Silicone goo in IR alt.
jonlaury
PostPosted: Wed Jan 20, 2010 11:06 am    Post subject: Silicone goo in IR alt. Reply with quote
When I opened up the regulator of an IR alternator, the circuit board was submerged in a slime of silicone jelly. I blew most of it out with 100 psi air, but how do you get rid of the residue? I tried acetone with no effect. And even though I wiped off the area, I can still feel the slippery effects of the residue everytime I handle that part. I'm concerned about contaminating other parts of my plane and subsequent bonding problems for resin and/or paint.
retasker(at)optonline.net
PostPosted: Wed Jan 20, 2010 12:55 pm    Post subject: Silicone goo in IR alt. Reply with quote
Essentially impossible. All you can do is make sure you do not handle
the part and then touch anything else that may need paint or resin.
I guess curiosity would prompt me to ask why you removed the silicone
potting material since it was put there for a purpose? And why you are
removing the regulator from an IR alternator in the first place?
If your intention is to replace it with an external regulator, then just
get rid of the part with the silicone residue on it - problem solved.
If you plan to repackage the internal regulator externally, then do so
now - problem solved.
Dick Tasker
http://forums.matronics.com/viewtopic.php?p 82524#282524
lists(at)stevet.net
PostPosted: Wed Jan 20, 2010 12:59 pm    Post subject: Silicone goo in IR alt. Reply with quote
Hey, John, how about something like this?:
http://tinyurl.com/yhotqp4
Steve Thomas
PostPosted: Wed Jan 20, 2010 2:24 pm    Post subject: Silicone goo in IR alt. Reply with quote
That's a tough job . . . I think we had some
super-solvents at HBC that would cut silicon
oils. I'm going to be out there tomorrow close
to the processes lab . . . I'll drop in and
ask.
jonlaury
PostPosted: Wed Jan 20, 2010 6:13 pm    Post subject: Re: Silicone goo in IR alt. Reply with quote
Dick,
Thanks for your thoughts.
I opened up the IR to cut all the circuits of the board away from external terminals so that I could convert it to a ER alternator. I'll have to look at how I might do the conversion without the OE plug and mounting points.
I was following instructions for the conversion from an article that appeared in the Experimenter. The alternator in the pictures had an epoxy potted board instead of this nasty silicone surprise
John.
jonlaury
PostPosted: Wed Jan 20, 2010 6:21 pm    Post subject: Re: Silicone goo in IR alt. Reply with quote
Steve,
Thanks for that. The data sheet says it gets rid of silicone oils so should do the trick. Now the trick is to find it.javascript:emoticon('Very Happy')
Bob McC
PostPosted: Wed Jan 20, 2010 6:34 pm    Post subject: Silicone goo in IR alt. Reply with quote
Jon;
Possibly the last item on this page?? http://tinyurl.com/yjjtwus Silicone is resistant to most solvents. Another possibility is silicone polish remover, available from auto paint shop wholesalers.
Bob McC
[b]> --
Bob McC
Falco #908
(just starting)
jonlaury
PostPosted: Wed Jan 20, 2010 7:00 pm    Post subject: Re: Silicone goo in IR alt. Reply with quote
Bob McC
The PolySi product looks like it would do the job, but one gal. smallest size is a bit more than I need.
The 3M Novec Degreaser product is available (who'd athunk) from Aircraft Spruce! in 12 oz aerosol, $19, and I have to place an order there soon.
Thanks for the thought,
Bob McC
PostPosted: Wed Jan 20, 2010 7:30 pm    Post subject: Silicone goo in IR alt. Reply with quote
John;
The link I sent says it's available also in pints and quarts, but if you've
found something at "Spruce" and you're placing an order anyway, then that's
the way to go.
Bob McC
[quote] --
Bob McC
Falco #908
(just starting)
