		johnwigney(at)windstream. Guest
				 Posted: Mon Feb 22, 2010 8:13 am    Post subject: Europa door shoot bolts |
				Hi Vaughn,
 Am happy to hear that you are back on track with the project. How is
 progress?
 You were fortunate with the Tomahawk door. Re Europa doors, my
 experience is that mine opened up once a long time ago (rear bolt not
 engaged) just as I was lifting off at take off. I was able to gently set
 it back down without losing the door. Lucky me. I am now a bit anal
 about checking the bolts. I believe that if you fly with one bolt out,
 there may be no way you can stop the door opening or even think about
 relocking it. Just fly the plane.
 At the 2008 Sun N Fun, there was a prize winning Lancair which departed
 from the show. The photo at take off  (below) shows his front hinge
 canopy was open about 2" at the back edge. He crashed fatally about 5
 miles from the airport. Even at big shows you can always declare an
 emergency. This guy could have put it back down.  Moral = "Fly the Plane!"
 Cheers, John
 ORIGINAL MESSAGE/
 Subject: Re: Liberty XL Service Bulletin for Canopy Shoot Bolts
 I learned to fly in a Piper Tomahawk which used a similar system to secure
 the doors. It was pounded into my head to check both doors very carefully
 before taking of. On my long solo cross country I left Harrisburg
 International and as I turned to leave the pattern, I noticed more noise
 than usual. Sure enough the rear shoot bolt on my side was not engaged. I
 slowed to 10 knots above stall and trimed for level flight as instructed and
 was able to correctly shut the door. I was prepared to request permission
 and land back at Harrisburg had I not been successful because of the dire
 warnings from my instructor about not bringing the complete airplane home.
 Learning a lesson without dire consequences is most preferable. Learning
 from others mistakes is even better for you.
 Vaughn Teegarden
 A191 back in the building stage
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Jeff(at)rmmm.net Guest
				 Posted: Mon Feb 22, 2010 10:11 am    Post subject: Europa door shoot bolts |
				Hi Vaughn,
 I flew my bird to that show and was standing there watching that
 Lancair take off. When I turned to watch the next one leave he went
 down. Myself and some friends were sick when we saw the smoke from the
 crash. Even more so when they told us it was an open canopy.
 Before I hit the throttle both my hands push out on the rear, then the
 front of both doors making sure those shoot bolts are in. It is too
 bad but we all get caught up in trying to make a perfect landing or
 takeoff when on lookers are around. (Air shows etc.)
 Thats when check list are needed even more.
 Best To All!!
 Jeff R.  N128LJ Gold Rush... still down for annual but looking forward
 to the soon to be nice weather!
 On Feb 22, 2010, at 10:06 AM, John Wigney wrote:
  Hi Vaughn,
  progress?
  not engaged) just as I was lifting off at take off. I was able to
  gently set it back down without losing the door. Lucky me. I am now
  a bit anal about checking the bolts. I believe that if you fly with
  one bolt out, there may be no way you can stop the door opening or
  even think about relocking it. Just fly the plane.
  departed from the show. The photo at take off  (below) shows his
  front hinge canopy was open about 2" at the back edge. He crashed
  fatally about 5 miles from the airport. Even at big shows you can
  always declare an emergency. This guy could have put it back down.
  Cheers, John
  ORIGINAL MESSAGE/
  Shoot Bolts
  secure the doors. It was pounded into my head to check both doors
  very carefully before taking of. On my long solo cross country I
  left Harrisburg International and as I turned to leave the pattern,
  I noticed more noise than usual. Sure enough the rear shoot bolt on
  my side was not engaged. I slowed to 10 knots above stall and trimed
  for level flight as instructed and was able to correctly shut the
  door. I was prepared to request permission and land back at
  Harrisburg had I not been successful because of the dire warnings
  Learning from others mistakes is even better for you.
  Vaughn Teegarden
		rampil
				 Posted: Mon Feb 22, 2010 2:08 pm    Post subject: Re: Europa door shoot bolts |
				It's true I think that anyone who has flown small GA certified AC will
 have had an experience with an open door. As Shakespeare said,
 tis much ado about nothing, as long as the pilot remembers what
 to do (fly the plane) and what not to do (fight to close said door).
 Its one thing to have a Cessna door or window pop - nothing
 happens to the aircraft, pilots undergarments excepted.
 When a door open on a Europa or a Liberty, there is an excellent
 chance that the door will cleanly depart the airframe as has happened
 several times. There is a theoretical, but so far unseen possibility
 that the departing door will hit the empenage and damage an
 airfoil or control.  That is not a nothing event!
 My request for comments was actually a probe to start a discussion
 on whether the Europa community should look into doing the same.
 The port door on my airframe has long been deformed by heat while
 under the tension of the gas spring and has thus deformed so it takes
 some special effort to engage the shoot in the rear. This deformity
 was exacerbated by the door blowing off the hinges on the ground at
 Norfolk VA after a perfect ILS in a 40 kt crosswind coming home
 from SnF 2006. As soon as I opened the door at the gas pump,
 it pulled right out of my hand.  Actually, when
 closed, but not latched, the rear corner of the door is proud of the
 fuse by two inches or so, therefore I need a handle on the inside to
 pull it in.
 The Liberty mod probably will not do a thing for me, but
 it might help avoid someone else's accident.
 I am planning a trip to SnF this year (even though I promised myself
 I would not) and I will look at the new Liberty shoot bolts.
 I have it from reliable sources, that the close by establishment for the
 annual engineering meeting is now remodeled and open for business.
 Fly Safe!
		steven.pitt2(at)ntlworld. Guest
				 Posted: Tue Feb 23, 2010 12:05 am    Post subject: Europa door shoot bolts |
				Ira,
 I will be at Sun'n'Fun again with the Europa team, Jeff and Mary Behrnes and
 a couple of Brit Europa owners. Bud tells me that Europa have stands 90 and
 91 so engineering meetings will be on the agenda.
 Look forward to seeing you and any other Europa owners/wannabees in just
 over a month.
 Steve Pitt
 G-SMDH
		raimo.toivio(at)rwm.fi Guest
				 Posted: Tue Feb 23, 2010 6:48 am    Post subject: Europa door shoot bolts |
 To prevent this happen I have 4 x microswitches and green/yellow leds to warn unengaged shootbolts.
 Those leds are just in sight and it is almost impossibe not to see those yellow ones.
 During T.O.  I check if the ASI is operative and the leds are just beside it.
 Secondly, some of you may remember the pip-pins which secure the door levers to the door lever guards to prevent human errors (= unintentional inflight door opening).
 Raimo OH-XRT
