		Afterfxllc(at)aol.com Guest
				 Posted: Tue Feb 02, 2010 2:27 am    Post subject: Counter balance snag in the LAA drawings |
				I have just finished installing the counter balance upgrade and the LAA  measurements will not work as printed. If you lay out the new ribs to the 327.3  the counter balance weights will not clear the lower wingtip and will hang out  of the wingtip if you install the weights on the outboard side of the square  tube.
 The plans don't show this but the fix is either move the ribs 200  mm inboard or making the ribs 90 degrees of the hinge line.
 for those of  you that have already rivited them as to the drawings you will have to install  all but one of your weights inboard and one of the thin weights outboard to keep  the tube from crushing.
 Have Fun
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		chris Sinfield
  Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
				 Posted: Wed Feb 03, 2010 12:55 am    Post subject: Re: Counter balance snag in the LAA drawings |
				I wonder why you are now seeing this when there are other planes out there with the LAA mod in place?/ out and flying?
 anyone else find this out when doing their LAA balance mod?? AMD? Zenith? LAA??
 hope we can find an answer to this before I get up to it..
 Chris..
		Ron Lendon
				 Posted: Thu Feb 04, 2010 10:22 am    Post subject: Re: Counter balance snag in the LAA drawings |
				I think the confusion comes from using the Zenith supplied User Guide.  If you follow the actual LAA prints it should work out much better.
 This one caught me also and I canted the ribs to gain room. I will find out tonight if that will fix the issue.
  _________________ Ron Lendon
CH 601 XLB
N601LT  - Flying
Corvair Engine Prints:
				 Posted: Thu Feb 04, 2010 12:07 pm    Post subject: Counter balance snag in the LAA drawings |
				No Ron if you use the LAA drawing they DON'T work. Roger didn't follow  the drawings and placed his at 90 degrees so he had much more room from the  wingtip. If you look at the photo guide you will see in his aileron the bottom  rivet line is very close to the trailing edge outboard tip. If you use the LAA  drawing measurements it is further away thus putting the tube closer to the  wing tip.
  Jeff
   In a message dated 2/4/2010 2:17:36 P.M. Eastern Standard Time,  ron.lendon(at)gmail.com writes:
   	  | Quote: | 	 		  -->    Zenith601-List message posted by: "Ron Lendon"    <ron.lendon(at)gmail.com>
 Ron Lendon, Clinton Township, MI
 WW Corvair with    Roy's Garage 5th bearing
 Zodiac XL, ScrapBuilder
 Read this topic    online    here:
 http://forums.matronics.com/viewtopic.php?p=284858#284858===============================================
 _-=    Use the  ties  Day  ================================================               - MATRONICS WEB FORUMS  ================================================             - List Contribution Web Site  sp;                             ===================================================
		Ron Lendon
				 Posted: Thu Feb 04, 2010 8:48 pm    Post subject: Re: Counter balance snag in the LAA drawings |
				It doesn't matter who is wrong here.  The fix I am going to apply is to bend the arm about 2.5" towards the fuselage.  It was EAA chapter 13 night and some good ideas came out about how to move the bar without tearing the aileron down again.
 Going to make a form to make the bend that will keep the bar boxed while forming with clamps.  Pictures and dimensions to follow.
CH 601 XLB
N601LT  - Flying
				 Posted: Thu Feb 04, 2010 8:56 pm    Post subject: Counter balance snag in the LAA drawings |
				Ron
  If you do what I did and Roger suggested all you have to do is put all the  weights but 1 inboard.
  Then it fits without bending the tube.
  Jeff
   In a message dated 2/4/2010 11:50:18 P.M. Eastern Standard Time,  ron.lendon(at)gmail.com writes:
 http://forums.matronics.com/viewtopic.php?p=284928#284928===============================================
		Ron Lendon
		Ron Lendon
