Pneumatics
Goto page 1, 2  Next
harley(at)siriusconinc.co
PostPosted: Sun Feb 14, 2010 6:01 am    Post subject: Pneumatics Reply with quote
What have most of you been using for lubricating oil?
Martin Mattes
Re: Regarding winterizing I meant charging pneumatic system with alcohol-oil
mix for winter cold proofin
You have to check with Yak 52 maintenance manual first.
I did it but it was long time ago (more then 20 years) and I may be wrong at
some points. Procedure is the same when you are doing regular maintenance
check. First, this should be special lubricant which pneumatic system is
usually charged with (white clear oil, you can fill its smell when you
retract/extend the gear in flight) Second, alcohol 96% Proportion,
volume????(do not remember exact number, 100-150gr/, 50/50 ) Charging:
Discharge air, disconnect Air tank and inject mix in line pipe, connect it
back. (Ones you are doing this drain water condensate from the air tank)
Charge the system with air. Then very important moment: Jack up the plane
,retract and extend gear few times, let this mix spread inside of the
system. That is what I can remember 20 years later.
But it is always better to check with manual.
Vadim
tigeryak18t
PostPosted: Sun Feb 14, 2010 1:54 pm    Post subject: Pneumatics Reply with quote
It is a mix of 50% 100% Ethanol (not easy to find but you can order it from a good drugery) and 50% glycerine.
Then the advice of my experienced russian mechanic  is not to spill it allover the main air system but to put  a few cc (written into the maintenance manual) into the landing gear actuator.
So you know where it goes..
If you don't have the maintenance manual I can search it for you.
Didier
2010/2/14 Martin (Home) <harley(at)siriusconinc.com (harley(at)siriusconinc.com)>
--> Yak-List message posted by: "Martin (Home)" <harley(at)siriusconinc.com (harley(at)siriusconinc.com)>
Martin Mattes
Re: Regarding winterizing I meant charging pneumatic system with alcohol-oil mix for winter cold proofin
I did it but it was long time ago (more then 20 years) and I may be wrong at some points. Procedure is the same when you are doing regular maintenance check.  First, this should be special lubricant which pneumatic system is usually charged with (white clear oil, you can fill its smell when you retract/extend the gear in flight) Second, alcohol 96% Proportion, volume????(do not remember exact number, 100-150gr/, 50/50 ) Charging: Discharge air, disconnect Air tank and inject mix in line pipe, connect it back.  (Ones you are doing this drain water condensate from the air tank) Charge the system with air.  Then very important moment: Jack up the plane ,retract and extend gear few times, let this mix spread  inside of the system.  That is what I can remember 20 years later.
Vadim
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
le, List Admin.
Didier BLOUZARD
didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)
0624243672
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
Vic
PostPosted: Sun Feb 14, 2010 4:44 pm    Post subject: Re: Pneumatics Reply with quote
Hello,
truck garages should offer an antifreeze as trucks usually have pneumatic brakes. So this should be the right stuff that could possibly include some sort of lubricant for the seals as well.
Vic
radiopicture
PostPosted: Sun Feb 14, 2010 4:52 pm    Post subject: Pneumatics Reply with quote
There is something called brake line anit-freeze that we use on
airport trucks and blowers. I would NOT assume that it's suitable for
the air system in a Yak / CJ. Is this really necessary? Winter is
almost over.
If it's long term and there's a lot of snot in there, there is some
danger of bollocksing up shuttle valves.
On Feb 14, 2010, at 7:44 PM, Vic wrote:
Hello,
Vic
http://forums.matronics.com/viewtopic.php?p=286453#286453
N13472(at)aol.com
PostPosted: Sun Feb 14, 2010 4:58 pm    Post subject: Pneumatics Reply with quote
Ok what in the hell is a (bollocks)?
Tom Elliott
CJ-6A NX63727
702-595-2680
radiopicture
PostPosted: Sun Feb 14, 2010 5:13 pm    Post subject: Pneumatics Reply with quote
Screw up, foul up, gum up. I this case, uncleared air system snot
(which I think consists of water, oil and glycerine) can sit in the
body of the shuttle valves thereby getting it stuck. The front-rear
gear valve is more susceptible, and there is also a main-emergency
valve. This from memory. Dennis, Doug and their ilk can verify or
correct.
Tom Elliott
CJ-6A NX63727
702-595-2680
radiopicture
PostPosted: Sun Feb 14, 2010 5:20 pm    Post subject: Pneumatics Reply with quote
Bollocks is a general expletive used by British types. Probably a
suitable substitute for the F-bomb. Example: "This Lucas electrical
system is all bollocksed up. Why did we still use cloth insulation in
the 70's?"
Tom Elliott
CJ-6A NX63727
702-595-2680
PostPosted: Sun Feb 14, 2010 5:35 pm    Post subject: Pneumatics Reply with quote
winter is just starting in Canada... the coldest I got her started was 26F
(-3C) without the "shower of sparks" ...its has never worked (replaced the
coil, the rotor...etc) and yes we freeze our ass off once airborne.....
wise(at)txc.net.au
PostPosted: Sun Feb 14, 2010 5:53 pm    Post subject: Pneumatics Reply with quote
Hi All,
When we do the 100 hourly or annual, whichever comes first, we jack the
aircraft and carry out the emergency valve operation, which lowers and locks
the undercarriage..
To get things back to normal one depletes the air in the system with valves
closed by squeezing the brake lever.
Thus a fair amount of air is used and the system has to be recharged.
When recharging we put a small amount of light machine oil in the system and
the air going in spreads this around.
We have stripped and checked our uplocks and they were in top condition, no
sign of rust or pitting.
This would be a good indication of the condition of the rest of the
Pneumatic components.
I have heard of undercarriage failure, either left or right, due to the
uplocks failing. In one instance retaining nut let go due to rust or
corrosion.
If never checked, would strongly recommend doing it as it is not difficult.
Had new seals made as original seals were a bit brittle.
Have just received the Kimball oil shut off valve and scavenge pump.
Aircraft stood for 3 weeks and have lock due to oil bypassing non return
valve.
Oil level is down.
Believe that the oil shut off valve will fix this.
We already have manifold drain.
Cheers,
Chris Wise
dsavarese0812(at)bellsout
PostPosted: Sun Feb 14, 2010 6:10 pm    Post subject: Pneumatics Reply with quote
On the Yak 52, shuttle valves have hard, rubber balls inside them. The shuttle valves move only when the emergency air valve is turned on. The original shuttle valves on the CJ (not Doug's replacements with SS balls inside) can easily rust and corrode and definitely cause problems. The front and rear gear selectors can corrode and cause air leaks. Particularly the rear gear selector because no one operates the gear from the rear cockpit. Most people don't even do a gear retraction test using the rear cockpit selector during the annual condition inspection. Then one day the darn thing starts to leak and bingo, you now have a pain in the rear problem of replacing it. The extremely hard to find parts are the pipe to M12 metric flare fittings. If you tear one of them up trying to remove it from the old selector, you're in deep do-do because they are very hard to come by.
Dennis
N13472(at)aol.com
PostPosted: Sun Feb 14, 2010 6:11 pm    Post subject: Pneumatics Reply with quote
OK! Now I know! When you use it with the word LUCAS all is clear. Besides
the F word working
on a LUCAS system I have created many new appropriate words.
Tom Elliott
CJ-6A NX63727
702-595-2680
radiopicture
PostPosted: Sun Feb 14, 2010 6:15 pm    Post subject: Pneumatics Reply with quote
Preheat I hope... MInimum engine temp for the M-14P is 41F, right?
Buffalo, NY area here. Ready for spring.
I did make a groovy cowl heater with a disk heater from Harbor Freight
and some off the shelf HVAC duct parts. I had considered using some of
these heating pads available from farm supply places (really cheap),
but there are so many things to heat. This convection method is pretty
rapid, and covers everything except the oil cooler. With the 25-60 oil
in there, I seem to get away with it.
was 26F (-3C) without the "shower of sparks" ...its has never worked
(replaced the coil, the rotor...etc) and yes we freeze our ass off
once airborne.....
radiopicture
PostPosted: Sun Feb 14, 2010 6:19 pm    Post subject: Pneumatics Reply with quote
Why do the British drink warm beer? Because they have Lucas
refrigerators. Old one, I know.
Besides
the F word working
Tom Elliott
CJ-6A NX63727
702-595-2680
PostPosted: Sun Feb 14, 2010 6:21 pm    Post subject: Pneumatics Reply with quote
Have you replaced the actual "shower of sparks" (starting coil) unit? It is located on the back side of the firewall above and to the left of the over voltage protection unit. It could also very easily be the starting coil wire itself. Seen this many times. You will need to purchase 5 mm wire to replace it.
You can check the spark by first making sure the main air is off. Next, squeeze off all the air in the system using the brake handle. When it no longer goes "swish" when you release the brake handle, move to the next step. Now remove the starting coil wire from the left magneto cap. Place the end of the starting coil wire about 1/2" from any metal on the engine. Now turn on the BATT and IGN switches in the cockpit and press the start button. It would be best to have someone look at the end of the starting coil wire to check the spark. It should jump about 1/2". It doesn't, do you hear the starting coil buzzing when you press the button? If yes, replace the starting coil wire and see if that doesn't fix your problem. Also while you have the mag cap off, clean the contacts, particularly the starting coil contact and clean the ring around the outside of the rotor cap. Its where the starting coil contact comes in contact with the rotor. If the starting coil wire doesn't fix the problem, order a starting coil from Doug Sapp. The CJ's starting coil is identical (even has the same part number stamped in the case as the Russian unit) to the Russian unit.
Dennis
PostPosted: Sun Feb 14, 2010 6:23 pm    Post subject: Pneumatics Reply with quote
What about doing a gear retraction during the annual from the rear cockpit?
Dennis
radiopicture
PostPosted: Sun Feb 14, 2010 6:34 pm    Post subject: Pneumatics Reply with quote
I do a whole multi-step process that some clever person wrote that includes purging the system of air until the (fart?) valve releases. It also includes a stage where the less powerful emergency system is blowing the gear down while the main system is selected to up. The gear is partially down at that point, and that lets you move the gear a bit by hand, which I guess might reveal some issues you wouldn't otherwise detect. That list ddoesn't include cycling the gear from the back, but I always do that before and after the aforementioned process.
On Feb 14, 2010, at 9:22 PM, A. Dennis Savarese wrote:
[quote]What about doing a gear retraction during the annual from the rear cockpit?
Dennis
[quote]---
william(at)netpros.net
PostPosted: Sun Feb 14, 2010 7:12 pm    Post subject: Pneumatics Reply with quote
I know in my YAK-55 the snot builds up and causes the check valves to
leak .... so the system does not maintain pressure for more than two
weeks and I have to charge the system from a SCUBA tank. I know it's
time to disassemble the tubing and clean things in gasoline when she
loses pressure over a week.
correct.
>Tom Elliott
>CJ-6A NX63727
>702-595-2680
correct.
>Tom Elliott
>CJ-6A NX63727
>702-595-2680
jan.mevis(at)informavia.b
PostPosted: Sun Feb 14, 2010 11:23 pm    Post subject: Pneumatics Reply with quote
The product originally used by the Russians (sixties/seventies of the former
century) is not available anymore, and its content is unknown. What the
Russians and the Lithuanians advise now, is a 50/50 volume mixture of very
clean glycerine and 96% ethylalcohol, only a few cubic centimeters per
actuator. The Russians started using this mixture in the eighties and they
loved doing this work, because they could order somewhat more ethylalcohol
and use it for their own home-made wodka (at least this has been told to me
by a Russian mechanic).
The Russian and Lithuanian mechanics insert it straight into the actuators,
using an injection needle and at the same time pumping with the gear leg to
suck it in.
Jan RA2005K YK50
dougsappllc(at)gmail.com
PostPosted: Mon Feb 15, 2010 8:28 am    Post subject: Pneumatics Reply with quote
Guys,As many of you know up until 2008 one of my duties in life was to preserve flowers (Riverview Floral LTD), primarily Gypsophila, which is a small wildflower used mainly as a filler flower in bouquets and floral arrangements.  Without boring you with all the biology, and chemistry involved, I'll get to the nuts and bolts of the process.  We normally would use 5 to 7000 gallons of USP grade Glycerine annually.  Glycerine is both a humectant (absorbs water), and a plasticizer which lends flexibility to the product once introduced into the cellular structure of the plant.
Alcohol also has the ability to absorb moisture, so the use of these two items in limited amounts in the pneumatic system should be a good thing unless we have an 0 ring incompatibility problem with the Ethyl alcohol.  Glycerine is inert, so no worries there.  I say "limited quantities" because many of the gear actuators which I have been getting in for cores have most if not all of the high pressure grease washed out of them because of over lubrication with light machine or tool oil which was incorrectly injected into the system.
Do NOT mess with Methyl alcohol, it's very bad stuff, nerve damage, blindness, are only a few of the problems associated with the use of this chemical.
I have a limited amount of US Pharmaceutical Grade Glycerine which could be decanted into gallon jugs (it's in 55 gallon drums now).   Price is about $25.00 per gallon.  Weight is 10.41 pounds per gallon.
Always Yakin,
Doug
On Sun, Feb 14, 2010 at 11:22 PM, Jan Mevis <jan.mevis(at)informavia.be (jan.mevis(at)informavia.be)> wrote:
[quote]--> Yak-List message posted by: "Jan Mevis" <jan.mevis(at)informavia.be (jan.mevis(at)informavia.be)>
suck it in.
Jan RA2005K YK50
Goto page 1, 2  Next
Page 1 of 2
