jonlaury
Posted: Fri Jan 22, 2010 10:10 am Post subject: Battery Cranking Amps |
Anybody have a method for determining cranking amps necessary for a specific engine? Mine's a 10.5:1 350in 6 cyl
I found this site with a CCA calculator and other useful engine stuff.
http://www.bgsoflex.com/auto.html
Trusting but verifying.
N20DG
Joined: 02 Jan 2008 Posts: 61 Location: lancaster, texas
Posted: Fri Jan 22, 2010 10:54 am Post subject: Battery Cranking Amps |
Would like to look at this site but this is what I get when I log onto it
"You don't have permission to access /auto.html on this server. "
Dick
In a message dated 1/22/2010 12:13:47 P.M. Central Standard Time, jonlaury(at)impulse.net writes:
| Quote: | --> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
http://forums.matronics.com/viewtopic.php?p=282917#282917===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Posted: Fri Jan 22, 2010 11:24 am Post subject: Battery Cranking Amps |
At 12:10 PM 1/22/2010, you wrote:
The "cranking amps" ratings of batteries are generally
not high on the priority of items in system design goals.
Weight, size, ease of installation, cost of ownership,
and other features usually set decision process in
OBAM aircraft. Cranking amps for an engine is pretty
whispy too . . . it depends on tightness of the engine,
temperature, viscosity of oil, motor efficiency, gear
ratios, wire sizes, etc.
In other words, I'll suggest you start with a 3 x 6 x 6"
SVLA, 17-20 a.h. battery with expansion room for upsizing later. See
how that fits with YOUR notions of satisfactory performance.
A new battery that size will get your engine going with
about any of the modern starters. The question that drives
an up-sizing decision is how often you need to replace the
battery for the environment and missions you fly.
MOST builders are happy with that size battery.
mrspudandcompany(at)veriz Guest
Posted: Fri Jan 22, 2010 11:56 am Post subject: Battery Cranking Amps |
I was able to get right on without a problem.
Roger
Dick
[quote]--> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
N20DG
Posted: Fri Jan 22, 2010 12:45 pm Post subject: Battery Cranking Amps |
Must be an AOL thingy - went to firefox and loaded OK
Dick
In a message dated 1/22/2010 1:58:19 P.M. Central Standard Time, mrspudandcompany(at)verizon.net writes:
| Quote: | http://www.bgsoflex.com/auto.html
jonlaury
Posted: Fri Jan 22, 2010 9:09 pm Post subject: Re: Battery Cranking Amps |
Bob . . . |
Per your suggestion of using smaller batteries to make a lightweight Z14, I looked at the Odyssey PC 310. With two of them I'd have 620 amps for 5 seconds (wondering how many engine start trys I get). According to the website that I linked in my original post, I need 427amps to spin my 6cyl 350 in. engine. The PC310 (6lbs) is an 8AH battery with a 25 amp discharge capability of 9 minutes. Two of them gets me about 1/2 hr (at) 12 amps, which is what my 2 no frills battery buses and E bus need. Having 2 alternators makes me OK with this minimum size battery bank and this light weight Z14 weighs less than the Z19 with 2 17AH batts by about 10 lbs.
What am I overlooking
earl_schroeder(at)juno.co Guest
Posted: Sat Jan 23, 2010 7:10 am Post subject: Battery Cranking Amps |
Hi John,
You wrote in part:
What am I overlooking?
Check the size of the battery terminals. Some that I've tried were too small to accept the wire size required to carry starter current requirements. For instance, some would only accept a 6-32 size screw or a 1/4" push on tab. Earl
Posted: Sat Jan 23, 2010 10:35 am Post subject: Battery Cranking Amps |
At 09:06 AM 1/23/2010, you wrote:
<earl_schroeder(at)juno.com>
Hi John,
You wrote in part:
The 310 is pretty light even in pairs. Limited
cranking ability due to high internal resistance.
Even with two paralleled, total battery resistance
about twice that of a 680.
That doesn't mean it won't work for YOUR airplane
and the environment in which you crank the engine.
There ARE small batteries with low internal resitances.
Bill and I tested a 10 a.h. Gates product about 15 years
ago that gave us five, 10-second cranking cycles on a
room temperature, hi-compression engine with 1 minute
waits between attempts.
So there is potential for a pair of light weights
to step up to the task . . . the 310 may or may
not be a good choice. You'll have to tell us.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
jonlaury
Posted: Sun Jan 24, 2010 5:01 pm Post subject: Re: Battery Cranking Amps |
OK I'm abandoning my holy grail search for a lightweight Z-14. I don't want to spend $300 for 2 PC310's to find out that they won't crank my engine. I think I'll settle for Z-13/8 (with a 40amp stby; $350 less money, more amps and a 4.5 # penalty over the B&C PM alts that don't fit my Franklin engine) and I'll use a single PC680. I have accomodation for another 680 should I decide that I need the redundancy. A single 680 gives me about 45 mins with my Ebus load (longer than the dual 310's). I still save 7+ lbs over Z-19 and I like having the second alternator better than a second battery.
No matter how frequently I tested my batteries, I know that with no alternator, I'm not going to be comfortable with a vague notion of how long I've got. I would head for an airport immediately. With a second alternator and battery reserve, a primary alternator failure, becomes a bother rather than something I have to make a go/no-go decision about.
Other than the size of the alternator, and using two B&C LR-3 VR's, I see nothing in Z13/8 that I would change.
Any observations/refinements appreciated.
jonlaury
Posted: Sun Jan 24, 2010 5:05 pm Post subject: Re: Battery Cranking Amps |
| earl_schroeder(at)juno.co wrote: | Hi John,
Check the size ng?of the battery terminals. Some that I've tried were too small to accept the wire size required to carry starter current requirements. For instance, some would only accept a 6-32 size screw or a 1/4" push on tab. Earl |
Thanks Earl. You're right. The PC 310 use an M4 screw (#8-32 equiv). There's a pad for more contact, but the screw is pretty small to get decent clamping force applied.
See the previous post.
kevann(at)gotsky.com Guest
Posted: Mon Jan 25, 2010 6:55 am Post subject: Battery Cranking Amps |
I have a two alt one batt(pc680) syatem in my 914 powered Europa. I change
out the battery every other year. I modified our Subaru Legacy to take the
680. The two year old 680 cranks the Subaru fine for two years till I get a
new one for the plane.
Kevin
jonlaury
Posted: Mon Jan 25, 2010 9:43 am Post subject: Re: Battery Cranking Amps |
| kevann(at)gotsky.com wrote: | I have a two alt one batt(pc680) syatem in my 914 powered Europa. I change
Kevin
Thanks Kevin.
I've often thought that with the numbers of people that subscribe to the List and who monitor this forum, there's got to be a market for 1 or 2 year old AGM batteries like the Odysseys for those who opt for a two battery system like Z19 or 14 and are in their first year.
It always pained me thinking of tossing a perfectly good $100+ battery.
Your Subaru adaptation is a good way to get some use out of a normally superfluous batt.
J
klehman(at)albedo.net Guest
Posted: Mon Jan 25, 2010 12:01 pm Post subject: Battery Cranking Amps |
That is actually a nice thing about z-14 with small batteries such as
the Dekka units. Flog them until cranking is noticeably slower. See
which one is dead and put the new one on the most critical side. They
are still $100. batteries but they are fully consumed when replaced.
Ken
jonlaury wrote:
> Kevin
Thanks Kevin.
J
http://forums.matronics.com/viewtopic.php?p 83361#283361
