		rv10rob(at)gmail.com Guest
				 Posted: Mon Feb 08, 2010 4:23 pm    Post subject: Installing main gear leg fairings first |
				Hi, all... I'm planning on doing my landing gear fairings after I'm flying.  That said, while I have the fuselage raised for installing the gear legs, I'd like to do the main gear leg fairings only, so I don't have to jack it up again later.  How feasible do you think it'd be to do the main gear fairings before doing the main gear pants?  From looking at the plans, it seems that If I attach the upper intersection (leg-to-fuselage) fairing, it'll fix the gear leg fairing in the correct alignment.  Only thing I can see being a problem is not knowing if the fairing needs to slide up or down the leg, since the pant is not installed.  Anyone think this would work?
  Thanks...
  -Rob
 Rob Kochman
 RV-10 "Finishing" Kit
 Woodinville, WA (near Seattle)
 http://kochman.net/N819K
		jkreidler
  Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
				 Posted: Mon Feb 08, 2010 5:58 pm    Post subject: Re: Installing main gear leg fairings first |
				Do yourself a huge favor and install the wheel pants, gear leg fairings, and both upper and lower intersection fairings before you put the wings on.  We are just finishing reworking the lower fairings because we took the 'after flying' approach.  Long story short we had to build new intersection fairings to get an acceptable fit.  Needless to say this was no fun with the wings in the way.  Not sure if just the upper will provide total alignment for you or not.
 I can say without a doubt, doing all of the fairings before the wings go on is a lesson learned, I really wish we had done it that way.
  _________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
				 Posted: Mon Feb 08, 2010 6:37 pm    Post subject: Installing main gear leg fairings first |
				I do not think installing the fairings from top to bottom is a good idea at all. Spend the time now while the plane is blocked up and do everything you can even is you don't make the first flights with the fairings. Obviously as others suggested C without the wings in the way C much easier to do them now..
 The fairings are pretty challenging and deserve a lot of effort and are worth that effort if the result is a good. Practice your geometry and get a laser.
 Date: Mon C 8 Feb 2010 16:18:53 -0800
 Subject: RV10-List: Installing main gear leg fairings first
 Hi C all... I'm planning on doing my landing gear fairings after I'm flying.  That said C while I have the fuselage raised for installing the gear legs C I'd like to do the main gear leg fairings only C so I don't have to jack it up again later.  How feasible do you think it'd be to do the main gear fairings before doing the main gear pants?  From looking at the plans C it seems that If I attach the upper intersection (leg-to-fuselage) fairing C it'll fix the gear leg fairing in the correct alignment.  Only thing I can see being a problem is not knowing if the fairing needs to slide up or down the leg C since the pant is not installed.  Anyone think this would work?
  Thanks...
  -Rob
 Rob Kochman
 Woodinville C WA (near Seattle)
 /www.matronics.com/Navigator?RV10-List
 .com
 tronics.com/contribution
		Jim Berry
				 Posted: Mon Feb 08, 2010 6:47 pm    Post subject: Re: Installing main gear leg fairings first |
				I agree with Jason that you should do all the gear fairings before you mount the wings. Even more important is to do them after you hang the engine. The weight of the engine will change the position of the gear legs. Also, the upper intersection fairings should be the last to go on. Establish the position of your wheel pants, then the main gear fairings, then the upper fairings.
 Jim Berry
 40482
 N15JB
		dmaib(at)mac.com Guest
				 Posted: Mon Feb 08, 2010 6:50 pm    Post subject: Installing main gear leg fairings first |
				Jason has it exactly right. You will be glad you have all of the
 fairings and wheel pants fit before you put the wings on. You don't
 need to have them installed for initial flying, but you will be might
 glad they are completed. Crawling around under the wings to try and
 fit everything will be no fun.
 David Maib
 40559
 flying
 On Feb 8, 2010, at 8:58 PM, jkreidler wrote:
  <jason.kreidler(at)regalbeloit.com>
 Jason Kreidler
 http://forums.matronics.com/viewtopic.php?p 85523#285523
				 Posted: Mon Feb 08, 2010 6:58 pm    Post subject: Installing main gear leg fairings first |
				Do yourself a favor, do them all NOW. When your flying.. fly  don’t go back and build again, believe me you'll be spending a fair amount of  time on the fairings. and it's better to do now than when everything is  installed.
  Pascal
  Sent: Monday, February 08, 2010 4:18 PM
  Subject: Installing main gear leg fairings  first
  Thanks...
  -Rob
 Rob Kochman
		Lew Gallagher
				 Posted: Mon Feb 08, 2010 8:06 pm    Post subject: Re: Installing main gear leg fairings first |
				Hey Jim,
 It's been quite a while back, but I thought I remember the instructions saying to align wheel and strut pants with the plane suspended -- no weight on the wheels (as it will be in the air) -- if so, then the engine being mounted or not shouldn't be a factor ... ?
 At any rate, I can't imagine getting everything level, centerline parallel to wheel lines, strings to the steps, etc. with the wings on.
 Later, - Lew
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
				 Posted: Mon Feb 08, 2010 8:43 pm    Post subject: Installing main gear leg fairings first |
				you are correct. It is supposed to be level, I think more of the flying
 config than ground config. It is actually easier to do it without the engine
 weight  and certainly before the prop, at least in my small garage it was
 anyway.
 Sent: Monday, February 08, 2010 8:06 PM
 Subject: Re: Installing main gear leg fairings first
  Hey Jim,
  Later, - Lew
  non-pilot
  Painting done!
  On with wiring and avionics.
  http://forums.matronics.com/viewtopic.php?p 85543#285543
		Jim Berry
				 Posted: Mon Feb 08, 2010 8:54 pm    Post subject: Re: Installing main gear leg fairings first |
				Lew,
 You are absolutely correct. I don't know how I could have forgotten all the fun I had getting the plane off off the gear and level. Sorry 'bout that.
 Jim Berry
		robertbrunk(at)mac.com Guest
				 Posted: Tue Feb 09, 2010 5:56 am    Post subject: Installing main gear leg fairings first |
				I have had to fly with my wheel pants off before and attached to the fuselage fairing , the alignment is maintained . Do not let anyone tow your main gear over an oversized chock. It will severely damage the wheel fairing.  Robert
 Robert E. Brunkenhoefer
 Brunkenhoefer Law Firm, P.C.
 520 Lawrence St.
 Corpus Christi, Texas 78401
 Phone: 361-888-8808
 Facsimile: 361-888-6753
 robert(at)brunklaw.com (robert(at)brunklaw.com)
 On Feb 8, 2010, at 6:18 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Hi, all... I'm planning on doing my landing gear fairings after I'm flying.  That said, while I have the fuselage raised for installing the gear legs, I'd like to do the main gear leg fairings only, so I don't have to jack it up again later.  How feasible do you think it'd be to do the main gear fairings before doing the main gear pants?  From looking at the plans, it seems that If I attach the upper intersection (leg-to-fuselage) fairing, it'll fix the gear leg fairing in the correct alignment.  Only thing I can see being a problem is not knowing if the fairing needs to slide up or down the leg, since the pant is not installed.  Anyone think this would work?
  Thanks...
  -Rob
 Rob Kochman
				 Posted: Wed Feb 10, 2010 9:27 am    Post subject: Installing main gear leg fairings first |
				Thanks, everyone... not the answer I wanted to hear, but sounds like it'd be
 better in the long run to do the fairings now.
 -Rob
 On Mon, Feb 8, 2010 at 6:58 PM, Pascal <rv10builder(at)verizon.net> wrote:
 [quote]  Do yourself a favor, do them all NOW. When your flying.. fly don’t go
