution Provider
				 Posted: Wed Jan 13, 2010 6:22 pm    Post subject: Uneven tire wear and brake pad separation |
				Rick
 It is not that you need to loose weight cause if that was the issue the wear
 would be in the inside on the outside.  Outside wear is very common on
 spring steel gear give it time and it might get better as the gear gets more
 wear and tare on it.  Either that Vans needs to correct the axel angle on
 the gear leg it self.
 John G. Cumins
 President
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576 Fax
				 Posted: Wed Jan 13, 2010 6:40 pm    Post subject: Uneven tire wear and brake pad separation |
				Not my issue!!!! Ken Scott or aka...the ego deflator..told me that...not
 really...just thought it was funny that both Deems and I had tire wear on
 the left more than the right...you still coming in on the 20th?
 Rick
		dlm46007(at)cox.net Guest
				 Posted: Wed Jan 13, 2010 6:53 pm    Post subject: Uneven tire wear and brake pad separation |
				air stop tubes came with the kit.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don  McDonald
 Sent: Wednesday, January 13, 2010 6:52 PM
 To:  rv10-list(at)matronics.com
 Subject: Re: Uneven tire wear and  brake pad separation
        Don McDonald
				 Posted: Thu Jan 14, 2010 6:28 am    Post subject: Uneven tire wear and brake pad separation |
				After 750 hours our tires still wear on the outside.  The tires sit fairly straight when on the ground, but most of the wear comes from the little squeek when the tires go from 0-60kts at touchdown.  When flying, the outside of the tire is lower than the inside.  The more landings you do, the more your tires will wear.  We just got about 150+ hours on the outside and just rotated them to the inside.  The nose tire was just replaced.  How have people been seeing the wear on the nose?  It should be much less than the mains, or course, unless you get a bad shimmy, but I don't remember if we have changed that before or not.  I'd have to go back and check through the logs.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Jan 13, 2010, at 9:19 PM, John Cumins wrote:
  Rick
  John G. Cumins
  President
  2499 B1 Martin Rd
  Fairfield Ca 94533
  707-425-7100
  707-425-7576 Fax
		msausen
				 Posted: Thu Jan 14, 2010 7:43 am    Post subject: Uneven tire wear and brake pad separation |
				Too bad Deems is flying, maybe he could come up with a way to pre-accelerate the tires to landing speed for smoother landings with less tire wear.  Heh.
		Deems Davis
				 Posted: Thu Jan 14, 2010 8:44 am    Post subject: Uneven tire wear and brake pad separation |
				Thanks all for the feedback re tires. It appears that uneven outside
 wear is the 'norm'. I wonder if we're all landing left wheel 1st? Or if
 Van's has a slight error in the gear weldment? I reject Rick's
 hypothesis regarding 'unequal weight distribution'    .  I've got em
 flipped and will watch closer for the next period. I've also had a
 couple of positive recommendations for retreads for future replacements.
 I haven't worked on Alaska, my hangar neighbor from AK just returned, so
 I'll have to ping him.
 I don't want to make everyone green, but it's 70 deg and CAVU here in
 PHX.
 Deems Davis
 N519PJ
 www.deemsrv10.com
 Don McDonald wrote:
  	  | Quote: | 	 		   Deems, You did better than I did.... I switched mine at 90 hours...
  tomorrow though.
  Don McDonald
      <http://us.mc537.mail.yahoo.com/mc/compose?to=deemsdavis(at)cox.net>>
      extreme.
      change tires.
		gengrumpy(at)aol.com Guest
				 Posted: Thu Jan 14, 2010 8:50 am    Post subject: Uneven tire wear and brake pad separation |
				I rotate inner to outer one annual condition inspection, then exchange
 left & right next annual and repeat inner to outer at the next one.
 Turn nose wheel around each annual.
 Works ok to keep all wear about equal.
 Remember on inner to outer, be careful and dust up the tube well and
 partially inflate it to keep from pinching the tube (learned that one
 the hard way.....)
 grumpy
 On Jan 14, 2010, at 10:43 AM, Deems Davis wrote:
  if Van's has a slight error in the gear weldment? I reject Rick's
  em flipped and will watch closer for the next period. I've also had
  a couple of positive recommendations for retreads for future
  replacements.
  returned, so I'll have to ping him.
  in PHX.
  Deems Davis
  N519PJ
  www.deemsrv10.com
 > up tomorrow though.
 > Don McDonald
 >    From: Deems Davis <deemsdavis(at)cox.net>
 >    extreme.
 >    change tires.
		AV8ORJWC
				 Posted: Thu Jan 14, 2010 10:21 am    Post subject: Uneven tire wear and brake pad separation |
				Some pilots have better CG than other skinny pilots.  The manufacturing
 error built into the gear leg, now that is something for Ken Scott to
 wax on incessantly.
 John
		Bob Turner
				 Posted: Thu Jan 14, 2010 11:07 am    Post subject: Re: Uneven tire wear and brake pad separation |
				Which way does the wind blow at your home airport? e.g., do you do more landings with a crosswind from the left, than from the right? Also, where is your hangar with respect to the usual runway? Are you making mostly left turns?
 As others have noted, wear on the outside of the tires is due to the spring gear leg,which hangs low prior to touchdown. See the same thing with spring gear Cessnas.
  _________________ Bob Turner
RV-10 QB |
				 Posted: Thu Jan 14, 2010 12:48 pm    Post subject: Uneven tire wear and brake pad separation |
				Rick
 Yep I sure am will arrive about noon so I have the 20 and 21 afternoons
 free.  Shoot me a e-mail off list and we can get together on of those
 afternoons.
 John
		partner14
				 Posted: Thu Jan 14, 2010 5:39 pm    Post subject: Uneven tire wear and brake pad separation |
				If we actually think about it.... if the gear were perfectly straight, we would simply wear out the center of the tire.... and then we're done.  The way it is now, we wear out mostly a part of the tire that would never get used, and then we get to turn them around and it's a brand new part of the tire again.  What the hell are we bitching about!
  Don McDonald
 --- On Thu, 1/14/10, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
 Date: Thursday, January 14, 2010, 11:08 AM
  --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
 Bob Turner
 RV-10 QB
 http://forums.matronics.com/viewtopic.php?p=281509#28150om/Navigator?RV10-List" target=_blank>http://www.matronics.com/Navigator?              - MATRONICS WEB FORUM;               -Matt Dralle, List Admin==========
40636 |
