lmassaro(at)tac-eng.com Guest
Posted: Sun Feb 21, 2010 7:46 pm Post subject: Instrument panel (teamgrumman@AOL.COM) |
Nice panel...
Speaking of the Aspen...
I installed an Aspen and one side benefit is that it allowed me to
move my GNS530/NAV/COMM stack to dead
center of the panel. The Aspen DG/HSI is used as the primary for
ILS/GPS/WAAS approaches. I put the other head
and the tach on the other side of the GPS and use that for COMM 2 as
a secondary in the event the Aspen goes TU.
The VSI was sent to the great VSI graveyard in the sky and I moved
the steam AI to that spot.
The Aspen took a while to get used to but now I cant say enough good
about it. Of course YMMV.
Lawrence Massaro
'92 AG-5B KRNM
>Subject: Re: Instrument panel
>From: "cwleach" <corl(at)aya.org>
>Nice looking panel! The only thing I would
>add would be a manifold pressure gauge to the right of the tach,
and swap the
>JPI and nav head as Bill suggested.
>I put the Nav head next to the ... NAV RADIO! What a concept, huh!
>"In the clouds" I have GPS 1 showing the CDI and numerical ground
track and desired
>track information while GPS 2 shows the moving map display. In this way I
>can simply match the #1 displayed Actual Track with Desired Track
numbers, check
>the deviation from Course on the adjacent CDI, then adjust heading 1 or 2
>degrees to change the actual track to correct any error. I've found
the "digital
>approach procedure" to be far more accurate than chasing needles
anyway. YMMV.
>I only purchased 1 Nav head because eventually an HSI (Aspen?) will
replace the
>DG leaving the CDI for Nav 2. Why buy two when you'll be replacing
one soon-ish?
>My airplane seems to be getting heavy despite leaving stuff out!
>... just curious what true benefit a manifold pressure gauge would
serve other
>than to give Gary a little more $$ for installation costs?
