				 Posted: Sat Jan 16, 2010 4:29 pm    Post subject: SB 10, VERY IMPORTANT! |
				I said this a long time ago. Perhaps this is a known C but until the building instructions explicitly say to notch out both side of the door gear box C there is no way to make the pin length long enough to get the travel distance which is necessary for safe door latching. The pictures I shared earlier in the day showed my pins 1/4"-1/2" PAST THE EXTRA 1/8" ALUMINUM PLATE WHICH IS SECURED TO THE DOOR FRAME. Subtract the thichness of this plate and the pin would be almost 3/4" past the aluminum door frame. Also C BY HAVING THE PIN TRAVEL SO LARGE C THERE IS NO WAY THE INTERIOR DOOR HANDLE COULD BE IN THE CLOSED POSITION AND THE DOOR NOT COMPLETELY OUT OF WACK IF THE PINS WERE NOT IN THEIR RECEIVERS.
 The plastic guide blocks are only guides and they are plastic so they don't damage the points on the pins. They were never intended for structural use
