Door Flex
speckter(at)comcast.net
PostPosted: Thu Jan 28, 2010 12:50 pm    Post subject: Door Flex Reply with quote
I have been wondering about how much door flex plays into the equation. I tried mine and it will only flex outward only about 1/8 to 3/16” no matter how much I push out while it is latched. I have the metal pin receptacles. I am wondering if some doors flex much more adding to the possibility of unlatching.
How much to others doors flex while latched?
Gary Specketer
Tim Olson
PostPosted: Thu Jan 28, 2010 1:08 pm    Post subject: Door Flex Reply with quote
I'm intrigued by the reports of "bowing". I've never noticed
mine bowing at all, and they don't flex, either. I wonder if
that has more to do with the hole location where the pins
go through than anything else. Mine has to be pulled ALL
the way in to get the pins in the holes. I built it so that
those pins really suck that door in tight. Perhaps the
bowing happens if builders leave a little more slop in the
doors by having the holes a tiny bit outboard?
Anyway, no bowing/flexing or anything that I've seen.
Tim Olson - RV-10 N104CD
Gary Specketer
aerosport1
PostPosted: Thu Jan 28, 2010 1:23 pm    Post subject: Door Flex Reply with quote
I think the door bowing could be possibly what Tim said but also if the
doors are not joined properly with the 3 dimensional glass cloth that is
used when joining the 2 door halves. This would allow the doors to flex more
in the middle. If that bond has been compromised somehow that would
definitely let the door bow in the center. I have tried to bend my doors
before attached to the airframe and they were very strong.
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Tim Olson
PostPosted: Thu Jan 28, 2010 1:40 pm    Post subject: Door Flex Reply with quote
I forgot all about that...you're right, could be in the glassing of
the doors, too. Good catch.
Geoff
Geoff Combs
President
614-834-5227p
614-834-5230f
bcondrey
PostPosted: Thu Jan 28, 2010 1:59 pm    Post subject: Door Flex Reply with quote
For those early RV-10 builders, remember that Van's original doors on the prototype had a bowing problem. I recall them discussing it at the RV-10 forum at OSH and citing that as the reason for the original finishing kit delays. That's when they put the reinforcing graphite strips in the door shells and proclaimed the issue resolved. There were never doors delivered to customers without the graphite reinforcement.
As others have said, it very well may be that some have an issue with the internal 3-D cloth not being properly installed. And, having the pins be a "comfortable" fit rather than really tight could also easily be a factor.
RV-10 N442PM (flying)
pitts_pilot(at)bellsouth.
PostPosted: Thu Jan 28, 2010 4:42 pm    Post subject: Door Flex Reply with quote
I wonder if the door halves haven't debonded along the bottom .... in
the doors that bow out.
Linn
> Gary Specketer
dmaib(at)mac.com
PostPosted: Thu Jan 28, 2010 5:24 pm    Post subject: Door Flex Reply with quote
Mine are the same as yours, Gary. Very little flexing. I have watched the pilot door during descents at speeds near Vne and see the same.
David Maib
40559
flying
Gary Specketer
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
orchidman
PostPosted: Thu Jan 28, 2010 7:38 pm    Post subject: Re: Door Flex Reply with quote
Tim Olson wrote:
I'm intrigued by the reports of "bowing". I've never noticed mine bowing at all, and they don't flex, either.
I never thought mine bowed either, but last week I took a short flight and took some pictures of my door.
The pictures are of the door measured at the middle fore-aft about at the back of your hip. One picture of the door is on the ground. The second is with all my vents closed flying at 150 KIAS and a 3rd is with all my vents open flying at 150 KIAS, both at 4500 Ft.
It looks like with the vents CLOSED, I have 1/16 inch bow and at 150 KIAS with all my vents OPEN and freezing my self to death, I have 1/8 inch bow. I have the Rivet Head Aluminum pins/blocks and it is a tight fit on the ground when closing the doors.
At 150 KIAS, all vents open
 Filesize:  25.38 KB
 Viewed:  10914 Time(s)
At 150 KIAS, vents closed
 Filesize:  28.6 KB
On the ground
 Filesize:  29.01 KB
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
indigoonlatigo(at)msn.com
PostPosted: Thu Jan 28, 2010 8:42 pm    Post subject: Door Flex Reply with quote
Now that is good science...Good work.
Thats why I put a spider foam block laminated between the door halves in the area shown. It acts like a shear web between the skins. There is a lot of open air space in that location of the door.
Subject: Re: Door Flex
Date: Thu C 28 Jan 2010 19:38:06 -0800
 Filesize:  108.41 KB
 Viewed:  10906 Time(s)
msausen
PostPosted: Fri Jan 29, 2010 8:42 am    Post subject: Door Flex Reply with quote
Hmm, makes me wonder if it would make sense to put an "exhaust" vent in the rear bulkhead to allow the pressure to equalize like they do with cars.
Michael
roxianmike(at)msn.com
PostPosted: Fri Jan 29, 2010 1:07 pm    Post subject: Door Flex Reply with quote
John I like the idea of adding some substance to the door in there but forgive me but what is a spider foam block?
Subject: RE: Re: Door Flex
Date: Thu C 28 Jan 2010 20:40:35 -0800
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} Now that is good science...Good work.
--> RV10-List message posted by: "orchidman" <gary(at)wingscc.com>
Tim Olson wrote:
> I'm intrigued by the reports of "bowing". I've never noticed mine bowing at all C and they don't flex C either.
I never thought mine bowed either C but last week I took a short flight and took some pictures of my door.
The pictures are of the door measured at the middle fore-aft about at the back of your hip. One picture of the door is on the ground. The second is with all my vents closed flying at 150 KIAS and a 3rd is with all my vents open flying at 150 KIAS C both at 4500 Ft.
It looks like with the vents closed C I have 1/16 inch bow and at 150 KIAS with all my vents and freezing my self to death C I have 1/8 inch bow. I have the Rivet Head Aluminum pins/blocks and it is a tight fit on the ground when closing the doors.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=283878#283878
http://forums.matronics.com//files/doors150open_314.jpg
http://forums.matronics.com//files/doors150closed_211.jpg
http://forums.matronics.com//files/doorsonground_113.jpg
<= Archive Search & Download C 7-Day Browse C Chat C FAQ C
orchidman
PostPosted: Sat Jan 30, 2010 8:05 am    Post subject: Re: Door Flex Reply with quote
Michael
I have also wondered about just how in-coming air is exhausted. I can think of many routes for the air to get out but now at least on my AC, I now know they are not as effective as 2 of Steins big vents. And I guess I should note that I didn't open up the 4 little ones in the overhead console. It was cold enough just opening up the 2 big front ones for a couple minutes.
This brings up another point. For those who have alternate static ports inside the cabin, have you tested them and under what conditions? Looks like you will need to note the conditions and results with your tests.
Is all of this opening a can of worms or what Mr. Green
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
nukeflyboy
PostPosted: Sun Jan 31, 2010 7:18 pm    Post subject: Re: Door Flex Reply with quote
You really don't want to put a vent opening in the rear bulkhead. The pressure in the tailcone is higher than that in the cabin and you will get a huge cold draft coming forward. In flight you can feel the air coming forward thru the corrugations in the baggage compartment bulkhead.
Dave Moore
RV-6 built and sold
RV-10 built and flying
Space Cadet
PostPosted: Tue Feb 02, 2010 9:01 am    Post subject: Re: Door Flex Reply with quote
So does all of the above mean the cabin vent air is being exhausted out the doors through the gap? Or are there other significant leak paths?
