Rack on door handle
Strasnuts
PostPosted: Tue Jan 19, 2010 12:58 pm    Post subject: Rack on door handle Reply with quote
Anyone know if you end up using the middle piece of rack gear that the plans tell you to "trim and save". I would like to use it for something else.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
ricksked(at)cox.net
PostPosted: Tue Jan 19, 2010 1:18 pm    Post subject: Rack on door handle Reply with quote
How soon do you need it? I have both of mine ( I think) since I used Hendricks locks. Ill mail them to you
Rick Sked
Ron B.
PostPosted: Tue Jan 19, 2010 3:05 pm    Post subject: Re: Rack on door handle Reply with quote
Just about finished with the construction and haven't come across a call out for their use. I would say no. I had a look at the plans and I do believe I used them at the time for referencing where to cut the opening in the door for the rack. I think it was because they are shorter.
Strasnuts
PostPosted: Tue Jan 19, 2010 3:15 pm    Post subject: Rack on door handle Reply with quote
Thanks Ron.
780 Hours
SuperSTOL 60 hours
jeff(at)westcottpress.com
PostPosted: Tue Jan 19, 2010 3:32 pm    Post subject: Rack on door handle Reply with quote
I have some vague memory of using it as a guide for some aspect of the
door assembly, but its use isn't permanent.
something else.
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p 82308#282308
Ron B.
PostPosted: Tue Jan 19, 2010 3:49 pm    Post subject: Re: Rack on door handle Reply with quote
Page 45-13 , step 4. Operate the latch mechanism so as to cause the rack trimmings to extend
bwestfall
PostPosted: Tue Jan 19, 2010 3:50 pm    Post subject: Rack on door handle Reply with quote
Yes the plans have you use the cutoff shorter pieces to mark the doors where
to hog out fiberglass.
It pretty much requires the shorter pieces to be able to install the
mechanism and the plans have you install the mechanism to figure out how
much material to remove from the door to be able to install the door handle
with the full length pieces.
If doing it again though I would seriously consider cutting them a bit
longer to have more travel for the door pins like was mentioned in the last
couple days.
-Ben Westfall
Strasnuts
PostPosted: Tue Jan 19, 2010 3:56 pm    Post subject: Re: Rack on door handle Reply with quote
I finally found it in the plans. I read right over it a couple of times. Sorry I should have taken more time before I asked.
Rick, I still need the extra for my third pin.
Thanks everyone.
780 Hours
SuperSTOL 60 hours
jcumins(at)jcis.net
PostPosted: Tue Jan 19, 2010 4:00 pm    Post subject: Rack on door handle Reply with quote
I think I would just order a few more and then make them as long as you need
for the travel aspect of it. I am going with the 3rd party door handle and
locks. Vans are way to crude of a design and not the quality I want.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
