		jkreidler
  Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
				 Posted: Mon Feb 01, 2010 5:49 am    Post subject: Fuel Filter Service - Access Panel |
				I was thinking about how difficult it is to service the fuel filter.  First, just to get at it there is a pile of work in removing the tunnel cover.  Some have split the tunnel cover so it isn't necessary to remove the entire cover to inspect the tunnel, great idea, for those still building this should be considered.  Others have installed an access panel in the side of the tunnel in the foot well.  This allows easier access to the fuel filter and fuel pump.  One of the things I really dislike about servicing the fuel filter is that you have to break the fuel lines, and this causes some fuel to spill.  Add insulation to soak up the fuel and you have a recipe for disaster, so you need to use a box of rags to keep the fuel from getting all over the place.
 So here is what I was thinking, I wished that when we built the airplane we would have installed an access panel on the bottom of the airplane that we could have reached up through to get at the fuel filter.  This would have been much easier during construction....  An alternative would be to install a second fuel filter, and place both filters at the tank exits under the wing walk access panel.
 I post this simply to get those who are still building to think about how they will service the fuel filter.  Not sure how we will modify our airplane to simplify the task.
  Thanks, Jason Kreidler
 N44YH - Flying
 4 Partner Build #40617
 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler
  _________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
		gengrumpy(at)aol.com Guest
				 Posted: Mon Feb 01, 2010 5:59 am    Post subject: Fuel Filter Service - Access Panel |
				It's not that big of a deal to take it out, and you need to inspect inside the tunnel anyway at each annual.
 Run the engine dry to check that the shut-off valve works, then a couple of paper towels soak up any residual (I put no insulation in my tunnel for just that reason.....did not want anything to soak up fuel should there be a leak or spill in there......
 I wouldn't mess with cutting access panels in the floor......at least not before checking with Van's on what it might do to structural strength....
 grumpy
 N184JM flying, about to start #3 annual
 On Feb 1, 2010, at 7:48 AM, jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com) wrote:
  	  | Quote: | 	 		  I was thinking about how difficult it is to service the fuel filter.  First, just to get at it there is a pile of work in removing the tunnel cover.  Some have split the tunnel cover so it isn't necessary to remove the entire cover to inspect the tunnel, great idea, for those still building this should be considered.  Others have installed an access panel in the side of the tunnel in the foot well.  This allows easier access to the fuel filter and fuel pump.  One of the things I really dislike about servicing the fuel filter is that you have to break the fuel lines, and this causes some fuel to spill.  Add insulation to soak up the fuel and you have a recipe for disaster, so you need to use a box of rags to keep the fuel from getting all over the place.
 N44YH - Flying
 tp://www.matronics.com/Navigator?RV10-List
 nics.com
 w.matronics.com/contribution
 =  [quote][b]
		Tim Olson
				 Posted: Mon Feb 01, 2010 6:10 am    Post subject: Fuel Filter Service - Access Panel |
				I just did this yesterday...removed the tunnel cover and
 disassembled the fuel filter.  I was contemplating doing
 a side access door like Scott to get to the filter. I think
 that access door could be really handy in accessing the filter
 to get tools in there.  But, at the same time, even if you
 have the door I don't think that makes it a great idea to
 do any filter removal without the tunnel cover off.
 I spilled plenty of fuel in that tunnel area and had to
 wipe it up as you noted.  I wouldn't want to completely do the
 job through a side panel unless I knew I could get it
 all 100% cleaned.  So I think that unless there were a
 bottom access panel as you noted, there isn't really
 a good way to service the filter without removing
 the tunnel cover completely, and also removing that SCAT
 tube for better access.  A side panel removal would
 add to easier access.
 But, when all is said and done, I think removal of the
 entire tunnel cover is probably something you should all
 be doing once a year anyway.  And I mean the entire tunnel
 cover back through the rear seats.  It's the only way
 you'll be able to inspect and lubricate the control rod
 ends.  It will still be a pain in the butt, but if it only
 comes once a year during annual time then it's not much
 worth complaining about....it's easier to annual an RV-10
 than it is some of those other certified planes.
 Tim Olson - RV-10 N104CD
  N44YH - Flying
		Phil.Perry(at)netapp.com Guest
				 Posted: Mon Feb 01, 2010 6:24 am    Post subject: Fuel Filter Service - Access Panel |
				I’m not sure if it’s possible, but I’ve been thinking of adding one filter at each wing root.
 I like the simplified access to the filter, but I also like the idea of having one fuel filter dedicated to each tank.  This way if a filter should get blocked, I can flip to the other tank and access some fuel there.
 Phil
 From: jason.kreidler(at)regalbeloit.com [mailto:jason.kreidler(at)regalbeloit.com]
  Sent: Monday, February 01, 2010 7:48 AM
  Subject: Fuel Filter Service - Access Panel
  N44YH - Flying
  Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		dlm46007(at)cox.net Guest
				If a builder decides to start cutting extra holes in the skin,  I would advise getting a structural engineer's analysis of the  proposal.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of  jason.kreidler(at)regalbeloit.com
 Sent: Monday, February 01, 2010  6:48 AM
 N44YH - Flying
		Tim Olson
				I did insulate the tunnel, but only the side walls.
 I don't think it does anything worthwhile to do the
 sidewalls either. The forward firewall, sure.
 And then the SCAT tube wrapped with insulation.
 That would be all I'd do if I were doing it again.
 My sidewall insulation doesn't go all the way to the
 floor though so fuel spilling and soaking isn't
 going to soak into it.
 Miller John wrote:
  	  | Quote: | 	 		   It's not that big of a deal to take it out, and you need to inspect
  strength.....
  grumpy
 > the place.
 > N44YH - Flying
 > nics.com
		Kellym
				Is there any particular reason the filter needs to be in the tunnel?
 Anyone considered relocating to front side of firewall?
 Tim Olson wrote:
 > the place.
 > N44YH - Flying
KCHD |
		Tim Olson
				 Posted: Mon Feb 01, 2010 6:39 am    Post subject: Fuel Filter Service - Access Panel |
				I think under the seats would be an awesome location except
 for one thing.....when you disconnect the lines, with
 no valve to shut off, you're going to dump fuel all
 over the place.  So that would tempt you to add shutoffs
 to each tank in front of the filter....and then that's
 another point of leak/failure.  Maybe with the right
 valves I'd consider putting one filter per wing and
 putting them under the seats.  Not sure if it's worth
 the hassle though once you're flying.
 Perry, Phil wrote:
  	  | Quote: | 	 		   I’m not sure if it’s possible, but I’ve been thinking of adding one
  Phil
  *Sent:* Monday, February 01, 2010 7:48 AM
  *To:* rv10-list(at)matronics.com
  *Subject:* Fuel Filter Service - Access Panel
  N44YH - Flying
  *http://www.matronics.com/Navigator?RV10-List*
  *http://forums.matronics.com*
  *http://www.matronics.com/contribution*
		jkreidler
				 Posted: Mon Feb 01, 2010 6:43 am    Post subject: Re: Fuel Filter Service - Access Panel |
				I think there are times, especially when the airplane is new that you need to get into that area besides annual.  During annual EVERY panel needs to come off, I don't think there are many or any exceptions this would not change that.  I agree a person would need to think about the structure when cutting in access panels, but be aware cutting an access panel in the side of the tunnel requires the same thought.
 Like I said, I am not sure how we will handle this, or if we will even make a mod.  I just wanted to give those still building a chance to think about a possible mod while it was still fairly simple to implement.  Knowing what I know now, I can promise that if we had known about this we would have done something (again not sure what) during construction.
				 Posted: Mon Feb 01, 2010 7:03 am    Post subject: Fuel Filter Service - Access Panel |
				Each tank , IIRC, already has a filter screen. Additionally  one can see the fuel flows for various power settings on the EFIS, so some  indication of a future problem may be evident. Lastly drain/flush  the main  tanks
 after the build process. Mine were QB tanks but still had residual pieces of proseal which I flushed before sending any fuel to the filter.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry,  Phil
 Sent: Monday, February 01, 2010 7:18 AM
 To:  rv10-list(at)matronics.com
 Subject: RE: Fuel Filter Service -  Access Panel
 Phil
 N44YH - Flying
 0   [quote][b]
		dmaib(at)mac.com Guest
				 Posted: Mon Feb 01, 2010 7:25 am    Post subject: Fuel Filter Service - Access Panel |
				I was dreading taking the fuel filter out during the first condition
 inspection back in November. It was a PITA, but not as bad as I had
 feared. Some certified airplanes have an access panel on the belly
 just for this reason. I think this would be the best solution, but as
 others have noted, some structural engineering support would be
 required. I am not convinced that an access panel in the side of the
 tunnel would make the task that much easier, and as Jason notes,
 still has structural considerations. If I was doing it over again, I
 would consider the belly access panel.
 $.02 worth
 David Maib
 40559
 flying
 On Feb 1, 2010, at 9:43 AM, jkreidler wrote:
  <jason.kreidler(at)regalbeloit.com>
 thought.
 Jason Kreidler
 http://forums.matronics.com/viewtopic.php?p 84343#284343
				 Posted: Mon Feb 01, 2010 7:36 am    Post subject: Fuel Filter Service - Access Panel |
				Drained and flushed my QB tanks during the build and did not have any appreciable debris. That was even after having to replace an end rib in one of the tanks due to a builder stupidity induced problem. I noted during the first condition inspection that my fuel filter was perfectly clean.
 David Maib
 4059
 flying
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Perry, Phil
 Phil
 From: jason.kreidler(at)regalbeloit.com [mailto:jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)]
 N44YH - Flying
 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler0123456789
 01
		rnewman(at)tcwtech.com Guest
				 Posted: Mon Feb 01, 2010 5:03 pm    Post subject: Fuel Filter Service - Access Panel |
				Although I'm not flying yet, can't comment on how  this will work out.   However, I added an acces panel of my own  doing.    See attached link to picasa site.   http://picasaweb.google.com/rcnewman64   click on folder for "fuel pump and access door"    Note,   I'm using the andair fuel pump and have moved the filters/gas colators to the  wing.   I'm not planning on needing to get into the pump area except  for inspections.
  Bob Newman
  40176
  [quote]   ---
		johngoodman
				 Posted: Tue Feb 02, 2010 7:28 am    Post subject: Re: Fuel Filter Service - Access Panel |
				 	  | Quote: | 	 		  I’m not sure if it’s possible, but I’ve been thinking of adding one filter at each wing root.
 Phil  |
 Phil, it is possible and I'm doing it. Take a look at this filter for $28.95 from Summit Racing. Very small and filters to 40 microns:
 http://www.summitracing.com/parts/SUM-230101/
 John
  _________________ #40572 Phase One complete in 2011 |
