frank.goodnight(at)att.ne Guest
Posted: Mon Jan 18, 2010 1:44 am Post subject: flight plans |
Hi all Kolbers,
As i am still gearing up for, and trying to learn about my first long
X country, I have a question for you that choose to fly long X
countrys over lightly populated
areas with sometimes rather harsh terrain.When on a trip do
you file a flight plan with the FAA? If you do or if you don't would
you please tell me your reasoning for your decision?
FYI I have a cell phone , GPS and a SPOT brand personal locater
that has tracking ,check in , I'm OK , and SOS features.
Frank Goodnight
Firestar 2
Brownsville ,TX
Posted: Mon Jan 18, 2010 7:34 am Post subject: flight plans |
Frank C
I have taken a few long distance X-country flight (several hundred miles each). Most have been in my Cessna 172s that I used to own C but one was with a group of guys flying to Arlington Airshow with two Quicksilver 2-places.
While crossing the mountain range to get close to Seattle C one of the Quicks threw a blade on the WarpDrive prop. Fortunately C there was an emergency airstrip near the summit C and the pilot had enough altitude to glide in. We C the ground crew C drove to him C dissasembled the plane C and rolled it into the trailer we were towing.
Luckily C this situation turned out to be a non-event (a two hour inconvenience). Had this mishap occur over "rough terrain" C he would have been S.O.L.!!!
On a couple of C-172 cross country's I've flown over "inhospitable" terrain. If something happened that would have caused me to go down C it would have taken days for a ground crew (or rescue) to get to me. High pucker factor. Didn't like it much.
My last x-country flight C from northern California to southern Utah C by way of the southern route C was mostly over main freeways. I also flew with "flight following" the whole way C with LA Center C and Las Vegas Center. HUGE comfort factor.
I said all that to say this; if I were going to fly x-country C and it was my first trip C and it was in an experimental airplane C I would not even consider anything but a route above major roads.
If C for whatever reason C you have to land the plane where you don't intend C your retrieval could be a thousand times harder in rough terrian. What could have been a simple dissambly C and roll into a trailer C may now be a massively expensive C arduous rescue.
Ask our buddy Dennis how much a helicopter costs to go get your plane.
Other people may have a different take on x-country flights C but for me C I'll stay with the highway routes when possible. Besides C why is it a bad thing to fly your plane a little longer??
Just my thoughts.....
Mike Welch
MkIII CX
> From: frank.goodnight(at)att.net
| Quote: | To: kolb-list(at)matronics.com
Subject: flight plans
Date: Mon C 18 Jan 2010 03:43:34 -0600
--> Kolb-List message posted by: "frank.goodnight" <frank.goodnight(at)att.net>
Hi all Kolbers C
As i am still gearing up for C and trying to learn about my first long
X country C I have a question for you that choose to fly long X
FYI I have a cell phone C GPS and a SPOT brand personal locater
that has tracking Ccheck in C I'm OK C and SOS features.
Frank Goodnight
Fir===
Hotmail: Trusted email with Microsoft’s powerful SPAM protection. [quote][b]
by0ung(at)brigham.net Guest
Posted: Mon Jan 18, 2010 8:04 am Post subject: flight plans |
Hi all Kolbers,
Frank Goodnight
Firestar 2
Brownsville ,TX
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Frank
I try to use a flight plan for this reason. If you don't check in at
the time you said you would arrive,,,, they send someone to look for you
right a way. If something happened, and you did not have cell coverage,
or you could not get the spot's buttons pushed or operating, due to damage
to the spot or you. Who would know.
Boyd
Richard Pike
Posted: Mon Jan 18, 2010 8:05 am Post subject: Re: flight plans |
I am not much of a cross country pilot anymore, but here is what I liked to do - Know the center sector frequency for whatever airspace you are in. If you have a transponder and want flight following, that's ok, personally I don't much like flying with constant FAA chatter in my ear.
But if you know what sector you are in, roll up on their frequency, make sure you can hear the controller talking, and then turn the volume down and go back to listening to your mp3 player. You will need to have some idea of sector boundaries and when to change to the next frequency.
Here is a database of center frequencies -
http://microvoltradio.com/ARTCC/ARTCC.htm
If the fan quits turning, turn up the radio volume, and if no one else is talking, you do it just like in the movies: "Indy (whatever) Center, Mayday, mayday, mayday. Homebuilt Nxxxx just had an engine failure, let me know when you are ready to copy my position." And if you have a transponder, squawk 7700.
Believe me, you will have everybodies undivided attention. Because if the controller misses it and fails to respond, you will almost certainly get some other pilot asking about it (Center, did you hear that Mayday?). Which is what you want.
While you are waiting for the center to reply, flip your gps to show your present lat/longs. When center replies, read them off. Twice. If you know where you are relative to a landmark on the sectional or whatever, that's good too. Between that and your 7700 code, they will know where you are. (If you glide another 5 miles away from where you said, you better let somebody know...)
Then concentrate on flying the airplane, the feds can no longer help you. They will ask you questions like souls on board, altitude, etc, and it's nice to have that going on, but mostly you need to be flying the airplane.
There are probably other good ways to do it, and if you don't mind listening to FAA chatter, active flight following is best, but after having spent 30 years in the FAA, doing flight following and working various emergencies, that's how I would do it.
PS: Worth what ya paid for it.
Richard Pike
MKIII N420P (420ldPoops)
rlaird
Posted: Mon Jan 18, 2010 8:09 am Post subject: flight plans |
Filing a flight plan is never a BAD idea, but a lot of people see it as an inconvenience and/or hate to think they're relying on "big brother." However, if you have a (bad) habit of not closing your plans, then you should probably not open one. In your case, for this trip, it's probably a good idea. (Note: if you land at a tiny, out-of-the-way airport and have no cell signal, and there's no phone around, you could have a real problem.)
Flight following can be very useful and provide a comfort zone, but you have to be high enough for your radio to contact them. This might preclude any ideas about flying low.
Make sure you have plenty of experience using your SPOT, and that your email goes to a wide variety of people, and that those people know what to look out for (the SOS message).
You should also try to carry 2-days of water/food, an emergency blanket, matches, duct tape, tie wraps, extra batteries for the GPS, and a knife/tool-kit. There was once a downed pilot that wasn't too far off the beaten track, but broke a leg and couldn't go anywhere, so, having those essentials might help, even if you're following roads.
-- Robert
Houston, TX
On Mon, Jan 18, 2010 at 3:43 AM, frank.goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
[quote]--> Kolb-List message posted by: "frank.goodnight" <frank.goodnight(at)att.net (frank.goodnight(at)att.net)>
Hi all Kolbers,
As i am still gearing up for, and trying to learn about my first long X country, I have a question for you that choose to fly long X countrys over lightly populated
you file a flight plan with the FAA? If you do or if you don't would you please tell me your reasoning for your decision?
FYI I have a cell phone , GPS and a SPOT brand personal locater that has tracking ,check in , I'm OK , and SOS features.
Frank Goodnight
Firestar 2
Brownsville ,TX
http://forums.matronics.com
le, List Admin.
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Mon Jan 18, 2010 8:31 am Post subject: flight plans |
Frank
I have flown a number of cross countries mostly in GA aircraft but some in
my MKIII. If you are concerned about someone finding you follow roads as
Mike suggests. The best way to have someone track you is to use flight
following. They watch your every move, mostly good, but they will also see
every mistake. The biggest problem with flight following is that is
optional. The controllers will follow only if they have time and have the
desire to follow. Flight plans work well if you follow the plan and remember
to close the plan. Way too often pilots forget to close them. Because of
this there may be some delay in searching for you.
Spot is good but never used one. The old ELTs work but had so many false
alarms the rescue people way too often ignored them. As soon as the new
frequencies and spots get popular I would guess they also will be ignored.
I have used flight following in my Kolb a few times but I generally fly
cross county without any of this stuff except for my cell phone. I have a
old ELT because it is required.
In Michigan we have a Lake Watch for crossing the great lakes which I will
no longer do. They require you to check in like every 5 minutes after you
establish the watch or they send a helicopter. Other areas of the country
may have watch areas such as mountain watches you can use. If you can't get
flight following the next best are the watch services.
Again worth what you paid for it.
Rick Neilsen
Redrive VW Powered MKIIIC
Posted: Mon Jan 18, 2010 8:46 am Post subject: flight plans |
Frank C
I failed to address your flight plan question. Yes! I would file a flight plan. Be sure to open it C and also be sure to close it. Plus C don't forget to check in with ATC once in awhile C so they know your progress along your route.
One important thing to remember regarding flight plans or flight following: You do NOT have to wait for you to land to close it out! Usually C whe I have the airport in sight (maybe 10-15 minutes out) C I close my flight following. You obviously "made it" C and don't need the service anymore. Why wait until you get on the ground C get busy and have them hunt you down?
I would also draw an exact route of your intended path on a sectional C and leave a copy with a person on your SPOT email notification. Your cell phone will not be of much value if you stray too far away from highways. The cell phone towers do NOT give you coverage out in the boondocks.
It's definitely a good idea to have some of the supplies Richard P. mentioned. Like I said C if it were me C I'd chart my route along major roads. In the event of a mishap C your landing may be on the road C your cell phone will more likely work C your retrieval vehicle can drive right up to you C and help could be the next car to drive past you.
A mishap way out in the sticks will not have any of the above.
Mike Welch
| Quote: | From: frank.goodnight(at)att.net
Hi all Kolbers C
Frank Goodnight
Firestar 2
Hotmail: Fgo/196390708/direct/01/' target='_new'>Get it now. [quote][b]
Dana
Posted: Mon Jan 18, 2010 9:21 am Post subject: flight plans |
I don't think I've filed a flight plan since I got my license, over 30 years ago. If you're just talking VFR flight plan, that's no different from letting somebody know where you're going and when you should be expected to arrive. I did some long cross countries in the T-Craft, but I never had a radio so I couldn't use flight following or anything like that anyway. In the Kolb I do have a radio, but I route my flights over areas where I can make a safe landing... no long legs over the forest... and most of Connecticut isn't exactly remote anyway.
-Dana
The missionaries go forth to Christianize the savages-- as if the savages weren't dangerous enough already. [quote][b]
Posted: Mon Jan 18, 2010 9:34 am Post subject: flight plans |
Hi all,
Thanks to everyone that answered my request. Looks like I will file a
flight plan most of the time. Although I can still remember the 2
times I forgot to close, 35 years ago
just after I got my private.[ Red face and hung down head] It was bad
enough that I have never filed another one. Could be that as I am
older now and a little more settled may be that
I can remember the things that I have to do.
The Kolb list is a wonderful vehicle to access the wealth of
aviation knowledge that is out there , especially for very light A/
C.Thanks again to those that are willing to share.
I,m sure some of that knowledge was acquired the hard way.
Frank Goodnight
Firestar 2
On Jan 18, 2010, at 10:04 AM, b young wrote:
Hi all Kolbers,
Frank Goodnight
Firestar 2
Brownsville ,TX
Frank
in at
for you
coverage,
damage
Boyd
Posted: Mon Jan 18, 2010 11:50 am Post subject: flight plans |
Hi all,
Frank Goodnight
Firestar 2
The worst I have ever had is no phone at the destination airport... it
took a bit of time to be able to call in and cancel, ( had to go across the
street 1/4 mile after securing the plane) .. in the in between time they
had called my wife. But when I got to a phone I called the faa and my
wife. So all was good. It happened at monument valley. No radio
coverage at MV on the ground... best to close the flight plan while still
at altitude. Or plan some extra time to get to a phone. My cell had no
coverage at mv.
Boyd
Dana
Posted: Mon Jan 18, 2010 1:16 pm Post subject: flight plans |
At 02:49 PM 1/18/2010, b young wrote:
| Quote: | The worst I have ever had is no phone at the destination airport... it
had called my wife... |
I forgot to close my flight plan once, while I was still a student pilot. I remembered several hours later, all panicky (I was 17 at the time and they'd emphasized that you'd pay for an unnecessary search). The guy at the FSS when I called was real friendly, "don't worry, it's OK, nobody's lookin' for you." No doubt since it was a controlled field I landed at the first thing they did was contact the tower and verify I'd arrived.
-Dana
If you don't grow up by age 35, you don't have to. [quote][b]
vincenic1(at)embarqmail.c Guest
Posted: Mon Jan 18, 2010 1:40 pm Post subject: flight plans |
Frank,
I have used a simple device to help remember to open and close flight
plans. I put a small patch of Velcro on the instrument panel. Then, I
made a small tag with "Open Flight Plan" written on one side and "Close
Flight Plan" written on the other side and a small piece of the mating
Velcro on each side. With the tag attached to the Velcro, say just
above the ignition switches, it is hard to forget to open or close the
flight plan.
Vince Nicely
b young wrote:
Hi all,
Frank Goodnight
Firestar 2
elleryweld(at)AOL.COM Guest
Posted: Mon Jan 18, 2010 6:53 pm Post subject: flight plans |
Vic in Maine you need something like that that says take off on one side and Land on the other
Ellery Batchelder Jr.
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Tue Jan 19, 2010 6:06 am Post subject: Re: flight plans |
| frank.goodnight(at)att.ne wrote: | Hi all Kolbers,
Frank Goodnight
Firestar 2
Brownsville ,TX |
I agree with others on flight following instead if you have a transponder.
A flight plan vs FF is a little like the difference between snail mail and email. Both will do the job but the flight plan is a little clunkier. I.e.
VFR flight plan:
- someone realizes you're overdue
- people start making phone calls
- SAR is dispatched
- it's finally discovered you made it to dest. and forgot to close your flight plan
- you get yelled at
- you possibly get cited with violations, etc.
Flight following:
- fan stops turning/other problem
- you: "Albuquerque center, 972SS just lost the engine, I'm a glider going down"
-ATC: "972SS Roger"
Boom, ATC has your position and altitude right there on the screen. The know which dot to chase because of your squawk code. They know what happened and where to look etc.
So to me, it's really a slam-dunk in favor of FF. Back when I flew GA I used FF for breakfast, lunch and dinner. It's great because you're real-time integrated into the ATC system for the major portion of your flight and they can respond real-time to any kind of situation you could end up in during the trip.
And not only that, but they give you traffic reports, weather advisories, etc. It's a great deal all around.
The only drawback is they may turn you down if they're really busy. Tho even then they may hand you off to someone else to try in that event. I think I've been turned down maybe 2 or 3 times out of a whole bunch of times they gave it to me, so it's still pretty likely they'll fit you in.
If you take enough trips of any length it's worth it to fit a transponder and use FF whether or not you file flight plans. I'm thinking about putting one in the titan for this reason...
LS
_________________ LS
Titan II SS |
Posted: Tue Jan 19, 2010 8:47 am Post subject: flight plans |
Date: Mon, 18 Jan 2010 07:24:53 -0800
While crossing the mountain range to get close to Seattle, one of the Quicks
Mike,
What was the cause of failure?
Jack B. Hart FF004
Winchester, IN
Posted: Tue Jan 19, 2010 10:33 am Post subject: flight plans |
| Quote: | threw a blade on the WarpDrive prop.
Mike C
Jack B. Hart FF004
Winchester C IN
Hi Jack C
I don't recall what caused the prop to lose a blade. To be honest C I don't think I ever knew the exact reason for the failure. I was more like a bystander in the situation C than a participant.
A fellow student pilot and I were the ground crew for the two Quicksilver 2-placers. We drove the pickup and trailer that had the camping supplies and fuel. It was a full enclosure trailer C to haul a plane C if it was needed. Obviously C it turned out to be the case.
This incident was on our way to the 1994 Arlington Airshow. I do remember that the Warp Drive people met with him (Dan C my instructor) C and I think they got everything worked out okay. Even the Rotax people even got involved C due to the tremendous C violent shaking the engine experienced. Both vendors were present at the airshow anyway C so they got to work immediately resolving the problem.
Mike Welch
MkIII
Hotmail: Powerful Free email with security target='_new'>Get it now. [quote][b]
Posted: Tue Jan 19, 2010 11:11 am Post subject: flight plans |
Mike W/Gang:
I too, was at 1994 Arlington Flyin. Had just gotten back into the Lower 48 from Alaska.
Bob, with Warp Drive, was there. He helped me do some field repairs to my three Warp Drive Blades with JB Weld. I had flown in a lot of heavy rain which caused erosion just inboard the nickle steel leading edges. At that time 11" edges were max. Now we have 15" edges which cover the area that was subject to rain erosion.
Larry Bourne was also there. He reminded me that I didn't think it was a good idea for him to try on my MKIII for size. I don't remember the incident, but do remember I still had a long way to fly to get back home to Alabama, by way of the northern, eastern perimeter of CONUS, and the west coast of Florida.
And to keep this comment relative to the subject line, no, I do not file flight plans with FAA while flying in CONUS. However, I do flight follow with friend or family in Alabama and Florida.
[quote] This incident was on our way to the 1994 Arlington Airshow. I do remember that the Warp Drive people met with him (Dan, my instructor), and I think they got everything worked out okay. Even the Rotax people even got involved, due to the tremendous, violent shaking the engine experienced. Both vendors were present at the airshow anyway, so they got to work immediately resolving the problem.
Mike Welch
MkIII
_________________ John Hauck
Titus, Alabama |
