Alt Cb Pops
richard(at)talbots.net.au
PostPosted: Wed Feb 24, 2010 3:49 am    Post subject: Alt Cb Pops Reply with quote
G'day List,
I have a problem that my Plane Power alternator has started poping the
crowbar OV CB when I switch on the ignition. I have 90 hours so far
without too many issues.
I have checked wiring etc and run continuity checks. There is no
resistance in the wiring runs. The current draw is 10A through the CB
and it pops 3-5 seconds after switch on.
Any ideas? I think the internals might have failed. Could there be a
cheap fix?
Richard
Tim Olson
PostPosted: Wed Feb 24, 2010 9:15 am    Post subject: Alt Cb Pops Reply with quote
I'd start with calling them. They seem to be very good
at supporting people, so maybe they'll just take it in
and check/fix it.
Tim Olson - RV-10 N104CD
Richard Talbot wrote:
G'day List,
cheap fix?
Richard
PostPosted: Wed Feb 24, 2010 6:30 pm    Post subject: Alt Cb Pops Reply with quote
At 05:47 AM 2/24/2010, you wrote:
<richard(at)talbots.net.au>
G'day List,
Hmmmm . . . I think the breaker is 5A. A 10A draw
is indeed suspicious. The max draw on this wire
is generally no more than 3 to 3.5 amps engine stopped
and much less in flight.
cheap fix?
Probably not. Shorted turns in the field winding
are the most plausible hypothesis but I have a
hard time figuring out how this might happen.
You'll probably have to return it to PlanePower
for diagnosis . . . but if you have MEASURED a
10A draw before the breaker pops, then it's a
certainty that something is wrong inside
the alternator.
