edgraydallas
Posted: Mon Feb 15, 2010 5:05 pm Post subject: Kitfox-List Digest: 6 Msgs - 02/14/10 |
Seeking advice from all Kitfox builders and "experts". I am halfway through
a Kitfox IV (1994 kit) which I am building to put on amphib floats. I want
to install at least 100 hp., but may not have enough cash for a 912S. What
is the best alternative engine? I like the Raven 1300 but Jeron thinks it
may be too heavy. Cant afford a Jab 120. Hearing bad things about the Soob
(heavy, doesn't deliver hp, etc. Query No. ONE What engine is best for
10k?
No. TWO I want to make the outer wing bays removable to convert to a
speedster on demand. Has anyone done it, how is it done, what diff. in
performance? I'm thinking a tube with O.D. which slips in the spars I.D.
then held with pin and safety like the root. The kit contains two extra
ribs so I can build up the 2 outer bays separately
No. THREE What other changes make a speedster wing? Is it only the lower
surface baby ribs to maintain the airfoil of the ribs?
Ed Gray Dallas KII 582 30 hours now and vertical tail being enlarged to Mod.
IV size
