Roger.Mills(at)btinternet Guest
Posted: Mon Feb 15, 2010 2:15 am Post subject: GPS antenna mounted to instrument moduleGPS antenna mounted |
You can probably even mount it out of sight if you want to.
My GPS 496 antenna is mounted on an aluminium bracket on top of the radio stack so that the antenna surface is just below the top of the instrument module. It’s completely covered and still works perfectly – over 2 years I’ve never had any reception problems!
Roger Mills
Europa 141
Time:
10:25:36 PM PST US
"Gavin & Anne" <gavanne(at)iconz.co.nz (gavanne(at)iconz.co.nz)>
Subject:
GPS antenna mounted to instrument module | Quote: | | Hi Ron I have the Garmin 295 panel mounted and have the external aerial on top of the instrument panel looking through the windscreen in about the centre of the panel. Works very well and its slimline shape is not noticeable. | 01234567890123456789012
