Dave Pelletier
Joined: 10 Jan 2006 Posts: 100 Location: Prescott, Arizona
Posted: Mon Apr 03, 2006 11:57 am Post subject: Instrument Markings |
Kolbers,
I have an older MK III Classic and I'm in the process of marking my instruments for an airworthiness inspection but I don't know what the max Flaps Extend (Vfe) speed and the normal operating (Vsi to Vno) range (Green Band) should be. Vsi is 42 for my plane. HELP!
AzDave
_________________ AzDave |
pollus(at)fornerod.nl Guest
Posted: Tue Apr 04, 2006 1:34 pm Post subject: Instrument Markings |
Hi Dave
The flight handbook I got with my MK3C states (in german)
V(NE) = 145 km/h (= 78 knots) Zulassigge Hochstgeschwindigkeit
V(A) = 110 km/h (= 59 knots) Manovergeschwindigkeit
V(F) = 100 km/h (= 54 knots) Max Klappengeschwindigkeit
V(S) = 65 km/h (at)400 kg and flaps 30 degrees (= 35 knots)
Mindestgeschwindigkeit
So far this language course. I did the km/h to knots calculation
myself so you might want to double check the numbers.
Greetings from Holland
Pollus
Op 3-apr-2006, om 21:59 heeft Dave & Eve Pelletier het volgende
geschreven:
<pelletier(at)cableone.net>
Kolbers,
plane. HELP!
AzDave
Dave Pelletier
Posted: Tue Apr 04, 2006 4:42 pm Post subject: Instrument Markings |
Pollus,
Thanks, I now have to get out my conversion charts to see what they are
in mph, but that will be fun to do. But ok, ok, what is a
"klappenwhatchamacallit" and a "Mindesgesthingy"?
Dave
Hi Dave
Pollus
geschreven:
> Kolbers,
> plane. HELP!
> Thanks,
> AzDave
> Do Not Archive
Posted: Wed Apr 05, 2006 9:59 am Post subject: Instrument Markings |
Hi Dave
"Geschwindigkeit" is speed
"Klappen" = flaps
"Mindes" = minimum
I would be glad to translate it into dutch...
Do not archive!
Op 5-apr-2006, om 2:40 heeft Dave & Eve Pelletier het volgende
geschreven:
Pollus,
they are
Dave
> Hi Dave
> Pollus
> geschreven:
>> Kolbers,
>> plane. HELP!
>> Thanks,
>> AzDave
>> Do Not Archive
Dave Pelletier
Posted: Sun Apr 16, 2006 8:49 am Post subject: Instrument Markings |
A few of you had e-mailed me off list and asked to let you know what my instrument markings would be when everything is said and done so here they are: (Mk III Classic - 582)
Vne 100 Red
Vno 85 Yellow
Vsi 42 Green
Vso 38 White
Vfe 70 White
Someone (Brian Melbourne?) told me that you don't really need the yellow arc since the MK III is ok right up to Vne. Someone else (?) told me that the DAR's are used to seeing a yellow arc so I might consider putting it in to avoid a problem.
AzDave
