jpx(at)qenesis.com Guest
Posted: Thu Feb 18, 2010 11:42 am Post subject: Failure modes with Z12 |
I am still vacillating between Z13/8 and Z12.
I intend to use two electronic ignitions. The only thing that
concerns me is an overvoltage event that burns out both ignitions.
Probably very rare, considering the robust design, but perhaps a
lightning strike, or the failure of an overvoltage module ? Z12 would
isolate the two and alleviate my concern.
Second, I frequently cruise at 2200rpm and the output of the SD-8
would be only about 5A. For 0.8 pounds and $79 more, with an
insignificant balance improvement, I can buy a 40A and 20A alternator
instead, which is very tempting.
The concept of the essential bus diode is not used in Z12, so now we
get to my question. It appears that after a failure of either battery
contactor, there is no configuration to supply power to the
corresponding battery bus. So duration of flight is limited by the
battery capacity, rather than the capacity of the remaining alternator
to supply all the ships loads with the cross feed contactor engaged.
What change could be safely made to provide power to both battery
buses without negatively impacting other features of Z12 ?
Thanks !
Jeff Page
Dream Aircraft Tundra #10
Posted: Fri Feb 19, 2010 1:29 am Post subject: Failure modes with Z12 |
At 01:34 PM 2/18/2010, you wrote:
correct . . . not a useful point of concern . . .
| Quote: | but perhaps a lightning strike,
No guarantees at all for lightning strike. I'm pretty sure
Klaus hasn't included lightning immunity in his design
goals . . . and in any case, system architecture wouldn't
offer any 'protection' except for a few of the possible
energy conduction pathways. One just generally needs to
stay away from
| Quote: | or the failure of an overvoltage module?
Ov module failures don't cause ov conditions.
OV module failures would not catch and stop
an OV condition . . . AFTER a regulator failure.
That's dual failures on a single tank of fuel.
Exceedingly unlikely to the point
| Quote: | Z12 would isolate the two and alleviate my concern.
Z12 is a single system with two alternators. Z13/8
is a variation on the same theme. Only Z-14 provides
near-total isolation between separate systems . . .
assuming your willing to let this concern drive
you decisions.
| Quote: | Second, I frequently cruise at 2200rpm and the output of the SD-8
What are your design goals? Under conditions of
main alternator failure, could you NOT cruise as
fast as red line for the remainder of the flight?
| Quote: | The concept of the essential bus diode is not used in Z12, so now we
You must be talking about Z-14. Are you telling us that
both batteries are critical for sustained flight? What
loads are you running from each of the battery busses that
offers this condition?
Elegant system design eliminates all single points of
failure that put the mission at risk. You need to
make a list of the things you absolutely need to
continue flight to airport of intended destination.
For me, flying a spam can, that means shut down the
electrical system entirely and go to flight-bag
hand-helds. When I have the airport in sight, I've
got what ever the battery contains to finish the
flight.
The decision is not made by asking us for advice on
your concerns. The decision is driven by failure mode
effects analysis stacked against the equipment you
plan to carry on the panel and in the flight bag. Where
will those devices will get a couple hours of energy when
the alternator quits (which is increasingly rare).
Confidence only arises from a calculated Plan-B.
longg(at)pjm.com Guest
Posted: Fri Feb 19, 2010 8:09 am Post subject: Failure modes with Z12 |
Jeff,
Bob's last 3 paragraphs put everything together. The risk adverse
individual (my wife) will question every level and only accept one final
outcome - total assumed security. That isn't going to happen. Look at
all the GA wrecks in the last few days - yikes. In a few year we'll be
lucky if we're allowed to fly.
So let's talk about failure modes as Bob mentions below. For your
example assume the worst case which is probably over water, right? Ok,
personally I have two Klaus jobs (wow, this guy is famous - just the
mention of the name Klaus, I'm so jealous), any-who I have the SD-8 and
a Dynon with HSI. So everything goes to hell, Don't tell Bob but I use
two batteries with Z-13 like Klaus recommends to run one module, so live
it up. This battery is 4.5 ah (very small), but the Klaus job will run
down to 5 volts (now, you're heading for the Bahamas and both
alternators die (hardly likely unless you've been pouring sand into
them) halfway between Palm Beach and Bimini - oh sh*%).
Ok, with my 1-2 amp Dynon (internal battery) and my sometimes 3 amp SL30
I can still do a non-precision landing at Bimini after running for an
hour (the 50 miles or so) on battery(s). Everything else is off and my
Dynon is running on internal battery (that sucker runs min 1.5 hours
just on the internal 16 volts it has saved up, and oh, since I have two
Dynons I can then turn on the other one and..) When I get near Bimini, I
turn on the radio because I've been monitoring my progress as Bob
mentioned with my handheld GPS and spare batteries. Hell, if I'm really
nuts I can even use my handheld radio to talk to the Bimini approach.
The Klaus jobs won't know the difference and if you're really cocky you
can turn one off and pull 5 volts for several hours before even the 17
ah battery dies. If that's used up, I kill it and move to my backup 4.5
ah battery and skip over Bimini and keep going to Nassau.
You get the point. Once you get setup, you simulate this on the ground.
If your system is 100%, you'll be sitting in your plane a long time
waiting for the battery to give up.
Moral of the story - Keep the batteries in your toys fresh and you'll
keep flying. Batteries and oil are cheap, don't skimp on either.
| Quote: | From Bob N>
" Elegant system design eliminates all single points of
got whatever the battery contains to finish the
flight.
the alternator quits (which is increasingly rare)."
user9253
Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
Posted: Fri Feb 19, 2010 8:44 am Post subject: Re: Failure modes with Z12 |
| Quote: | | "I am still vacillating between Z13/8 and Z12." | If you are undecided, go with Z-13/8. It is simpler, costs less, and weighs less than Z-14 and is more reliable than most factory-built systems.
You are concerned about a battery contactor failure. How will you recognize that a battery contactor failure has occurred? There might not be any symptoms because the alternator would probably keep working. It would be necessary to monitor the battery voltage to recognize a problem. Even with a failed battery contactor, voltage on the main power distribution bus will be normal as long as the alternator keeps working. The low voltage warning light on the regulator does not warn of low battery voltage due to contactor failure.
If using Z-13/8, turning on the E-Bus Alternate Feed Switch will provide a parallel path around the contactor from the main alternator to the battery. Although voltage will be dropped across the diode and current is limited by the 15 amp fuse, it should be adequate for a fuel pump and ignition. In addition, the aux alternator is connected to the battery side of the main contactor. Multiple failures would have to occur before power is lost to critical engine ignition and fuel systems that are connected to the battery. You might consider connecting one ignition and fuel pump to the battery bus and the other set to the E-Bus. Doing so insures that one set will keep working in the event of a bad electrical connection.
What do you think Bob N.?
Joe
_________________ Joe Gores |
Posted: Fri Feb 19, 2010 10:17 am Post subject: Failure modes with Z12 |
At 10:44 AM 2/19/2010, you wrote:
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=287195#287195
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
user9253
Posted: Fri Feb 19, 2010 1:56 pm Post subject: Re: Failure modes with Z12 |
Bob,
I can not show you where you are wrong because you said nothing wrong and your electrical drawings are very hard to improve upon. Comments in my previous post were not meant to criticize or to suggest changes. I was only trying to explain how the circuit worked and that there is no reason to be overly concerned about a battery contactor failure in flight and that no changes to Z-13/8 are required for dual electronic ignition (other than to tap power from two separate points). When I asked for your opinion at the end of my previous post, I was asking for your approval and to correct anything that I may have said that was incorrect. I hope that you did not take it any other way. I have been reading the AeroElectric List for a couple of years and have learned a lot and respect your work and opinions. I commend you for offering free advice and taking time to answer electrical questions from home-builders.
Joe
Posted: Fri Feb 19, 2010 9:10 pm Post subject: Failure modes with Z12 |
| Quote: | When I asked for your opinion at the end of my previous post, I
Joe, I just re-read my posting. I'm sorry if
I sounded reproachful in any way. Please know that
it was unintentional. I abhor such behavior in
myself and discourage it in others. In fact, I think
I complimented your organization of the FEMA thought
process and attempted to amplify that stream of ideas.
To the best of my recollection, your postings have
always been helpful and technically accurate.
I value your participation on the List.
