Wing Plans Page 23-5 Step 3
Kelly McMullen
PostPosted: Mon Jan 18, 2010 7:55 pm    Post subject: Wing Plans Page 23-5 Step 3 Reply with quote
Calls for inserting WD-1014C into the WD-1014 torque tube assemblies.
No where can I find dimension for WD-1014C, nor where the plans call
for fabricating same. My parts list shows the 4130 tubing needed, says
the one length is to make the 2 WD-1014C tubes needed. What am I
missing?
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Strasnuts
PostPosted: Mon Jan 18, 2010 8:07 pm    Post subject: Wing Plans Page 23-5 Step 3 Reply with quote
If I remember right you make two of them out of the steel tube sent in the
kit. Mine were not labelled and it took me time to measure all the parts to
make sure I was cutting the right tube into two parts.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
John Kirkland
PostPosted: Mon Jan 18, 2010 8:12 pm    Post subject: Re: Wing Plans Page 23-5 Step 3 Reply with quote
I'm at the same spot, cut it exactly in half.
RV-10 #40333
N540XP (reserved)
Kellym
PostPosted: Mon Jan 18, 2010 8:45 pm    Post subject: Wing Plans Page 23-5 Step 3 Reply with quote
I have the correct tube identified, but don't see where it says to cut
in half or any other dimension.
RV-10 #40333
N540XP (reserved)
http://forums.matronics.com/viewtopic.php?p 82180#282180
Kelly McMullen
KCHD
john(at)trollingers.com
PostPosted: Tue Jan 19, 2010 4:57 am    Post subject: Wing Plans Page 23-5 Step 3 Reply with quote
just cut it in half, the dimensions of the whole thing are on the next page or so.  you do not have to be very exact as yhere is plenty of play when you put it all together
On Mon, Jan 18, 2010 at 11:44 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote]--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
I have the correct tube identified, but don't see where it says to cut in half or any other dimension.
--> RV10-List message posted by: "John Kirkland" <jskirkland(at)webpipe.net (jskirkland(at)webpipe.net)>
RV-10 #40333
N540XP (reserved)
http://forums.matronics.com/viewtopic.php?p=282180#282180
le, List Admin.
