ltaylor02(at)Chartermi.ne Guest
Posted: Sat Feb 13, 2010 6:34 am Post subject: STEWART SYSTEM |
I initiated the covering process of my Model IV yesterday using the Stewart System. The only covering experience that I have occurred during a two hour orientation session during Oshkosh last year. The Stewart system is amazingly straight forward and applies as advertised. I completed the horizontal stabilizer through taping as my first step. I'm really impressed with Stewart's very straight forward and common sense application process. The associated DVDs also prove very helpful; "see one-do one...!"
Lane Taylor
Long EZ
Kitfox Model IV progressing...
larry huntley
Posted: Sat Feb 13, 2010 7:49 am Post subject: STEWART SYSTEM |
It is great stuff to work with. I have covered with it for the last 5-6 yrs and will NEVER use anything else. Larry Huntley 4-1200 Soob
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
occom
Posted: Sat Feb 13, 2010 9:53 am Post subject: STEWART SYSTEM |
I'll chime with an enthusiastic approval also. Easy to learn, easy to use. Priced right and unbeatable support from Stewarts themselves.
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Sat Feb 13, 2010 5:16 pm Post subject: Re: STEWART SYSTEM |
How does it work for doing repairs?
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
larry huntley
Posted: Sat Feb 13, 2010 5:32 pm Post subject: STEWART SYSTEM |
It works very well for repairs and you can use it over any other process,
even on certified aircraft. (What did you break? ) (G) Larry
occom
Posted: Sat Feb 13, 2010 5:37 pm Post subject: STEWART SYSTEM |
The hardest part would be blending in the paint. the method is to sand
around the hole, glue on a patch and shrink the area over the hole. then
apply uv/fill and top coats.
larry huntley
Posted: Sat Feb 13, 2010 7:13 pm Post subject: STEWART SYSTEM |
Depending on where the patch is one can often paint an entire panel to match
paint better. I have painted the side of a fuselage from the trim stripe
down to the bottom longeron to cover a repair in the side of the fuselage.
Ekopoly ,does blend in to itself fairly well with the correct procedure and
it can be buffed,unlike some aircraft paints. Talk to Dan Stewart 509 679
8763. You will find him very helpful. Larry Huntley
Av8r3400
Posted: Sun Feb 14, 2010 4:31 am Post subject: Re: STEWART SYSTEM |
| larry huntley wrote: | It works very well for repairs and you can use it over any other process,
I'm looking at doing a recover of my model IV-1200 and was just wondering for future repairs. I know how it works with the Poly Fiber system, but I didn't think latex would bite into itself on a repair...
I'm really intrigued by the Stewarts system and would like to give it a try.
Av8r3400
YouTube Videos |
larry huntley
Posted: Sun Feb 14, 2010 5:08 am Post subject: STEWART SYSTEM |
I have a 4-1200 also on which I used Cub Yellow PolyTone. Some kind of bug
left green spots all over it that went right down to the fabric. I repainted
w/ Aerothane and a year later it looked the same. After dinging up the
fuselage in an "unscheduled landing" I recovered w/ Stewart's Cub Yellow and
put it in the same environment and it is still clean.
Dan can tell you how to make repairs and he will be very happy to talk to
you. Tell him I sent you. Larry Huntley
brubakermal(at)yahoo.com Guest
Posted: Sun Feb 14, 2010 7:07 am Post subject: STEWART SYSTEM |
utube stewert systems and u will find several factory videos, and there are also several how to videos on EAA tutorial that will help mal
Malcolm Brubaker
Michigan Sport
Pilot Repair
LSRM-A, PPC, WS
(989)513-3022
--- On Sun, 2/14/10, Av8r3400 <theav8rweb(at)yahoo.com> wrote:
Subject: Re: STEWART SYSTEM
Date: Sunday, February 14, 2010, 12:31 PM
| Quote: | It works very well for repairs and you can use it over any other process,
