etandrews(at)westnet.com. Guest
Posted: Sat Jan 16, 2010 11:09 pm Post subject: Crack to nose wheel fairing bracket |
Everyone,
I have found a crack on my front nose wheel fairing bracket. I suspect that
the crack has developed because the bracket has not been centrally aligned
on the wheel bolt and thus the lower section of the bracket was not
supported as well (please see attached photo). This may be something that
you want to check for when next pumping up the nose wheel.
Evan Andrews
40379 Flying 100hrs
(Brisbane)
E-mail message checked by Spyware Doctor (6.1.0.447)
Database version: 6.14140
http://www.pctools.com/en/spyware-doctor-antivirus/
140.94 KB |
2871 Time(s) |
partner14
Posted: Sun Jan 17, 2010 12:25 am Post subject: Crack to nose wheel fairing bracket |
Larger diameter washer would have probably helped spread the load.... did you balance your wheel pants?
Don McDonald
--- On Sat, 1/16/10, Evan & Tania <etandrews(at)westnet.com.au> wrote:
Subject: Crack to nose wheel fairing bracket
Date: Saturday, January 16, 2010, 11:07 PM
Everyone,
Evan Andrews
40379 Flying 100hrs
(Brisbane)
40636 |
Posted: Sun Jan 17, 2010 7:50 am Post subject: Crack to nose wheel fairing bracket |
When you speak of balancing the wheel faring C what do you consider the balance point.
The brackets are tied into the faring in eight places. The Bracket is anchored to the wheel fork in four places. Does one use the mean distance between the two achor points that go into the wheel fork or would one use the mean distance between the bracket connections into the fiberglass faring???
Please explain the logic.
Thanks C
JOhn G.
Date: Sun C 17 Jan 2010 00:15:20 -0800
Subject: Re: Crack to nose wheel fairing bracket
Don McDonald
--- On Sat C 1/16/10 C Evan & Tania <etandrews(at)westnet.com.au> wrote:
Date: Saturday C January 16 C 2010 C 11:07 PM
Everyone C
Evan Andrews
40379 Flying 100hrs
(Brisbane)
/www.matronics.com/Navigator?RV10-List
.com
tronics.com/contribution
