Intercom Shields
PaulR
PostPosted: Thu Jan 14, 2010 11:09 am    Post subject: Intercom Shields Reply with quote
I'm working on wiring the 25 pin Dsub for a PSE intercom and trying to understand shields. PSE wants all the headset and mic wires shielded which I've done and they are to only be connected together at the intercom end. My question is, is it okay to stop these shields an inch or so before getting to the backshell on the DB25? Will this work okay and not introduce a bunch of noise? I just can't see anyway to continue the shielding into the backshell and then back out to join the ground connector to run them all together. I've made a 25 pin ground bus per Bob's directions.
Intercom is PM 3000
Paul Rose
N417PR
RV-9A
PostPosted: Thu Jan 14, 2010 5:05 pm    Post subject: Intercom Shields Reply with quote
You can stop them 5" with virtually zero risk of noise.
See:
http://www.aeroelectric.com/articles/pigtail/pigtail.html
PaulR
PostPosted: Fri Jan 15, 2010 5:52 am    Post subject: Re: Intercom Shields Reply with quote
Thanks Bob, I had already looked at the pigtail detail, but the connections didn't seem to be working that way. As long as I can stop them just short of the housing for the connector, it will be fine.
Paul Rose
N417PR
RV-9A
PostPosted: Fri Jan 15, 2010 5:43 pm    Post subject: Intercom Shields Reply with quote
Don't make them TOO short . . . or all the
same distance outside the housing . Stagger
'em so they don't make a big lump.
