Recommended Letter-writing campaign, follow-up
Goto page Previous  1, 2
Juan Vega Jr
PostPosted: Sat Feb 06, 2010 4:31 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
funny how y'all are stil skirting the manauvering speed issue. So focused on protecting the flaw issue, I keep saying manauvering speed, everyone says, Huh?
too funny.
Juan
Juan Vega Jr
PostPosted: Sat Feb 06, 2010 4:38 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
SAbrina, by the way, any aircraft that is at gross Max weight and aft CG, will have a pitch sensitivity issue. There are some good case studies to review in AOPA's archives. Its just in the nature of every aircraft, even jets. MOre so in fighter aircraft, they are specifically made tail heavy, as they can pitch in a turn at the drop of a hat.
Zenith's issue I think with confidence, is that the folks flying it take it for granted, its just that easy a plane to fly. The plane needs to be slowed down to manauvering speed when in turbulance, and not flown over 103 mph when its rough out. if fully loaded, with full fuel, flying at 120 mph below the cloud line, the plane will make you pay in the form of not only a rough ride but possibly a dry cleaning bill.
Your good at math and research, check the numbers.
n801bh(at)netzero.com
PostPosted: Sat Feb 06, 2010 4:46 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Ya Know... I just have to chime in.
The Yuba City crash has extensive radar return data that clearly shows that plane going at or very close to the "MANAUVERING" speed... Tell us oh kind sir..... What broke that 601 XL apart. ????????
Ben Haas
N801BH
www.haaspowerair.com
psm(at)att.net
PostPosted: Sat Feb 06, 2010 5:01 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Hi Juan,
What you are saying is absolutely true. Unfortunately, it is true for every airplane design and not specific to the Zodiac XL.
Before you can convince me that there is no design problem in the XL you need to explain the unusually high failure rate of the XLs.
It is easy to make excuses like poor pilot training, poor maintenance, poor quality in the construction (although you need to explain the wide differences in factory and home built planes that have failed) or a lot of other possible problems like failure to reduce to Va in turbulence. In the end, these just muddy the basic question of why it is only Zodiac XLs that suffer from these problems.
Paul
sabrina
PostPosted: Sat Feb 06, 2010 6:55 pm    Post subject: Re: Recommended Letter-writing campaign, follow-up Reply with quote
ggower_99(at)yahoo.com
PostPosted: Sat Feb 06, 2010 9:56 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Also lets not forget Weather... Learning how to read, understand and avoid bad weather is as important (at least in mountain areas like ours) as learning how to fly.
Saludos
Gary Gower
--- On Sat, 2/6/10, Dan Wilde <dwilde(at)clearwire.net> wrote:
Subject: Re: Re: Recommended Letter-writing campaign, follow-up
Date: Saturday, February 6, 2010, 1:48 PM
--> Zenith-List message posted by: Dan Wilde <dwilde(at)clearwire.net (dwilde(at)clearwire.net)>
Sabrina wrote:
Trained, even over trained on this issue, might be a good thing.
I just read an article in a recent EAA newsletter that may pertain to this issue. The study found that the less you know about something, the more you think you know. The article was relating to UL pilots who would take just enough training to learn how to land and then stop taking lessons because they felt they knew enough to fly on their own. As a former UL pilot I saw this attitude more than once and also saw the tragic results.
Knowledge and training are good things and not to be avoided.
Dan p; --> http://www.matronics.com/Navigator?Zenith-List
sp; --> ht - List Contribution Web Site; &nb; http://========================
Juan Vega Jr
PostPosted: Sun Feb 07, 2010 10:36 am    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
to your last two quewstions, nope and nope
Juan Vega Jr
PostPosted: Sun Feb 07, 2010 10:45 am    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
if yu read the wind conditions at the time of the crash, the plane was on the leward side of the mountain with gusts up to30 +knots.
sincerley
Oh kind sir, Jr.
PostPosted: Sun Feb 07, 2010 2:46 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Yeah,, That's why a good pilot slows down to manauvering speed, The plane 'should' stall before the airframe breaks.. But the radar data showed a climb.. Hmmm,, maybe that's the way planes stall in california, they go up. <G>.
my last comment on this.
Ben Haas
N801BH
purplemoon99(at)bellsouth
PostPosted: Sun Feb 07, 2010 5:05 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Ben ,I'am with you ben same ole shit from the same old shit heads, day in and day out the exact reason that all you ever see is Kobe,KOBE ON THIS LIST ANY MORE, AT LEAST THEY HAVE SOMETHING CONSTRUCTIVE TO TALK ABOUT INSTEAD OF THE SAME OLD 5 YEAR Old crap Joe N101HD
From: "n801bh(at)netzero.com" <n801bh(at)netzero.com>
Sent: Sun, February 7, 2010 5:32:43 PM
Ben Haas
N801BH
Juan Vega Jr
PostPosted: Sun Feb 07, 2010 5:55 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
my emailing and beer drinkin judt dont mix. Who Dat!
Juan,
Page 2 of 2
