Wing skin question
william(at)gbta.net
PostPosted: Sat Jan 16, 2010 3:58 pm    Post subject: Wing skin question Reply with quote
Page 16-2 step 5. Wing skin joint detail. I kinda understand what it's asking me to do but does anybody have any pics of exactly what it wants. How is the best way to accomplish this job?
Thanks in advance,
Bill
ricksked(at)cox.net
PostPosted: Sun Jan 17, 2010 7:44 am    Post subject: Wing skin question Reply with quote
Bill,
Are you talking about feathering the edges on the overlap? If so, I used a belt sander and finished it up with a vixen file. Sorry don’t have the plans in front to reference the page.
Rick
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami Britton
Sent: Saturday, January 16, 2010 3:56 PM
Subject: Wing skin question
Thanks in advance,
Bill
william(at)gbta.net
PostPosted: Sun Jan 17, 2010 7:51 am    Post subject: Wing skin question Reply with quote
That’s exactly what I''m asking about. Is it a slow process or does the metal come off pretty quickly. I have a belt sander but I know how fast you can mess things up with it. It's looking like I'll probably just use a hand powered sander and see how that goes.
Thanks to all that have replied.
Bill
Sent: Sunday, January 17, 2010 9:42 AM
Subject: RE: Wing skin question
Bill,
Rick
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami Britton
Thanks in advance,
Bill
0 [quote][b]
Strasnuts
PostPosted: Sun Jan 17, 2010 9:04 am    Post subject: Wing skin question Reply with quote
I set the two pieces close to the end of the table and drew a reference line and used a 6 inch DA sander. Worked well and didn't take too much too fast.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Kellym
PostPosted: Sun Jan 17, 2010 1:41 pm    Post subject: Wing skin question Reply with quote
Are folks sanding the two mating surfaces, or the top, exposed surface? The plans seem to imply sanding the outer, exposed surfaces. I think I would prefer sanding the mating surfaces, then prime them.
Seano wrote: [quote] (at)font-face { font-family: Cambria Math; } (at)font-face { font-family: Calibri; } (at)font-face { font-family: Tahoma; } (at)font-face { font-family: Consolas; } (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } LI.MsoNormal { MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } DIV.MsoNormal { MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } PRE { MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New"; FONT-SIZE: 10pt; mso-style-priority: 99; mso-style-link: "HTML Preformatted Char" } SPAN.HTMLPreformattedChar { FONT-FAMILY: Consolas; mso-style-priority: 99; mso-style-link: "HTML Preformatted"; mso-style-name: "HTML Preformatted Char" } SPAN.EmailStyle19 { FONT-FAMILY: "Calibri","sans-serif"; COLOR: #1f497d; mso-style-type: personal-reply } .MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.Section1 { page: Section1 } I set the two pieces close to the end of the table and drew a reference line and used a 6 inch DA sander. Worked well and didn't take too much too fast.
Kelly McMullen
KCHD
john(at)trollingers.com
PostPosted: Sun Jan 17, 2010 2:27 pm    Post subject: Wing skin question Reply with quote
i just skipped the step and the wing still looks great
On Sun, Jan 17, 2010 at 4:38 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote] Are folks sanding the two mating surfaces, or the top, exposed surface? The plans seem to imply sanding the outer, exposed surfaces. I think I would prefer sanding the mating surfaces, then prime them.
tp://forums.matronics.com
dlm46007(at)cox.net
PostPosted: Sun Jan 17, 2010 2:42 pm    Post subject: Wing skin question Reply with quote
I may be misunderstanding the question, but , in general, when mating two skin sections, for example at the forward spar, a small gap (.020) between the skins must be allowed. When riveting the skins the riveting process will close he gap. If no gap is there the edges of the skins will form a ridge that is visible by looking down the seam. The ridge can easily be felt by running fingers along or across the seam. Ridges are poor sheet metal form.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Trollinger
Sent: Sunday, January 17, 2010 3:25 PM
Subject: Re: Wing skin question
davidsoutpost(at)comcast.
PostPosted: Sun Jan 17, 2010 7:18 pm    Post subject: Wing skin question Reply with quote
My plans stated this was an "optional step". I elected to skip it and my wings look just fine.
David Clifford
RV-10 In Progress
Empennage Done
Engine Overhauled & Pickled
Closing up The Wings
jrlark
PostPosted: Sun Jan 17, 2010 7:35 pm    Post subject: Wing skin question Reply with quote
Bill
Get yourself a 5" random orbital sander to do the feathering of that edge. I have a lot of experience using them for woodworking projects and they are an excellent sander, easy to control and won't give you a nasty surprise. I wouldn't go near a belt sander with aluminum for anything....Rick
MauleDriver(at)nc.rr.com
PostPosted: Mon Jan 18, 2010 5:34 am    Post subject: Wing skin question Reply with quote
Rick and Sandra Lark wrote:
Bill
anything....Rick
That sounds right. I'll have to get one of those. I'm guessing it
would work well on some of the fiberglass finishing (?).
I used a sanding disk on my die grinder for the skin. It worked but was
clearly the wrong tool for the job.
Bill Watson
Jim Berry
PostPosted: Mon Jan 18, 2010 9:46 am    Post subject: Re: Wing skin question Reply with quote
Bill,
A dual action sander works even better than a random orbit sander for finishing fiberglass. A cheapie from Harbor Freight will do the job, or you can get a high dollar dual action form your local auto body supplier.
Jim Berry
40482
N15JB
