Pitot heat relays
flylists(at)dbarrett.net
PostPosted: Wed Feb 10, 2010 7:35 am    Post subject: Pitot heat relays Reply with quote
I've been looking at relays for pitot heat and landing lights, and have
found several that look to me like they might work. 20A should be sufficient
but the 40A version has mounting tabs to secure them behind the panel. Here
are representative specs:
http://www.azettler.com/pdfs/az977.pdf
http://www.azettler.com/pdfs/az973.pdf
http://www.azettler.com/pdfs/az9731.pdf
http://www.azettler.com/index.php?id=electromechanical_relays_other2
Are there specific things I should be concerned about when specifying relays
for this application? Is a sealed relay recommended in the cockpit?
Resistors/diodes across the coil are available but not generally in stock.
(I can add the diode if necessary here.) The cost is < $2 in single units
http://www.onlinecomponents.com
http://www.onlinecomponents.com/buy/AMERICAN-ZETTLER/AZ9731-1A-12DC1/
They have a $35 minimum order, but I'm sure I can find other things to fill
out the order.
David Barrett
sprocket(at)vx-aviation.c
PostPosted: Wed Feb 10, 2010 9:42 am    Post subject: Pitot heat relays Reply with quote
These are standard automotive relays. If you don't want to place the
minimum order, pick one up at your favorite auto parts store.
I use devices that have internal resistors (or diodes) because it saves a
bit of wiring-- but have 14 of them in my aircraft [another long topic about
switch failures vs relay reliability].
You can also purchase relay sockets that make installation a bit easier, if
you wish.
Vern Little
Vx Aviation
Sent: Wednesday, February 10, 2010 7:26 AM
To: <aeroelectric-list(at)matronics.com>
Subject: Pitot heat relays
sufficient
Here
relays
fill
out the order.
David Barrett
Checked by AVG - www.avg.com
07:35:00
pestar
PostPosted: Wed Feb 10, 2010 1:07 pm    Post subject: Re: Pitot heat relays Reply with quote
Vern
What manufacturers relays are you using where the diodes are built in?
Peter Armstrong
Auckland, New Zealand
PostPosted: Thu Feb 11, 2010 6:19 am    Post subject: Re: Pitot heat relays Reply with quote
Both Digikey and Mouser have diodes and relays. Search their websites for this part number: G8JN-1C6T-F-DC12 made by Omron. It has a metal one-hole mounting bracket and is weather proof. Here is the data sheet:
http://www.components.omron.com/components/web/PDFLIB.nsf/0/39018354E59A56C985257201007DD68C/$file/G8JN_0607.pdf
I thought it interesting that the normally open contacts have a higher current rating than the normally closed contacts, maybe because magnetism closes contacts quicker and tighter with less bounce than a spring does.
Joe
Joe Gores
dfritzj(at)yahoo.com
PostPosted: Thu Feb 11, 2010 6:55 am    Post subject: Pitot heat relays Reply with quote
I got mine from Waytek. I think they were Bosch.
Dan
pwmac(at)sisna.com
PostPosted: Thu Feb 11, 2010 9:02 am    Post subject: Pitot heat relays Reply with quote
Ford uses N2 filled, diode internal relays used for the glow plugs. A
handy source. I would have to check, but I bet NAPA sells the
identical part for less $$??
Paul
the data sheet:
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p 85935#285935
PostPosted: Thu Feb 11, 2010 2:11 pm    Post subject: Pitot heat relays Reply with quote
Here's what I'm using: Digikey 255-2161-ND
They have the built-in resistors.
Standard automotive type. Not having to wire in the diodes/resistors is a
big bonus. Also, the coils are polarity insensitive when using resistors
rather than diodes, if that matters.
Vern
Sent: Wednesday, February 10, 2010 1:07 PM
Subject: Re: Pitot heat relays
Vern
Peter Armstrong
http://forums.matronics.com/viewtopic.php?p=285873#285873
07:35:00
