				 Posted: Fri Feb 05, 2010 11:20 am    Post subject: Starter engaged light, was Starter   and contactor wiring |
				At 10:04 AM 2/5/2010, you wrote:
 <aerobubba(at)earthlink.net>
 Hi All-
 It's been a while since I went down my decision tree on this topic, and I
 might not recall all the details perfectly, but it seems to me that there
 are a couple details of 'starter engaged' annunciation that might have been
 overlooked.  First, it seems to me that the objective is to know whether
 there is power on the starter or not, so tapping the fat wire between the
 solenoid and  the motor would be in order.
     This is how it's done on TC aircraft when the
     feature is installed.
  	  | Quote: | 	 		  This would then annunciate that
 there was power to the starter motor itself.  It also has the advantage of
 monitoring the spin down of the motor.  Should the pinion hang and the
 motor remain engaged after the solenoid opens, the back emf can keep the
 engaged light illuminated.
     Not true. Every starter has an over-run clutch that
     prevents back-driving of the motor armature via a
     stuck pinion gear. This is especially important for
     modern, highly-geared starters where the armature
     is already running 4-6000 rpm while cranking the
     engine a couple hundred RPM.
     Without an over-run clutch, an engine idling at
     say 1000 rpm would either over-speed the armature
     perhaps to destruction from thrown windings or
     commutator bars or stripped gear teeth in the
     gearbox.
  	  | Quote: | 	 		  It might be especially zippy if one were to use
 a bi-directional led for the indicator, such that one could perhaps have
 amber indicate normal engagement and red to indicate run-on.
     If a starter WERE in a back-drive mode, the polarity
     of voltage would not reverse . . . hence the starter-stuck
     light would not change colors . . . only get much brighter.
  	  | Quote: | 	 		    Including a zener diode could clip the spin-down indication during
   normal operation while still allowing the run-on indication to
   function, should that become desirable.
     An interesting hypothesis but not consistent with
     either the physics of motor operations or with the
     configuration of starter drive-trains.
		jonlaury
				 Posted: Sat Feb 06, 2010 10:32 am    Post subject: Starter engaged light, was Starter   and contactor wiring |
				I am using a DPST momentary switch, with a lamp in  it that is switched independently, wired to the coil of a starter contactor for  my START button. I plan to wire the internal lamp to one side of the switch so  that it goes on when the START button is depressed and also have a parallel wire  going to the fat wire between the starter solenoid and the starter. So the lamp  will light when I depress the START button and will go out when it is  released...unless the starter solenoid is stuck closed and the fat wire between  the starter solenoid and the starter is energized.
  See any glitches?
				 Posted: Sat Feb 06, 2010 11:16 am    Post subject: Starter engaged light, was Starter   and contactor wiring |
				 	  | Quote: | 	 		  There was an airframe lost a while back due to a stuck contactor and the
 ensuing electrical fire, but that involved significantly different and more
 robust hardware.
     Do you have a source for more information on this
     event?
  	  | Quote: | 	 		  As ever, thanks for your help with the rectal-cranial inversion!
     No problem my friend . . . it's what we do . . .
