				 Posted: Sat Jan 30, 2010 9:05 am    Post subject: Alternate static--was Door Flex |
				I have a story (confession) about alternate static.
 I have a "toggle valve" for the alternate static port that just opens the static system to cabin pressure.  I think that's pretty standard.
 At some point after test flying, I had the panel apart and managed to put the toggle in upside down, so "normal" was open to the cabin and "alternate" was the regular static system.
 The result was that everything worked as advertised--airspeed, altimeter, encoder, all seemed normal enough that I didn't have any reason to suspect an error.  But, when we opened an air vent while using altitude hold, we got about a 50' climb, then level off and everything normal again.  Reverse when closing the vent.  The A/P was seeing higher pressure, equating it to lower altitude, and correcting.
 I was convinced that the vent was upsetting airflow over the elevator trim.  Sometimes I'm really surprised at the lengths my brain will go to in order to make the pieces of a puzzle fit...
 Anyway, the actual problem finally dawned on me, and I turned the toggle 180* to match the normal/alternate labels, and all was well.  Duh.
   Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA 95076
 831-722-9141 Shop
 831-750-0284 Cell
		Tim Olson
				 Posted: Sat Jan 30, 2010 9:18 am    Post subject: Alternate static--was Door Flex |
				I have a toggle too. It's interesting to have the AP engaged and
 flip the toggle open-closed-open-closed, and watch the plane
 and altimeter/airspeed/vsi.
 Tim Olson - RV-10 N104CD
 Dave Saylor wrote:
  	  | Quote: | 	 		   I have a story (confession) about alternate static.
  Dave Saylor
  AirCrafters LLC
  140 Aviation Way
  831-722-9141 Shop
  831-750-0284 Cell
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Sat Jan 30, 2010 5:29 pm    Post subject: Re: Alternate static--was Door Flex |
				 	  | Tim Olson wrote: | 	 		  I have a toggle too. It's interesting to have the AP engaged and
 I am curious, what happens when you open/close the vents.  From my experiences, it does look like we are getting a fair amount of cabin pressurization when opening our vents.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		Tim Olson
				 Posted: Sat Jan 30, 2010 7:48 pm    Post subject: Alternate static--was Door Flex |
				I'll let you know this summer when I open my vents.  . Got up to 14F
 today.
 On Jan 30, 2010, at 7:29 PM, "orchidman" <gary(at)wingscc.com> wrote:
  Gary Blankenbiller
  RV10 - # 40674
  (N2GB Flying)
  http://forums.matronics.com/viewtopic.php?p 84105#284105
