447
lhaggerty(at)tampabay.rr.
PostPosted: Wed Mar 03, 2010 12:39 am    Post subject: 447 Reply with quote
How can I tell if I am looking at a point breaker 447 or a SDI 447 engine. Pete
herbgh(at)nctc.com
PostPosted: Wed Mar 03, 2010 9:55 am    Post subject: 447 Reply with quote
Points ignition has ignition coils stacked at the pull start end of the engine...Herb
At 02:39 AM 3/3/2010, you wrote:
[quote]How can I tell if I am looking at a point breaker 447 or a SDI 447 engine. Pete
WhiskeyVictor36(at)aol.co
PostPosted: Wed Mar 03, 2010 3:00 pm    Post subject: 447 Reply with quote
Pete,
The points 447 has two separate external ignition coils mounted on the side of the engine and also has an ignition damping box mounted onto the pull start assembly housing. The CDI Ducati ignition 447 only has one external ignition coil feeding both plugs.
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 3/3/2010 3:39:08 A.M. Eastern Standard Time, lhaggerty(at)tampabay.rr.com writes:
-List href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
tp://forums.matronics.com/">http://forums.matronics.com
[/b]
ulflyer(at)verizon.net
PostPosted: Wed Mar 03, 2010 3:02 pm    Post subject: 447 Reply with quote
Herb, stacked at one end compared to what?
At 09:52 AM 3/3/2010, you wrote:
[quote]Points ignition has ignition coils stacked at the pull start end of the engine...Herb
Email Forum -
- MATRONICS WEB FORUMS -
- List Contribution Web Site -
[/b]
henry.voris
PostPosted: Wed Mar 03, 2010 3:54 pm    Post subject: Re: 447 Reply with quote
03feb10
Pete,
Attached is a photo of my thundering 447 w/ Ducatti electrics...
Aloha,
 Filesize:  35.14 KB
 Viewed:  9403 Time(s)
Henry
Firefly Five-Charlie-Bravo
herbgh(at)nctc.com
PostPosted: Wed Mar 03, 2010 6:11 pm    Post subject: 447 Reply with quote
Compared to a single ign coil with both wires coming out that is below the carb area ...Herb
At 03:14 PM 3/3/2010, you wrote:
[quote]Herb, stacked at one end compared to what?
Email Forum -
Email Forum -
[/b]
Checked by AVG - www.avg.com
07:34:00[b]
nla1(at)comcast.net
PostPosted: Wed Mar 03, 2010 6:53 pm    Post subject: 447 Reply with quote
Henry,
Your picture is a CDI (SDI) ignition system. Here is what a point ignition system looks like
Aloha
henry.voris wrote:
--> Kolb-List message posted by: "henry.voris" <henry_voris(at)yahoo.com> (henry_voris(at)yahoo.com)
03feb10
Pete,
Aloha,
Henry
http://forums.matronics.com/viewtopic.php?p=289120#289120
http://forums.matronics.com//files/ducatti_with_cracked_boot_212.jpg
 Filesize:  92.31 KB
 Viewed:  9392 Time(s)
PostPosted: Thu Mar 04, 2010 9:44 pm    Post subject: 447 Reply with quote
I can't get spark to my electronic ingnition plugs any suggestions before I spend big bucks hireing someone to look at it? Pete
rickofudall
PostPosted: Fri Mar 05, 2010 5:23 am    Post subject: 447 Reply with quote
What happened and what have you done so far? What are you using determine there's no spark?
Rick Girard
On Thu, Mar 4, 2010 at 11:43 PM, lhaggerty <lhaggerty(at)tampabay.rr.com (lhaggerty(at)tampabay.rr.com)> wrote:
[quote] I can't get spark to my electronic ingnition  plugs any suggestions before I spend big bucks hireing someone to look at it?  Pete
George Myers
PostPosted: Fri Mar 05, 2010 7:11 am    Post subject: 447 Reply with quote
Be sure to take out both plugs and have someone really spin the engine. The spark on these things is hard to see. Ground it out of the light. Don’t ask how I know. Neutral
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of lhaggerty
Sent: Thursday, March 04, 2010 11:44 PM
Subject: 447
PostPosted: Fri Mar 05, 2010 2:57 pm    Post subject: 447 Reply with quote
We removed the plugs, they were wet with fuel, we grounded them and pulled the engine thru several times and could not see spark. Then we checked the kill switch to make sure is was working, checks out good. I am trying to get info on how to check out the cdi coil. Pete
www.avg.com
Version: 8.5.435 / Virus Database: 271.1.1/2724 - Release Date: 03/05/10 13:26:00
elleryweld(at)aol.com
PostPosted: Fri Mar 05, 2010 10:03 pm    Post subject: 447 Reply with quote
Use a new set of plugs when you are trying to see if it is firing and do it in a dark area so you really can tell if it is firing the old plugs may have gotten fouled
Ellery Batchelder Jr.
