				 Posted: Fri Feb 19, 2010 8:59 am    Post subject: Alternitive Kolb Engines |
				Mike/All
  That would be interesting to have a engine spread sheet  but many would be unsuitable for our Kolb use.
  Generally speaking auto engines are too heavy and powerful  for Kolb use. Generator engines (Genrec and Onan) would seem to fit as options  because they are designed to run under heavy load but are normally a bit heavy  for the power they produce.
  I really like the concept of the Yamaha that Jason is  working with. After all Rotax originally modified snowmobile engines for  aircraft use. The biggest problem would be a supply issue for wide spread usage.  Not just engines but redrives also. Rotax doesn't like people using their  redrive on other engines.
  The R series BMW is another engine that shows  promise.
  I concur with Jason that there is a bunch of work  in converting engines to aircraft use especially if you are the first.
  New VW engines are available in unlimited  quantities at very reasonable prices for Kolb usage. Parts for maintenance are  also very inexpensive and available for the foreseeable future. The VW redrives  are also available and continue to evolve. Granted a gear redrive would seem to  be better and maybe a suitable one will be developed if there is  enough demand. For the time being the Valley belt redrive is a good  solution. One of the advantages of a VW conversion is that Great  Planes will put together a fairly complete engine package and Valley will  even build a complete "firewall forward" that you can test fly at their  factory. To my knowledge no one makes a off the shelf exhaust systems but  Larry Smith at Valley promised me they would offer them if there was demand.  Also Kolb will build VW engine mounts on your new Kolb or weld on mounts for  your existing Kolb. There are two more VW powered Kolb MKIIIs getting close to  flying. The VW experiment is getting more refined so the effort for  the next builders will be greatly reduced.
  I will be flying my VW powered Kolb MKIIIC to Sun-N-Fun  this year and camping with it all week
  Rick Neilsen
  Redrive VW Powered MKIIIC
  [quote]   ---
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ces308
  Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
				 Posted: Fri Feb 19, 2010 8:51 pm    Post subject: Re: Alternitive Kolb Engines |
				Hello gang....FWIW....I have 99. 2 hrs of absolutely trouble free hrs on my A-2200 Jabiru engine...I get 1000-1100 fpm climb on my M3X...it is smooth as silk...3-4 gph fuel burn...and basically maintenance free...I change oil and filter every 25 hrs and other that the the first few required adjustments at the beginning,that has been it. No monkey business mounting it or re-drives...just put it on and prop it...
 Just my 2 cents worth...Hope to see some of you guys this summer !
 chris ambrose
 M3X/Jabiru A-2200   99.2 + hrs
 N327CS
				 Posted: Mon Feb 22, 2010 7:20 am    Post subject: Alternitive Kolb Engines |
				Chris
 Yes I forget about the Jabiru.
 I'm relocating to the Oceana County Airport C04 when I return to Michigan
 this spring. I will make a point to stop in to see you this summer. Looks
 like you are about a hour away.
 Maybe we could have a small Kolb flyin this summer. Get Steve S, Jim S, Ted
 W, and you to fly over (also any one else that wants to join us). We could
 start a annual fly the sand dunes and Lake Michigan shore line.
 Rick Neilsen
		Arksey(at)aol.com Guest
				 Posted: Mon Feb 22, 2010 4:14 pm    Post subject: Alternitive Kolb Engines |
				Rick.
      you have a good idea....set up the fly in and count me in...grandma will be gald  to get me out of the house by then. Lake Michigan shore line and dunes sounds  good....I will poke up Ted W
  Jim  swan
  From:  Richard & Martha Neilsen <NeilsenRM(at)comcast.net>
 Sent: Mon, February 22, 2010 10:19:41  AM
 Subject: Re: Kolb-List: Re:  Alternitive Kolb Engines
 --> Kolb-List message posted  by: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net (NeilsenRM(at)comcast.net)>
 Chris
 I'm relocating to the Oceana County Airport  C04 when I return to Michigan this spring. I will make a point to stop in to see  you this summer. Looks like you are about a hour away.
 Maybe we could  have a small Kolb flyin this summer. Get Steve S, Jim S, Ted W, and you to fly  over (also any one else that wants to join us). We could start a annual fly the  sand dunes and Lake Michigan shore line.
 Rick  Neilsen
  do not  archive
 jim swan firestar ll 503 michigan
