Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Sun Feb 14, 2010 3:32 pm Post subject: What a mess! |
I have my work cut out for me all those wires have to go somewhere. Started to install the panel today. The folks at Stein did a great job and installation has been pretty straight forward. There are a whole lot of wires that have to go somewhere. Spent 4.5 hours on my back running bundles and making connections and probably have another 4 hours to go. To those of you that may be a little older, a little wider, or less flexible than I my hat is off to you. This is quite a task and really uncomfortable, but it is good to see some progress. Only the plenum, cowling, wheel pants, and assembly to go. As many before me have said...90% done 90% to go.
Eric Kallio
N518RV
ricksked(at)cox.net Guest
Posted: Sun Feb 14, 2010 3:54 pm Post subject: What a mess! |
Eric,
Man up ya skinny bastard!!! We "REAL". men never complained...If you're at your ideal weight and are whining about fitting in the plane....change your diaper and wipe your tears!!! I still don't know how I did it...but I'll fly it tomorrow!!
Rick S
N246RS
Tim Olson
Posted: Sun Feb 14, 2010 5:03 pm Post subject: What a mess! |
Personally, I found building an RV-10 to be far easier than
losing 40 lbs. I'm still working on the pounds, but
the -10 is long done.
Tim Olson - RV-10 N104CD
ricksked(at)cox.net wrote:
Eric,
Rick S
N246RS
Posted: Sun Feb 14, 2010 5:35 pm Post subject: What a mess! |
Ditto!!! And my response was all in fun..just in case
Sent via BlackBerry by AT&T
AirMike
Posted: Sun Feb 14, 2010 8:45 pm Post subject: What a mess! = Geezer fraternity |
I found out that a long piece of wood placed over each seat station and screwed down helped. I then covered with a bunch of old pillows or a thin piece of ensolite helped me get through the wiring thing. Put the board down before any seat tracks are in place
_________________ See you OSH '18
Q/B - sold. |
