colin.dix(at)bailey-steam Guest
Posted: Thu Jan 14, 2010 7:55 am Post subject: Airspeed Indicator reading low, |
Hello Kitfox List,
I have been following your discussions for a while. I wonder if you can help please. I have a half share in a M44-1200 - Rotax 912. G-BXWH based in the UK.
We have aproblem with the airspeed indicator reading about 10 MPH low, and the Rate of Climb meter is reading low as well. I'm told we have the same arrangment that others have that works correctly. Any ideas where to look for a cure for both please? BODY { font-family:Arial, Helvetica, sans-serif;font-size:12px; }
Colin
Colin Dix
Bailey Engineering & Design Ltd
Linden Lea, Bailey Lane End, Ross-on-Wye,
Herefordshire, HR9 5TR. UK.
2D Design using AutoCAD,
3D Design using Pro-Engineer Wildfire 2,
3D Design using Solidworks
Precision Engineering & Development.
T: +44 (0) 1989 750420
F: +44 (0) 1989 750420
M: +44 (0) 7776 153423
E-mail: colin.dix(at)bailey-steam.com
Web: http://www.bailey-steam.com
The information contained in this e-mail is intended for the named recipient(s) only. It may contain privileged and
confidential information, if you are not an intended recipient(s) you must not copy, distribute or take any action on it. If
you have received this e-mail in error please advise the Sender immediately. Thank you.
If this e-mail has any drawing files attached, it should be noted that we can not ensure the compatibility of the data
with your software. The electronic copy(s) of the drawing(s) is supplied for your information only and should always
be checked against a posted hard copy. Bailey Engineering and Design Ltd will not accept liability arising
from any purpose for which it may be used.
Guy Buchanan
Posted: Thu Jan 14, 2010 9:55 am Post subject: Airspeed Indicator reading low, |
At 07:48 AM 1/14/2010, you wrote
| Quote: | We have aproblem with the airspeed indicator reading about 10 MPH
Colin,
Check for leaks. I did the trick of putting a 10cm piece of
sealed tube on the pitot and then carefully kinking it while watching
the ASI. (Don't want to over speed it.) Once kinked, hold it in place
with a rubber band or tie wrap and wait to see if the airspeed
decays. If so you've got a leak in the pitot system. My leak was
between the bezel and glass.
Do the same with the static system, except start with a
kinked hose and let it un-kink after sealing it to the static system.
Once you've confirmed no leaks then question the location of
the static port. My system ran 10mph low using the "same arrangement"
as well so I just disconnected the static port and ran it at cabin
pressure: much closer.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
Dorsal
Posted: Fri Jan 15, 2010 7:26 am Post subject: Re: Airspeed Indicator reading low, |
Given both airspeed and rate of climb are off in the same direction I believe this points to a static port problem. If my assumption is correct it is not a leak but a a small amount of additional pressure at the static port location, disconnecting and running at cabin pressure , as Guy suggested,may help.
_________________ Dorsal ~~^~~
Series 7 Flying
912S Warp Drive |
dave
Posted: Fri Jan 15, 2010 9:21 am Post subject: Re: Airspeed Indicator reading low, |
some of the Kitofx ASI are notorious for readings........
mine read low --stalls at 27 (some think that is right ? NOPE)
MIne cruises at 105 mph -wrong again about 90 to 92 ..........
I have inside static port ...........
try opening door and see what happens
then stick arm out door and what ASI
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
