7suds(at)Chartermi.net Guest
Posted: Wed Mar 10, 2010 9:07 pm Post subject: 912ul Oil and Filter |
Guys,
Just wondering what people are using for Oil and Filters on their 912ul
engines and why you like it whether that be the Rotax Oil and filters or
aftermarket alternatives.
Lloyd Cudnohufsky
Northern Mi.
Mod 5 912ul IV IFA
A work in progress
Do not Archive
paul perry
Posted: Wed Mar 10, 2010 9:57 pm Post subject: Re: 912ul Oil and Filter |
Lloyd, there are extensive posts in the rotax forum on the subject of oil and filters , but the last post by Roger Lee about filters at http://forums.matronics.com/viewtopic.php?t=14122&highlight seems to sum up the situation best (at least for me) Since the rotax filters cost so much more than the automotive filters that are available, each owner will have to make a decision if they are really worth it, especially since many have the opinion that the rotax is really not as good as the purolator or mobil-1. I have used the rotax and the mobil-1, while the previous owner/builder used a napa-gold. I haven't had any problems with any of them, but I have only about 70hrs experience with the engine since purchasing the plane in June 2008. I use valvoline 10w-40 4 cycle motorcycle oil since I burn 100LL. If I was using no-lead gas, then I would probably go with one of the synthetic oils per rotax guidelines. If I had a warranty on my engine still in effect, then I would stick with the rotax filters, but my engine is not under warranty so I plan on using the purolator or mobil 1 filters next time because of availability and price.
Paul Perry
KV IV Speedster/912UL (mfg 2001 and 152hrsTT)
Posted: Thu Mar 11, 2010 2:56 pm Post subject: 912ul Oil and Filter |
Thanks Paul, great info on the filters.
