Failure modes with Z14
jpx(at)qenesis.com
PostPosted: Sat Feb 20, 2010 1:54 pm    Post subject: Failure modes with Z14 Reply with quote
I received lots of response to this, so rather than copy the text of
four messages, I will continue with the pertinent pieces. I
appreciate the responses !
To start, I confused everyone, sorry. It is Z14, not Z12 that I am
considering (along with Z13/Cool, so that messed up the discussion a
lot, since my actual question was not directly addressed.
Also, I didn't mention which electronic ignitions I plan to use. I
intend to install E-Mag ignitions, not the Light Speed, but this
choice does not really affect the design.
I currently fly a 40 year old Cessna. longg(at)Pjm picked an excellent
example, since each spring my wife and I fly it from Toronto to
Bahamas to Sun n Fun and back, and other long trips as well. No
matter what design I select, it will be a far better system. However,
since I can do it better, I want to Wink
Joe described what I like about Z13/8 - pretty much any single
electrical failure permits continuation of flight to intended
destination. Power from the second alternator can be applied to any
chosen load in the airplane as needed, within the limits of the
current produced. I have spent quite a lot of times considering the
effects of various failures.
The only single failure I can think of that would cause a significant
problem is an over voltage event that the OV module didn't address in
a timely fashion, and the electronics in both ignitions fried. Bob,
your experience indicates this is a very unlikely occurance. Medical
statistics are the same way. I don't care how rare a disease is if I
am the one that has it. Then, in another post, you describe the
in-flight fire in a Lancair IV-P due to the abused regulator/OV unit
that I am planning on using Wink
An over voltage event is something I have no plan B for. A battery
operated radio is great, but there is no equivalent for the ignition.
Unlike a regulator and alternator, that I can easily see are working
throughout the flight, I have no way of knowing if the OV unit will
function as intended in the rare case I need it to. I do not have the
resources to analyze and test the design to be convinced it is
failure-proof. Of course, like any component, it is not, so I need a
plan B.
One way of addressing it, is two isolated systems running the
ignitions. So although I really like Z13/8, Z14 has possibilities.
Unlike Z13/8, Z14 has what seems to me to be a weakness. There is no
essential bus diode, so a single contactor failure leaves the battery
bus unpowered, in spite of having two working alternators. So if I
have one electric fuel pump, and it happens to be on that battery bus,
then my flight endurance is limited by battery capacity.
Perhaps what I am looking for, is a modification to Z14, that will
provide an alternative path to a battery contactor that fails, without
providing additional failure modes that take away the advantages of
the isolated system. Any ideas how to do this ?
Jeff Page
Dream Aircraft Tundra #10
klehman(at)albedo.net
PostPosted: Sat Feb 20, 2010 7:50 pm    Post subject: Failure modes with Z14 Reply with quote
Jeff
I have 320 hours on my Z-14 which is really two electrical systems. Each
system powers an ignition and efi system directly from the battery and
either system will run the engine. Both alternators have an OVP system
that will disconnect the respective alternator.
So to damage one ignition or efi computer there must be two failures.
The regulator and then the OVP system. I don't worry about two failures
but even then the second system will run the engine. As per Bob's
directions for the OVP, it is easy to test the OVP module occasionally
if I choose. The procedure is simply to bump the voltage a couple of
volts with a couple of D cell flashlight batteries as I recall.
I guess my main point is that I do not route engine critical current
through a contactor. Why put more things to fail in those current paths.
I do run other systems, including starter current through a contactor.
The only time the crossfeed contactor closes is during engine cranking
or if I decide to manually close it after an alternator fails. I also
feed one cigarette lighter receptacle from a battery bus in case I ever
need to power a handheld device from it. Also comes in handy when camping.
Ken
four messages, I will continue with the pertinent pieces. I appreciate
the responses !
considering (along with Z13/Cool, so that messed up the discussion a lot,
intend to install E-Mag ignitions, not the Light Speed, but this choice
example, since each spring my wife and I fly it from Toronto to Bahamas
to Sun n Fun and back, and other long trips as well. No matter what
design I select, it will be a far better system. However, since I can
chosen load in the airplane as needed, within the limits of the current
produced. I have spent quite a lot of times considering the effects of
various failures.
problem is an over voltage event that the OV module didn't address in a
timely fashion, and the electronics in both ignitions fried. Bob, your
statistics are the same way. I don't care how rare a disease is if I am
the one that has it. Then, in another post, you describe the in-flight
fire in a Lancair IV-P due to the abused regulator/OV unit that I am
plan B.
bus unpowered, in spite of having two working alternators. So if I have
one electric fuel pump, and it happens to be on that battery bus, then
providing additional failure modes that take away the advantages of the
Jeff Page
PostPosted: Sat Feb 20, 2010 9:47 pm    Post subject: Failure modes with Z14 Reply with quote
At 03:52 PM 2/20/2010, you wrote:
<snip>
But that's a DUAL failure. An OV protection scheme fails
followed by a regulator running amok . . .
Bob, your experience indicates this is a very unlikely occurance. Medical
How many dual failures do you intend to hypothesize and
address as part of your FMEA?
Then, in another post, you describe the in-flight fire in a Lancair
IV-P due to the abused regulator/OV unit that I am planning on using Wink
That wasn't an electronics failure but an INSTALLATION failure.
Similarly, you can't have a plan-b for loose prop bolts, thrown
jugs, ailerons lost to high speed flutter, etc. These things
are even more rare but offer exceedingly dire challenges to
your survival skills.
A optimally managed OV event becomes an LV even in tens
of milliseconds after onset of the failure. This is why
we generally don't bother to install OV annunciators
on the panel . . . but bulbs don't stay lit long enough
for you to make much use of what they have to tell you.
After the alternator is shut down, plan-b is the same
as if you'd thrown a belt, broken a wire, etc.
A battery operated radio is great, but there is no equivalent for
the ignition.
plan B.
This is why instructions for installing our OV modules
call for testing every annual along with instructions on
how to do it. However, these devices have been installed
on TC aircraft for over 40 years. I don't recall seeing
any maintenance manual call for annual testing.
If a fuel pump is critical to sustained flight, then why
don't you have two pumps? Z14 has no ENDURANCE bus because
one bus becomes the endurance bus should the other one be
taken down due to alternator failure. If the small alternator
quits, then most likely both busses can be kept up using
the larger alternator. If the big guy quits, then shut
the main bus down, reduce loads to get airport in sight using
small alternator . . . then close the cross-feed contactor
and use both batteries plus small alternator to terminate
the flight.
Your stacking failure on top of failure to the degree that
you'll have plans B, C, D, etc. Worse yet, you risk becoming
and electrical systems failure analyst when you should be
concentrating on piloting instead of deducing the appropriate
"plan".
Make one of the Emags a self-powered version and wire
as shown in Figure Z-13/8 . . . you've got redundancy
to burn. If your engine is electrically dependent on
fuel delivery, then you need two pumps. Run one from
the main bus, the other from the battery bus.
Run a 9011 multi-channel OV.LV monitor to annunciate
contactor failure.
jpx(at)qenesis.com
PostPosted: Sun Feb 21, 2010 10:39 pm    Post subject: Failure Modes with Z14 Reply with quote
Yes, I intend to power the ignitions and fuel pump directly from the
battery bus (through fuses of course).
I re-wired the cigarette lighter in my Cessna so I could charge my
phone at Sun n fun and Oshkosh Smile
Ken
Failure of any single part should cause little concern, and probably
little notice by an oblivious passenger. Probably most dual failures
would mean full utilization of plan B, rather than a forced landing.
The dual failure that merits my attention is both ignitions failing.
With isolated electrical systems, that would be exceptionally
unlikely. With Z13/8 and a B&C LR3C-14 (or equivalent), that could
potentially happen. I don't plan on mounting it upside down so it can
fill with water, but it is not impossible that I unknowingly make a
similar mistake.
In the event of an OV situation, I have to count on the controller and
the circuit breaker both doing what they are supposed to do. Most of
us have much confidence due to familiarity in the electrical items
like alternators installed on our planes, because we have used them in
cars etc. for years and have monitored their operation. And we know
they fail sometimes. Who hasn't replaced an alternator ? At best we
can occasionally test the OV circuitry. How many of us have extensive
experience with the OV protection accomplishing its mission when it
was needed ? How do I compare the sensitivity of the OV module
compared to the ignition module ?
If I install isolated systems to run the ignitions, I do not need to
determine the potential for failure of the regulator, OV circuitry and
circuit breaker.
I know it seems like I am overly concerned about a very unlikely
possibility. As ugly and maintenance prone as magentos are, they are
unbelievably unlikely to both fail on the same flight. I don't want
to replace them with another system, for which I can identify a
possible failure mode that takes them both out, while addressing it
only with "well, that is very unlikely". I need to either modify the
design to eliminate the possibility, or be convinced that very
unlikely is much more unlikely than, say, my prop coming off. I have
no practical way of quantifying "very unlikely", so I am trying to
eliminate the possibility. An isolated system is not excessively
complex or expensive, I just need to determine the best way to do it.
Hopefully, due to the time spent learning from your book and this list
(much appreciated !), together with my schooling and attention to
detail, I won't make a similar error.
The best I can do to mitigate some of these risks is to purchase
quality parts and assemble them with mentors and mechanics checking my
work, plus dual instruction in handling emergencies.
As long as my ignitions are still working, plan B works well,
otherwise I am landing in a very undesirable place Sad
the flight.
The electric fuel pump is only necessary to back up the mechanical
pump. It just seems odd that with the design of Z14, that with the
single failure of a contactor, but two working alternators, there is
no path to charge both batteries. With Z13/8 there are dual charging
paths, which is a very nice design.
to burn.
Actually, I do intend to run one or two P-Mags. I just need to ensure
I will not fry both of them with an OV event.
contactor failure.
I have designed, but not yet prototyped a LV monitor that will
annunicate LV on either battery, and be activated by either battery
contactor switch or the "clearance delivery" switch (the don't drain
the battery by leaving the switch on idiot feature).
Some of the features of Z14 I probably don't need. There has been
some discussion that two smaller batteries cannot delivery the same
starter current that a single large battery can. Perhaps the solution
is a modification to Z13/8, whereby the standby alternator is always
in use to power the second ignition. Isolate that with a cross feed
relay and add a second small battery. The cross feed relay would be
only used to route power to the endurance bus after main alternator
failure, but not to kick in the second battery during starting.
Jeff Page
PostPosted: Mon Feb 22, 2010 8:04 am    Post subject: Re: Failure modes with Z14 Reply with quote
The battery is NOT the power source for electrical equipment on an aircraft. The alternator is. Z-13/8 has two alternators. If the main one fails, the aux alternator will power the ignition. If both alternators fail, the battery is a backup. Once the engine is running, failure of the battery contactor will most likely not affect the operation of the alternators. An ignition connected to the E-bus will keep working after the battery contactor fails, drawing its power from the alternator as usual. Each ignition should be connected to separate points of the electrical system so that a bad connection will only affect one ignition. In Z-13/8 after a battery contactor failure, the battery can be kept charged by the main alternator through the E-Bus relay or by the aux alternator. Even if both alternators and the battery contactor fail, the battery still has enough stored energy to power one ignition for a couple of hours. The length of time can be determined by doing a load test on the battery. This is something that should be done periodically anyway. If there are still concerns of contactor failure, a diode can be placed across the big terminals of the contactor with the arrow pointing towards the battery. However, this is not needed or recommended.
Many years ago I had a VW with a 6 volt battery. The generator quit working (but I did not know it). The engine barely cranked when I started it to go home after work at night. After a couple of miles, the headlights got dimmer and dimmer, then the engine quit. Before the car coasted to a stop, I shut off the headlights and the engine started to run again. There was not much traffic that late at night. Every time a car approached, I pulled off onto the shoulder and waited for it to go by. It was hard to see without headlights. I discovered that the engine would keep running with the turn signal on. So I used that to see the road, driving very slowly. It took me a couple of hours to get home, but I made it. The point is that it doesn't take a fully charged battery to power the ignition.
As for over voltage protection, two OV modules can be used. Then the regulator would have to fail along with both OV modules before the electronics would be fried. I do not think these extreme measures are necessary or desired. If the voltage regulator fails, an alternator properly sized to just barely meet the expected load will not develop as high of a voltage as a larger alternator will.
Many things can go wrong on an aircraft. Perhaps a BRS is the answer. But even those malfunction.
Joe
Joe Gores
PostPosted: Mon Feb 22, 2010 8:13 am    Post subject: Failure Modes with Z14 Reply with quote
Jeff
The 2 little Dekka 8 AH batteries on my Z-14 system are indeed
equivalent to one 16AH battery except for being more expensive. They
have large bolted lead terminals and one will start the subaru. Two are
better when it is very cold. The batteries do what the manufacturer
says. Small batteries with small terminals that are not designed to
start engines will be a different story.
My system does indeed allow charging both batteries with any single
contactor failure. Not a big deal but a consideration with small
batteries. Both alternators feed through their OV contactors to the
respective battery. No second contactor between them and the batteries.
With appropriate component placement I believe that I have no additional
always hot wiring risk with this setup. Because I feed non engine loads
(and cranking current) through a contactor, a failure of that contactor
will kill most other systems but it won't affect the engine. I have
ample battery bus (the cigarette lighter and limited panel lighting),
and handheld backup options for that. I do not have any IFR avionics at
this time.
Your failure concerns do resonate with me. My design was heavily
influenced by the knowledge that it was a one off system by a first time
builder using components placed in a new environment that nullified
previous failure data. That is why Bob's philosophy and Z-14 suited me
so well with an electric dependent engine. Even though electric
components can fail without warning, the engine electrical and EFI
systems are the least of my engine reliability concerns now.
If it helps - yes I did spend some time testing the OV modules and yes
they perform exactly as advertised and the current version simply does
not trip unless there is a real OV event.
Don't overlook ergonomics. Keep your system as operationally simple as
possible. Give some thought to what you actions you will take for
failures and locate controls to make those actions simple and
methodical. Ideally one procedure for all engine problems is ideal.
Ken
snip>
Some of the features of Z14 I probably don't need. There has been some
discussion that two smaller batteries cannot delivery the same starter
current that a single large battery can. Perhaps the solution is a
modification to Z13/8, whereby the standby alternator is always in use
to power the second ignition. Isolate that with a cross feed relay and
add a second small battery. The cross feed relay would be only used to
route power to the endurance bus after main alternator failure, but not
Jeff Page
PostPosted: Mon Feb 22, 2010 9:58 am    Post subject: Failure modes with Z14 Reply with quote
While I have also seen an electrical system function just fine with the
battery disconnected, such performance is not a certainty in all situations.
You raise a point that is dear to me though. Perhaps because I've seen
the results of batteries fed by a runaway regulator, I am also a
proponent of using a small alternator. ie. one that is adequate for
normal ops rather than one that can put out twice the power that will
ever be needed. Especially as we migrate to lower power electronics,
lights, and smaller batteries. Years ago I also had an occasion to
manually cycle a runaway generator with a melting battery while IFR and
it would have been much less tense had it been a smaller unit.
I have confidence in the OV protection but my OV contactor still has to
open for it to work and the less current going through it the better I
think. Actually I had a different contactor fail to open this weekend
but it worked on about 20 subsequent tries so I don't know yet whether
it is the switch or the contactor. My OV contactors normally switch
while unloaded so they will likely last forever.
Ken
user9253 wrote:
<fran4sew(at)banyanol.com>
The length of time can be determined by doing a l! oad test on the
recommended. Many years ago I had a VW with a 6 volt battery. The
power the ignition. As for over voltage protection, two OV modules
alternator will. Many things can go wrong on an aircraft. Perhaps a
BRS is the answer. But even those malfunction. Joe
-------- Joe Gores
PostPosted: Tue Feb 23, 2010 8:19 am    Post subject: Failure Modes with Z14 Reply with quote
At 09:38 AM 2/22/2010, you wrote:
Jeff
are better when it is very cold. The batteries do what the
manufacturer says. Small batteries with small terminals that are not
designed to start engines will be a different story.
Yes, the Dekka products are unique for their size.
Your words generate an interesting idea . . .
Assume the builder chooses commercial off the shelf
IR alternators and a variant on Z-24 for control and
ov protection. In this instance, one COULD set the
altenrator b-lead contactor next to a battery contactor
and tie it's output directly to the battery.
This configuration satisfies the legacy design goal
of minimizing hot fat-wires when all switches are
OFF. Now you can have your battery contactors feed
a single main bus. No e-bus is needed since you're
not likely to every need battery-only ops. Now you
have two, independently alternator-supported batteries.
Two battery busses to distribute loads for an electrically
dependent engine. A main bus that's not subject to
single-point-of-failure. Cool.
I'll pray over this a bit. Perhaps a Figure Z-8 is
being conceived . . .
PostPosted: Tue Feb 23, 2010 10:36 am    Post subject: Failure Modes with Z14 Reply with quote
Yes I was thinking that a small Bosch "40" amp relay and fuse would be
quite adequate for turning my main bus into an E bus since my main bus
loads are under 20 amps. Halogen landing lights and nav lights are the
only things on it that draw significant power. With my key starter
switch, it is not possible to crank the engine unless the main bus
contactor is closed. Similar to a car, first key position closes the
main bus contactor and then the spring loaded position cranks the
engine. It has worked well for me.
Alternatively, with a 20 amp or larger second alternator, most folks
could eliminate the crossfeed contactor and then dual main bus
contactors would in fact be the crossfeed.
Ken
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> Jeff
jpx(at)qenesis.com
PostPosted: Tue Feb 23, 2010 7:56 pm    Post subject: Failure modes with Z14 Reply with quote
Joe,
I am quite comfortable with the situation that would occur if any of
the individual parts of Z13/8 should fail. I don't expect a contactor
failure is any more significant than other failures. What I like
about Z13/8 is that there are alternate feed paths so that the
alternator(s) can continue to keep the batteries charged, and power
can be supplied to the endurance bus.
I once drove a car all winter without a functioning alternator. It
was mounted on the bottom of the engine and I didn't want to lie in
the snow to fix it. I knew how many starts and how long I could drive
with and without the headlights. I only got caught needing a boost
once all winter Wink
So the only thing that I would like to do is ensure that an
overvoltage condition cannot damage both ignitions. Perhaps two OV
modules would do it, but I would feel more comfortable with an
isolated system.
Ken,
This is good to know.
single contactor failure.
How did you change the circuit to accomplish this ?
Also useful to know. How did you test them ? I expect that applying
16V to the sense lead would result in the field breaker tripping. My
concern would be duplicating the shorted regulator scenario, that is,
applying 12V directly to the field terminal. This should result in
the alternator producing possibly 80-120V ? Does the breaker trip in
time to protect some cheap auto headlamps ? I don't think I want to
do this test with my expensive ignitions.
This I have thought a lot about. In the end, I came up with a color
coded system. If this LV light illuminates, flip the switches joined
with the same color line. Easy to do in flight without a checklist
(although I would use one anyway). No troubleshooting in flight.
I would like opinions on the feasibility of modifying Z13/8 by
isolating the aux alternator path with a cross feed relay that would
be open in flight except after alternator failure. I would add a
small battery to ensure the SD-8 produces power.
Jeff Page
raymondj(at)frontiernet.n
PostPosted: Tue Feb 23, 2010 9:28 pm    Post subject: Failure modes with Z14 Reply with quote
Jeff,
I would be interested in seeing your "Light/line" switch layout on your
panel. Sounds like a good idea. Are there any pictures posted anywhere
I can look at?
Raymond Julian
Kettle River, MN.
Jeff Page wrote:
Joe,
I am quite comfortable with the situation that would occur if any of the
failure is any more significant than other failures. What I like about
Z13/8 is that there are alternate feed paths so that the alternator(s)
can continue to keep the batteries charged, and power can be supplied to
the endurance bus.
I once drove a car all winter without a functioning alternator. It was
mounted on the bottom of the engine and I didn't want to lie in the snow
to fix it. I knew how many starts and how long I could drive with and
without the headlights. I only got caught needing a boost once all
winter Wink
So the only thing that I would like to do is ensure that an overvoltage
condition cannot damage both ignitions. Perhaps two OV modules would do
it, but I would feel more comfortable with an isolated system.
Ken,
applying 12V directly to the field terminal. This should result in the
alternator producing possibly 80-120V ? Does the breaker trip in time
to protect some cheap auto headlamps ? I don't think I want to do this
I would like opinions on the feasibility of modifying Z13/8 by isolating
the aux alternator path with a cross feed relay that would be open in
flight except after alternator failure. I would add a small battery to
Jeff Page
PostPosted: Wed Feb 24, 2010 8:06 am    Post subject: Re: Failure modes with Z14 Reply with quote
Jeff,
Perhaps two OV modules would do it, but I would feel more comfortable with an isolated system.
The advantage of building your own plane is that you can design it to meet your goals.
How did you test them? I expect that applying 16V to the sense lead would result in the field breaker tripping. My concern would be duplicating the shorted regulator scenario, that is, applying 12V directly to the field terminal.
Testing is accomplished by applying a high voltage directly to the OV module and not to the rest of the electrical system. Do this by disconnecting the wire to the OV module and inserting 2 D-Cells in series with the wire. The test can be conducted with the engine not running. See this circuit: http://tinyurl.com/ydpjzkl
This document also describes testing the over voltage protection, but it does not test the circuit breaker: http://www.aeroelectric.com/DIY/DIY_Crowbar_OVP_F.pdf
I would add a small battery to ensure the SD-8 produces power.
The SD-8 is a permanent magnet alternator. It does not require any battery power to excite the field windings because there are none.
Bob N offers very good philosophy on the subject of backup systems:
http://tinyurl.com/ybbdffj
Joe
Joe Gores
jpx(at)qenesis.com
PostPosted: Wed Feb 24, 2010 11:47 am    Post subject: Failure Modes with Z14 Reply with quote
Ray,
My circuit diagram and the switch panel layout are available here:
http://www.qenesis.com/tundra/Electrical
Jeff Page
Re: Failure Modes with Z14
I can look at?
Raymond Julian
PostPosted: Wed Feb 24, 2010 1:04 pm    Post subject: Failure Modes with Z14 Reply with quote
Jeff,
Thanks for the link. Your layout looks like a good way to aid in
decision making during high stress events. I will definitely include
that feature in my panel planning.
Raymond Julian
Kettle River, MN.
Jeff Page wrote:
Ray,
Jeff Page
> I can look at?
> Raymond Julian
PostPosted: Wed Feb 24, 2010 1:14 pm    Post subject: Re: Failure modes with Z14 Reply with quote
Jeff,
I looked over your schematic at http://www.qenesis.com/tundra/Electrical/Tundra_Power_Wiring.pdf and it looks very good. It would be interesting to see the internal schematic for the low voltage module and the purpose of the wires connected to it from switches. I am not saying that anything is wrong, only that I do not know what is inside of that box and how it works.
Good job.
Joe
Joe Gores
jpx(at)qenesis.com
PostPosted: Wed Mar 10, 2010 7:04 am    Post subject: Failure modes with Z14 Reply with quote
Joe,
Thanks for taking the time to look at my diagram. It is comforting to
know that someone else doesn't see any obvious goofs.
I have finished the diagram of the low voltage monitor. Its link is
now available at the same page:
Note that I have drawn the diagram, but not yet breadboarded it, so it
may not function as intended.
I would be particularly interested in any changes that would make the
design better handle the DO-160 nasties.
Jeff Page
works.
Good job.
Joe
PostPosted: Wed Mar 10, 2010 2:57 pm    Post subject: Re: Failure modes with Z14 Reply with quote
Jeff,
If wire 2223 or its connections fail, power will be lost to the essential bus. Wire 2222 should be connected directly to the E-Bus.
Now I see what those 4 wires are for that connect between the low voltage module and grounded switches. Any one of the switches can enable the low voltage module. The diodes isolate the 4 switches from each other. Did you design the low voltage warning module yourself? Are you an electrical engineer? Let us know how it works.
Joe
Joe Gores
