GrummanDude
Posted: Sun Jan 10, 2010 12:15 pm Post subject: Cowling Update |
I began the installation of the second cowling yesterday. This is going on Martin's plane. It's in for an annual and cowling. Martin put a deposit down about a year ago.
The initial fitting of the cowling is already done. I have a spare fuselage that I use for fitting. Today, I'm going to be sanding and detailing the surface. I've already noticed that the distance used in the joggle at the forward end (where the upper cowling attaches) is about .030 to low. The tooling will get some fine tuning. I'm taking a lot of pictures.
"Is the cost worth it?" Martin asked. Depends.
From a maintenance stand point, yes. It's a LOT easier to R&R the new cowling than the old one.
From a checking the oil point of view, no. Five cam-locks and a screw need to be removed vs opening a door.
From a speed point of view, likely. Jeff is showing a consistent 5 to 6 knots improvement at the same power settings.
From a CHT point of view, probably. Jeff is showing a much improved temp distribution and 15 degrees lower temps.
From a fuel efficiency point of view, possibly. I've flown my plane next to four different Tigers at the same speed and 2700 rpm. At the same speed and roughly the same rpm (they flew 2700 rpm, mine varied), my fuel burn was anywhere between .5 gph and 3 gph less than the other plane. Is that all the cowling? or something else? My plane doesn't have any junk hanging off it like most planes. So, it's possible that the other planes are just draggy anyway.
----- I flew alongside a very clean 75 Traveler. This Traveler would true at about 135 knots under most conditions. At 132 knots true, my fuel flow was about 2 gph less. My fuel burn was 7.5 gph.
Plus, it's not just the cowling but all new baffles and baffle seals.
| | - The Matronics TeamGrumman-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?TeamGrumman-List |
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
GrummanDude
Posted: Fri Jan 15, 2010 8:11 pm Post subject: Cowling update |
I found something during this current installation that will require a change to the installation instructions.
a B&C starter won't fit. They are too big. SOOOOOO
Is there anyone out there in Team Grumman-land that wants a B&C starter?
Do you think there might be someone on the 'other' gang that wants one? send them my way. I need to order the Sky-Tec.
Gary
AuCountry Aviation
Discover
Posted: Fri Jan 15, 2010 9:06 pm Post subject: Cowling update |
I didn't think that B&C starters were approved for installation on certified AC. Only by individual FSDO approvals. Therefore you should not expect to see very many of them.....
On Jan 15, 2010, at 9:36 PM, teamgrumman(at)aol.com (teamgrumman(at)aol.com) wrote:
[quote]I found something during this current installation that will require a change to the installation instructions.
Gary
Discover
This would be the place to get it sold quickly
http://www.vansairforce.com/community/forumdisplay.php?f=3
Gary
GrummanDude
Posted: Fri Jan 15, 2010 10:56 pm Post subject: Cowling update |
i'll try it
AuCountry Aviation
flyv35b(at)minetfiber.com Guest
Posted: Sat Jan 16, 2010 6:46 am Post subject: Cowling update |
I think they were STC'd but I'm not sure about that.
Cliff
Posted: Sat Jan 16, 2010 6:48 am Post subject: Cowling update |
Go with the 149-NL Sky-Tec, is a much better starter than the 149-12LS.
Cliff
Discover
Posted: Sat Jan 16, 2010 8:37 am Post subject: Cowling update |
Cliff,
You're right. The starters are STCd and PMAd. I ws thinking of their alternators which are fir experimentals only. So Gary you may see mire of these starters
Her is a link to the starters
http://www.bandc.biz/lycomingstarter12v122ringgearteethstcpma.aspx
Ned
On Jan 16, 2010, at 8:44 AM, "flyv35b" <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)> wrote:
[quote] I think they were STC'd but I'm not sure about that.
Cliff
Discover
Posted: Sat Jan 16, 2010 8:42 am Post subject: Cowling update |
Keep in mind that the NL is 1.15 lbs heavier right out on the nose of the plane. Not good for those of us the like to maximize speed
I've had excellent performance from the PM starters
Ned
On Jan 16, 2010, at 8:46 AM, "flyv35b" <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)> wrote:
| Quote: | Go with the 149-NL Sky-Tec, is a much better starter than the 149-12LS.
[/b] |
Posted: Sat Jan 16, 2010 9:09 am Post subject: Cowling update |
I would gladly sacrifice the extra weight for the better quality based on what I have seen concerning problems with customers starters.
Cliff
Posted: Sat Jan 16, 2010 9:11 am Post subject: Cowling update |
Actually I have a 20 amp STC'd standby B&C alternator on my Bonanza. It's a beautiful installation with it's own ACU and over amperage warning light.
Cliff
Discover
Posted: Sat Jan 16, 2010 9:23 am Post subject: Cowling update |
I own quite a few things from BandC and also Bob Knuckols. The quality
is outstanding.
GrummanDude
Posted: Sat Jan 16, 2010 8:40 pm Post subject: Cowling update |
Ned, I'd have to sign up to post the starter for sale. I really have no interest in joining another group. If you want to post on the RV list for me, that would be great. Just give them my cell number. Phone number. Not the number of my cell.
AuCountry Aviation
GrummanDude
Posted: Sat Jan 16, 2010 8:43 pm Post subject: Cowling update |
I have the 149-12NL in my plane. I know that one fits.
AuCountry Aviation
allenc3(at)bellsouth.net Guest
Posted: Sat Jan 16, 2010 8:58 pm Post subject: Cowling update |
Just post it on Barnstormers. It is free and a B&C starter will sell in a New York Minute.....
Claude
From: teamgrumman(at)aol.com (teamgrumman(at)aol.com)
Sent: Saturday, January 16, 2010 11:39 PM
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Subject: Re: Cowling update
-----Original Message-----
Sent: Fri, Jan 15, 2010 10:55 pm
i'll try it
From: Ned Thomas <923te(at)att.net (923te(at)att.net)>
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com) <teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)>
Sent: Fri, Jan 15, 2010 9:04 pm
| Quote: | I found something during this current installation that will require a change to the installation instructions.
Gary
From: WILLIAM KELLY <v1rotate(at)verizon.net (v1rotate(at)verizon.net)>
To: (teamgrumman-list(at)matronics.com)teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Sent: Fri, Jan 15, 2010 1:35 pm
Subject: Re: Garmin 430 background lighting
I forget how I adjusted the brightness initially, but I found it too bright day or night, so I leave a couple of layers of masking tape bits over the electronic eye on the upper left. Not much for looks, but it works. You might not think it would matter at night, but even the random instrument panel light seems to affect the brightness of the 430 screen. If I recall my past experiences correctly there does not seem to be any one unit setting that works suitably for both day and night. Agreed, a dimmer knob would be great.
Bill
| Quote: | | I did a long night flight last night and the brightness of the 430s (2 of them) was overwhelming in the darkness. I left one on and restarted |
ator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List
ttp://forums.matronics.com
ibution">http://www.matronics.com/contribution
href="http://www.matronics.com/Navigator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List
Discover
Posted: Sun Jan 17, 2010 8:29 am Post subject: Cowling update |
How much are you asking? It would be good to post with a price.
And confirm the telephone number or would you just as soon have your this email address posted?
GrummanDude
Posted: Sun Jan 17, 2010 11:30 am Post subject: Cowling update |
Ned,
According to the log books, the starter has about 400 hours on it in 2 1/2 years. The guy puts a lot of hours on his plane. It isn't on the ground much.
From the looks of the B&C website, the starter costs $580. Half of that is $290. Let's say $250. It looks new. Ned, I think you should buy it for your project. $250 including shipping.
You have my number.
Gary
AuCountry Aviation
Discover
Posted: Sun Jan 17, 2010 11:56 am Post subject: Cowling update |
Thanks Gary but I already have a new starter on the 540
I placed the ad on Vans
On Jan 17, 2010, at 1:29 PM, teamgrumman(at)AOL.COM (teamgrumman(at)AOL.COM) wrote:
[quote] Ned,
You have my number.
Gary
