Landing and Taxi Light Question?
jeffrey-j-paris(at)excite
PostPosted: Thu Jan 21, 2010 8:31 am    Post subject: Landing and Taxi Light Question? Reply with quote
Europa Guru's,
I am planning to use HID lamps for my taxi and landing lights. Any considerations, suggestions or pictures to where Europa Builders have placed them? I think I will be placing mine in the front of my cowl below the air inlets. I have plenty of room due to the fact that I stretched my Rotax purposed cowl to fit my Jabiru 3300 installation (approx. 8" stretch).  Any ideas would be greta.
Cheers and thanks to all,
Jeff Paris Rochester, New York Europa Classic Monowheel kit #A012  Jabiru 3300 2450 hours into the build and getting ready to prime and paint all my flying surfaces.
Best Weight Loss Program - Click Here! Weight Loss Program Click Here For More Information [quote][b]
raimo.toivio(at)rwm.fi
PostPosted: Thu Jan 21, 2010 9:49 am    Post subject: Landing and Taxi Light Question? Reply with quote
Hi Jeff,
I feel not to be a Guru but I am brave enough to answer:
I have two 35 W Xenon lights. RT´s taxi light is hidden in the lower cowl turbo air intake (I have 912S so the intake is not necessary for my engine). It is ON in the attached photo. RT´s landing light is built-in to the duct above the air cooler´s air intake. It is OFF but visible in the attached photo. Both are very effective and I have been happy with them all night long. Typical GA landing light 100 W like in Cessna is a children´s torch when compared with these Xenons. An extra benefit: they does not care off vibration or so and their expected life span is around +1000 hrs. They are also light weight. Today you can find even 500 Watts leds and their size is like a mail stamp. But a cooling is a huge (power led´s cooler is huge!) problem.
Raimo OH-XRT
 Filesize:  70.7 KB
 Viewed:  4786 Time(s)
johnwigney(at)windstream.
PostPosted: Fri Jan 22, 2010 10:55 am    Post subject: Landing and Taxi Light Question? Reply with quote
Hi Jeffrey,
I mounted my light at the top of the left outrigger fairing. It is a 35w 'taxilight' with a conventional bulb. However, the illumination is really not very satisfactory. One day, I will mount an HID light in the same spot. I plan to use a light from Trail Tech. I think a 30 watt HID SCMR16 # 4252-SX will meet my needs. See catalog.
I also intend to look at using a 'snowdome for a fairing. This idea was posted earlier by a very creative Europaphile.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
ORIGINAL MESSAGE [quote]From: "Jeffrey J Paris" <jeffrey-j-paris(at)excite.com>
Subject: Landing and Taxi Light Question?
Europa Guru's,I am planning to use HID lamps for my taxi and landing lights.
=C2- Any considerations, suggestions or pictures to where Europa Builders
have placed them?=C2- I think I will be placing mine in the front of my co
wl below the air inlets.=C2- I have plenty of room due to the fact that I
8" stretch).=C2- Any ideas would be greta.Cheers and thanks to all,Jeff P
aris Rochester, New York=C2- Europa Classic Monowheel kit #A012=C2- Jabi
y flying surfaces.=C2-
craigb(at)onthenet.com.au
PostPosted: Fri Jan 22, 2010 2:57 pm    Post subject: Landing and Taxi Light Question? Reply with quote
[quote] Just on Raimo's and johns note on the hid lights, you might find this site
useful www.hid50.com I have not purchased anything from him yet, but
the prices seem good, and he has a lot of good information that is worth
a read if considering HID. Only problem is he sells just the bulbs and balasts
no lights to put them in, so you need to find a suitable light to take the
bulb, my thoughts were some of the new motorcycle lights are just about
the right size and could be dismantled and fitted into the cowl.
craig
DanBish
PostPosted: Sat Jan 23, 2010 8:21 am    Post subject: Re: Landing and Taxi Light Question? Reply with quote
While we're on the subject, I'll be needing to purchase my position lights soon, to be installed inside a rebate on the front/outermost wingtips inside the custom clear fairings I bought from Aerial Pleasures. I've seen some combo position/landing light options but I think they're halogen, not HID. Anyone seen a US based HID landing light option that would fit in the wingtip and include red/green position lights?
Dan
jrgowing(at)bigpond.net.a
PostPosted: Sat Jan 23, 2010 3:11 pm    Post subject: Landing and Taxi Light Question? Reply with quote
for those like me that did nont know:-
www.hid50.com yiels the following:-
High intensity Discharge lighting is light from a plasma discharge rather than a filament. The system involves a combined igniter and ballast to start the light and maintain the current, and certain gases and metal salts to create the light. Overall the system uses less energy than halogen lighting, while producing 4 times more light per watt.  HID lights are sometimes referred to as Xenon bulbs, due to the presence of Xenon gas between the electrodes. Note that some halogen bulbs contain small amounts of Xenon (up to 5%) and accordingly brand themselves as 2Xenon lights 2, but they are not High Intensity Discharge lamps and do not put out greater light than standard halogen bulbs.
Bob Gowing in Oz UK kit 327
