Fox5flyer Guest
Posted: Wed Feb 17, 2010 1:07 pm Post subject: Clear tubing |
I'm down for annual and I'm changing out my tubing for the sight gauges and vent lines. I have always used Tygon tubing (1/4"ID) and although it stays flexible, the best I can get from it is 2 years before it yellows so badly that it is no longer easy to see the fuel levels.
Can anyone recommend a tubing for this purpose that can stand up to auto gas and last a little longer than 2 years, or is this the best I'm going to get considering the circumstances?
Any input appreciated.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
taildragon(at)msn.com Guest
Posted: Wed Feb 17, 2010 4:46 pm Post subject: Clear tubing |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Have you tried that blue Bing alcohol resistant tubing from ACS?
Roger Lee
Posted: Wed Feb 17, 2010 5:43 pm Post subject: Re: Clear tubing |
I talked to 5 different tubing Mfg's almost 2 years ago and they all said the die in the auto fuel would turn their tubing brown over time.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Fox5flyer Guest
Posted: Wed Feb 17, 2010 5:49 pm Post subject: Clear tubing |
I'd considered that, but I didn't think that the fuel level would be very visible. Is that what you use?
Deke
Posted: Wed Feb 17, 2010 7:56 pm Post subject: Clear tubing |
I've used the blue tubing for sight gauges and header tank vent line over the past 4 years. It is easy to see in the right light. Just be sure to have a white back ground. I painted the inboard side of the tanks white and pasted a calibrated scale printed on clear sticky back to clear plexiglas that is mounted to the fuselage butt rib. Simple, cheap, looks fine and works great!
Fox5flyer Guest
Posted: Thu Feb 18, 2010 3:29 am Post subject: Clear tubing |
I kinda thought that was the case. Thanks, Roger.
Deke
Dick Maddux
Posted: Thu Feb 18, 2010 6:32 am Post subject: Clear tubing |
Deke,
I just replaced my fuel gauge tubing two days ago with a tubing that has a liner in it. Williams Aircraft sells the stuff and that is what he uses on his fuel sight gauge kit. I tried to fit the tubing on the barbed fittings last year but it waded up the lining so I used the Tygon tubing instead. It turned brown in a year. I don't want to use the blue tubing as it would be too difficult to see the fuel quantity.
Anyway, this time, I bought a quantity of this liner tubing figuring I would go through several pieces before I got it on. I then polished the barb fittings, applied some Dry Slide lubricant and, slid the tubing on without damaging the liner. This tubing is supposed to be for caustic chemicals,etc so hopefully gas won't turn hurt it. I will find out what kind of tubing it is today as I have a little of it left. I bought it on line. I also replaced the brass wire that is included with the kits. That was all tarnished up when I removed it. I have since replaced it with a stainless rod to hold the shape of the tube.Anyway,I hope this works better as, like you, I am tired of replacing it all the time.
I am also going thru a lot of work on my plane as part of my "annual.' I have replaced all the 17 mm water hoses and made a tool yesterday to pull the gearbox in order to reshim it. I only have 225 hrs on the engine but it is 15 years old and the box is starting to make a little noise and is intermittently hanging up at about 1200 rpm on start as well as this running backwards business on shutdown sometimes. New Belleville (sp) washers and assorted parts are pretty sporty!
Dick Maddux
Fox 4-1200
912UL
Milton,Fl
Guy Buchanan
Posted: Thu Feb 18, 2010 9:57 am Post subject: Clear tubing |
At 01:04 PM 2/17/2010, you wrote:
| Quote: | | Can anyone recommend a tubing for this purpose that can stand up to auto gas and last a little longer than 2 years, or is this the best I'm going to get considering the circumstances? |
Deke,
I use the blue tubing with a white background and a red tube from a Chem-tool spray can inside. I can see the fuel level pretty well in daylight, though not as well, I'm sure, as new clear tubing. Next time I'll use stainless rod inside. My tube has not discolored, but I use 100LL exclusively. It has oxidized on the outside over the last four years which makes it a little harder to see through. I'll probably replace it when I re-engine this year.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Dick Maddux
Posted: Thu Feb 18, 2010 10:44 am Post subject: Clear tubing |
Deke,
The clear tubing I am using on my wing tanks is Tygon SE-200 . As mentioned earlier,this is the tubing Merle Williams uses in his kit.
Dick Maddux
Fox 4
Milton,Fl
Lynn Matteson
Posted: Thu Feb 18, 2010 12:15 pm Post subject: Clear tubing |
Whatever the stuff is that John McBean sells with his fuel level view
thing-a-ma-jig is good stuff. I've had mine on since the first of
2006 or before, and I've put (855 hrs x ~4 GPH=3420) 3420 gallons of
100LL through my tanks, and I can still see the fuel level. Some
things aren't worth being a pioneer over...John has done the legwork,
buy Kitfox.
Lynn Matteson
Jabiru 2200, #2062, 855 hrs (since 3-27-2006)
Countdown to 1000 hrs~145 to go(157 days to go)
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
On Feb 18, 2010, at 1:43 PM, Catz631(at)aol.com wrote:
| Quote: | Deke,
Dick Maddux
Fox 4
Milton,Fl
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Thu Feb 18, 2010 7:04 pm Post subject: Re: Clear tubing |
clear superthane works fine or urethane fuel line .
clear or blue but blue harder to see through.
simple
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Fri Feb 19, 2010 4:03 am Post subject: Clear tubing |
What John sells with his kit (I bought one too) is Tygon, or at least it was
when I bought mine from him, and it does OK with 100LL, but not auto gas.
I'm not really sure there is a product that will work and I may just have to
accept changing the hoses every couple years. Not a huge deal.
Deke
Fox5flyer Guest
Posted: Fri Feb 19, 2010 5:05 am Post subject: Clear tubing |
Thanks, Guy. I think the key here is the auto fuel has additives that discolor the urethane where the 100LL, without the same additives, seems to be gentler on it. At the cost of 100LL these days, I'll just change out the tubing every couple of years.
Deke Morisse
Mikado Michigan
Lynn Matteson
Posted: Fri Feb 19, 2010 6:01 am Post subject: Clear tubing |
Cost of 100 LL? I just got 290 gallons of the blue stuff delivered
for $3.70/gallon. Cheap when compared to all the problems encountered
with auto gas...but that's just me.
Lynn Matteson
On Feb 19, 2010, at 8:04 AM, fox5flyer wrote:
| Quote: | Thanks, Guy. I think the key here is the auto fuel has additives
Deke Morisse
N369LM |
Dick Maddux
Posted: Fri Feb 19, 2010 6:03 am Post subject: Clear tubing |
Lynn,
I had to change out the tubing I bought from John in one year. It was so brown that I could not see the fuel level anymore. That's why I am trying the Tygon SE-200. Hopefully it will work better. I only use auto fuel in my engine.
Dick Maddux
912UL
Milton,Fl
Fox5flyer Guest
Posted: Fri Feb 19, 2010 7:47 am Post subject: Clear tubing |
Where did you find your SE200? I can only find it in 50+ rolls.
Deke
lcfitt(at)sbcglobal.net Guest
Posted: Fri Feb 19, 2010 8:00 am Post subject: Clear tubing |
This revives a queation I have been mulling as I read this these posts. My
airplane had the heat bendable tubing once offered as standard with the
kits. Was it discontinued because of the giant plastic fittings necessary
for it's installation. I recall that these would loosen over time and leak
a bit - on a pretty regular basis. With the talk of the need to change out
the barb secured tubing, maybe tightening these giant fittings periodically
is not such a problem after all.
Lowell
Fox5flyer Guest
Posted: Fri Feb 19, 2010 9:22 am Post subject: Clear tubing |
Lowell, my sight gauges were previously what you are referring to. They
also discolored over time which is the reason I changed them out and
converted to the barb setup. However, I never had any leakage problems.
The barb and Tygon method is much simpler and a snap to change to new
tubing. It's that auto gas that is responsible for the discoloration, in my
opinion, which is all I burn.
Deke
pchristensen10(at)austin. Guest
Posted: Fri Feb 19, 2010 9:48 am Post subject: Clear tubing |
Damn, that's expensive. The nearest airport sells for $3.49.
Pete
Lynn Matteson
Posted: Fri Feb 19, 2010 11:42 am Post subject: Clear tubing |
Roger, Dick.
Lynn Matteson
On Feb 19, 2010, at 9:02 AM, Catz631(at)aol.com wrote:
| Quote: | Lynn,
Dick Maddux
912UL
Milton,Fl
N369LM |
