Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27557 Location: Livermore CA USA
Posted: Sun Feb 28, 2010 12:10 pm Post subject: Photos Of CS Prop Bolt Safety Wiring...? |
Does anyone have any close-up photos of how they safety wired the prop bolts on a Hartzell CS prop? You have to run the safety wire though those roll-pins. What a pain. If you have to pull the torque up from the bottom, it seems impossible to actually set twist. Maybe if I twist both ends first... Hum...
Anyway, some pics would be most appreciated!
RV-8 #82880 N998RV
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Matt Dralle
Posted: Sun Feb 28, 2010 3:33 pm Post subject: Photos Of CS Prop Bolt Safety Wiring...? |
At 12:08 PM 2/28/2010 Sunday, Matt Dralle wrote:
| Quote: | Does anyone have any close-up photos of how they safety wired the prop bolts on a Hartzell CS prop? You have to run the safety wire though those roll-pins. What a pain. If you have to pull the torque up from the bottom, it seems impossible to actually set twist. Maybe if I twist both ends first... Hum...
Well, okay, so it wasn't quite as hard as I thought. It was still a pain though! Here are three pictures of the safety wiring I did on the Hartzell CS Prop bolts (photo of each pair of bolts). What do you guys think?
Best regards,
RV-8 #82880 N998RV
| Description: |
| Filesize: |
125.01 KB |
| Viewed: |
3499 Time(s) |
| Description: |
| Filesize: |
122.46 KB |
| Viewed: |
3499 Time(s) |
| Description: |
| Filesize: |
127.76 KB |
| Viewed: |
3499 Time(s) |
blake.lewis(at)gmail.com Guest
Posted: Sun Feb 28, 2010 3:59 pm Post subject: Photos Of CS Prop Bolt Safety Wiring...? |
Matt,
I watched a mechanic do this last Thursday. Well I didn't watch the whole time because it took him forever. He was complaining an hour after he was done.
I didn't take pics.
Blake.
[quote] Does anyone have any close-up photos of how they safety wired the prop bolts on a Hartzell CS prop? You have to run the safety wire though those roll-pins. What a pain. If you have to pull the torque up from the bottom, it seems impossible to actually set twist. Maybe if I twist both ends first... Hum...
