MP plumbing
rparigoris
PostPosted: Wed Mar 10, 2010 2:10 pm    Post subject: MP plumbing Reply with quote
I guess a little off topic, I have a question about plumbing my manifold pressure gauge. An avionics shop mentioned to me a while back (now out of business) it is a good idea to have ability to drain manifold pressure line once a year. They said even with a normal aspirated engine, crud makes its way into gauge and clogs up the works. He said they install near the gauge an easy way to create a leak once a year and let crud get sucked through engine. I don't know if they use a needle valve, some sort of valve, a capped flair or?? i have a Rotax 914 that has ability to not only suck, but pressurize as well, being a turbo oil can certainly be in the mix as well. I have a UMA dual diaphragm 2+1/4" gauge, UMA said they recommend ability to purge line once a year but offer no guidance as far as what sort of hardware to use to create leak. any ideas or suggestions?Thx.Ron Parigoris [quote][b]
david.nelson(at)pobox.com
PostPosted: Wed Mar 10, 2010 2:56 pm    Post subject: MP plumbing Reply with quote
Hi Ron,
Why not place a clear, in-line "fuel-filter" as found at motorcycle/small engine
shops?
Just an idea,
/\/elson
~~ Lately my memory seems to be like a steel trap .... without any spring. ~~
Thx.
Ron Parigoris
