bakerocb
Posted: Mon Jan 25, 2010 6:55 am Post subject: Encoder Certification |
1/25/2010
Hello Angier Ames, You wrote 1) 2) and 3) below:
1) "Altitude encoders are required equipment for IFR flight in controlled
airspace."
{Response} Not true for all controlled airspace -- just that airspace
identified in 91.215 (b). Can you show otherwise?
2) "And unless the operation is conducted under part 121 or 135, as per
FARS, 14CFR Section215(a), they do NOT need to be certified/ TSO'd."
{Response} Not true because 14 CFR Section 215 (a) says exactly the
opposite. Read here:
"91.215 ATC transponder and altitude reporting equipment and use.
(a) All airspace: U.S.-registered civil aircraft. For operations not
conducted under part 121 or 135 of this chapter, ATC transponder equipment
installed must meet the performance and environmental requirements of any
class of TSO-C74b (Mode A) or any class of TSO-C74c (Mode A with altitude
reporting capability) as appropriate, or the appropriate class of TSO-C112
(Mode S)."
3) "So, go to your basement and create your own altitude encoder. Your only
obligation under Part 91 is to demonstrate that it meets the performance and
environmental standards of any class of TSO-C47b or c or TSO-C112."
{Response} More than a bit misleading. The FAA requirements of proving "the
performance and environmental standards" of a TSO, or an alternate method of
complying with the requirements, for avionics are very extensive, demanding,
and expensive. This is why most of the altitude encoding EFIS' available to
the experimental amateur built community are not TSO'd. There is extensive
material in the aeroelectric list archives on the significance of
paragraph14 CFR 91.217, particularly 91.217 (b). Just help yourself.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 07:07:12 AM PST US
Subject: AeroElectric-List: Re: Encoder Certification
Since we are all now exhausted by this subject, lets beat this dead
horse one more time.
airspace. And unless the operation is conducted under part 121 or 135,
as per FARS, 14CFR Section215(a), they do NOT need to be certified/
TSO'd.
only obligation under Part 91 is to demonstrate that it meets the
performance and environmental standards of any class of TSO-C47b or c
or TSO-C112.
Angier Ames
N4ZQ
grosseair(at)comcast.net Guest
Posted: Mon Jan 25, 2010 9:58 am Post subject: Encoder Certification |
I agree, Bob, and I thought the first couple of responses pretty well
covered the original question. The subsequent discussion has certainly
covered the subject of controlled airspace, but reminds me of a favorite
quote: "A fanatic is one who can't change his mind and won't change the
subject"--Winston Churchill
John
bobsv35b(at)aol.com wrote:
| Quote: | Good Morning John,
As Always, It All Depends! <G>
I think most of us would agree with your assessment.
The subject came up when a homebuilder wanted to know if he could fly
his transponder equipped airplane to another point to get it certified.
That morphed into a discussion as to where a transponder is required.
While most of us do opt to have an operating transponder on board, the
fact remains that such a unit is NOT required in most of the airspace
utilized by we GA pilots.
Even in areas where a transponder IS required, there are procedures
available that may allow a flight to be made with the transponder
inoperative.
And, why do we care? As OC says, it's all in the spirit of education.
Since there are so many conflicting opinions, it appears that some
education is required.
Does that make any sense at all or do you still feel we were wasting
your time?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Downers Grove, IL
Stearman N3977A (With a transponder)
In a message dated 1/24/2010 12:08:07 A.M. Central Standard Time,
grosseair(at)comcast.net writes:
<grosseair(at)comcast.net>
This whole discussion has me totally exhausted. I personally don't
understand why you just wouldn't buy a transponder... unless, of
course.
you're smuggling drugs or are flying some WWI vintage rag bag with no
electrical system. Then I get it, and why would you even care?
John
al38kit
Posted: Sat Jan 30, 2010 8:04 pm Post subject: Re: Encoder Certification |
This has been a most humorous thread...It appears that many agree that a transponder is required in all controlled airspace...it is not.
In fact, a transponder is not required for all IFR flight. A quote from the EAA regarding equipment for IFR flights...
"Transponders and related equipment; One item that will be high on the list of desired equipment will be a transponder. It’s interesting to note that 91.205 does not list a transponder as required in order to operate under IFR."
Just to muddy the water!
