livair(at)bellsouth.net Guest
Posted: Fri Apr 14, 2006 5:08 am Post subject: R Wing needed for Firestar |
We need a right wing for a Firestar II? Anybody have an old one reasonably
priced? Uncovered and/or minor damage ok. I talked to the factory guys at Sun-N-Fun and they said try this list.
Eugene Zimmerman
Posted: Fri Apr 14, 2006 7:52 am Post subject: R Wing needed for Firestar |
On Apr 14, 2006, at 9:08 AM, <livair(at)bellsouth.net>
<livair(at)bellsouth.net> wrote:
reasonably
Uh Oh!
Sounds like there is a story behind this.
You probably should plan to rebuild the wing.
A good used wing will be very hard to come by.
Sometimes it is surprising how many parts can be salvaged.
Wishing you success,
Gene
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Fri Apr 14, 2006 4:04 pm Post subject: Re: R Wing needed for Firestar |
| livair(at)bellsouth.net wrote: | We need a right wing for a Firestar II? Anybody have an old one reasonably
priced? Uncovered and/or minor damage ok. I talked to the factory guys at Sun-N-Fun and they said try this list. |
If you can't find one, it's not a bad job to build one. It takes two 12 hour days, or one weekend, to build a wing up to covering.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
Livair
Posted: Fri Apr 14, 2006 7:15 pm Post subject: Re: R Wing needed for Firestar |
Are there other models that have the same wing? Is the Twinstar or Ultrastar wing by any chance the same?
John Jung
Posted: Sat Apr 15, 2006 6:48 am Post subject: Re: R Wing needed for Firestar |
| Livair wrote: | | Are there other models that have the same wing? Is the Twinstar or Ultrastar wing by any chance the same? |
I believe that the Mark II has the same wing as the Firestar II. But unless you find one close to you, the transportation costs could be more than rebuilding or building new. Doesn't hurt to search, though.
Firestar II N6163J
Surprise, AZ |
