planecrazzzy Guest
Posted: Wed Apr 12, 2006 3:22 pm Post subject: Hey Big Lar...Vamoose update ??? |
Hey Big Lar,
It's been a while since we got an "update"....
What's the latest with yer Bird...?
Are ya "sneakin it out" and flying it.....
Gotta Fly...
Mike in MN / N381PM
biglar
Posted: Thu Apr 13, 2006 4:33 pm Post subject: Hey Big Lar...Vamoose update ??? |
I guess you must be psychic. Over the last few days I've installed the
vented valve covers and the stock oil pressure controls. Started Vamoose up
and the oil poured out - again, tho' I do think the volume was a little
less. Came inside, cussed more than a bit, checked my email to help cool
off, and this message was looking at me. Drained the oil tonight and will
pull the redrive this weekend. Again. Getting (??) tired of it. Wish I
could afford a 912.
All that said, and having had a day to cool off, I realize it's got to be
something simple, but it IS aggravating. This time, I'm going to pull the
flywheel, too, and measure and check everything that could possibly pass
oil. This WIll be solved. Lar. Do not
Archive.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
planecrazzzy Guest
Posted: Fri Apr 14, 2006 5:07 pm Post subject: Re: Hey Big Lar...Vamoose update ??? |
I wish I knew SOMETHING about those VW engines to help you out.....
OK , keep pluggin away...
Gotta Fly...
Mike in MN
biglar
Posted: Fri Apr 14, 2006 6:43 pm Post subject: Hey Big Lar...Vamoose update ??? |
Kin ya do anything 'bout laziness ?? Do not Archive.
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
"Vamoose" |
planecrazzzy Guest
Posted: Sat Apr 15, 2006 12:23 am Post subject: Re: Hey Big Lar...Vamoose update ??? |
Hey big Lar,
If you cooperate....I can try.
First, we'll start with 12V DC , if that doesn't get ya goin....
We'll go staight to AC ....say 120 ....240....480....
You know, you did all that work for years...now your SO CLOSE
That in itself should be really good motivation...just one small(er) oil leak
keeping you from flying.....Well, that and a mountain of paperchasing...
Gotta Fly...
Mike in MN
| biglar wrote: | Kin ya do anything 'bout laziness ?? Do not Archive.
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
